Author Topic: 75% DSA Keycap Set  (Read 2056 times)
Offline sabron
75% DSA Keycap Set
« on: Fri, 08 September 2017, 03:26:37 »
Any idea where I can get a keycap set for a 75% board? looked everywhere can't seem to find any normal ones with white, greyish keycaps.
Thank you.
« Last Edit: Fri, 08 September 2017, 03:29:21 by sabron »
Offline Petch
Re: 75% DSA Keycap Set
« Reply #1 on: Fri, 08 September 2017, 10:53:35 »
DSA is a uniform profile, so a standard set will fit a 75% perfectly (as long as you have the 1.75u shift)
