Author Topic: hhkb caps lock  (Read 27577 times)
Offline GenEric35
hhkb caps lock
« on: Sat, 13 March 2010, 12:03:50 »
I couldn't find the caps lock on my hhkb, it kept toggling on and didnt know what did, then did a search on the forum for hhkb caps lock and nothing clear came up, and also had heard that it didnt have that key, to clear up any confusion i make this post, it's:
fn+tab
« Last Edit: Sat, 13 March 2010, 12:07:31 by GenEric35 »
:target: HHKB Pro 2
IBM Model M 1390131
Unicomp Customizer
Offline ssdt
Re: hhkb caps lock
« Reply #1 on: Mon, 24 April 2017, 15:38:34 »
You are a life-saver! :D
Poker II         HHKB Pro 2
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” - Aristotle
Offline Chape
Re: hhkb caps lock
« Reply #2 on: Fri, 08 February 2019, 07:54:38 »
Hey thank you so much, was also stuck with this... I've just created my account on this forum to thank you ! Have a great day :)
Offline livewirerc
Re: hhkb caps lock
« Reply #3 on: Mon, 11 February 2019, 16:45:24 »
fn+tab
Y'all must be using one of the blank key models of the HHKB. Both of my printed key models have "Caps" printed on the front of the "Tab" key, similar to how all the other keys have their function button use printed on the fronts.
