Author Topic: [GB]CAMP C225 80% and CAMP PAD Custom Aluminum Keyboard  (Read 160483 times)
Offline Vadurr
  • Valar Morghulis
Re: [GB]CAMP C225 80% and CAMP PAD Custom Aluminum Keyboard
« Reply #100 on: Fri, 22 September 2017, 16:02:15 »
Does this board support split backspace?
Neither plate shown in the OP do, so I doubt it. Looks like you can only alter the bottom row, caps lock, and right shift.
Ahh I figured. Thanks!
Offline mkarlsson
« Reply #101 on: Sat, 23 September 2017, 06:11:49 »
Hey SuperVan / just, I filled up the form on the 19th, when should I get my invoice?
Enviado desde mi iPhone utilizando Tapatalk
Offline SuperVan
« Reply #102 on: Sat, 23 September 2017, 06:31:34 »
No.
Offline SuperVan
« Reply #103 on: Sat, 23 September 2017, 06:33:10 »
Don't worry about that. You will get your invoice soon.
Offline mkarlsson
« Reply #104 on: Sat, 23 September 2017, 06:35:41 »
Great, thanks for the info!
Offline mkarlsson
« Reply #105 on: Sat, 23 September 2017, 09:51:30 »
Got the invoice, it says Titanium+silver+wkl, did you see the note about the CF plate?
Thanks a lot.
Offline techfresh
« Reply #106 on: Sat, 23 September 2017, 11:19:54 »
Is there an MOQ?  Also when will the spreadsheet for order status be published?  I am also worried about there not being enough interest in this board.  I think it looks great and hope it goes through.
I wish it was a little heavier like 2.2kg. There are 60%'s that are heavier like the fjell and x60.  How thick is the brass plate?  Is 6063 a lighter aluminum than 6061?  I'm just wondering why this case is so much lighter than other TKLs.
Any response on why this only weighs 1.8kg?  The brass weight looks somewhat thick so not sure if it means the base of the case is not very thick.
Offline just
« Reply #107 on: Sat, 23 September 2017, 11:25:13 »
Thanks a lot.
supervan will pm you
« Last Edit: Sat, 23 September 2017, 11:29:28 by just »
cc is all
Offline xondat
  • i'm not a star
« Reply #108 on: Sat, 23 September 2017, 11:25:47 »
The weight is pretty small; you can see the thickness here:
Maybe 3-4mm?
6063 and 6061 are the same density (2.7g/cm3, brass is about 8.5g/cm3).
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #109 on: Sat, 23 September 2017, 12:46:40 »
Maybe 3-4mm?
The only thing I think i would change on this would be a weight that went all the way through, for maximum t h i c c
Offline Softkore
« Reply #110 on: Sat, 23 September 2017, 13:16:11 »
Which one is the blue gray? The photos are confusing for me. I'm having a hard time choosing color, can we get a more clear picture of the blue gray?
« Reply #111 on: Sat, 23 September 2017, 13:45:44 »
Offline Softkore
« Reply #112 on: Sat, 23 September 2017, 13:49:00 »
Thank you very much!!
Sent from my Pixel using Tapatalk
Offline strigif0rm3s
« Reply #113 on: Sat, 23 September 2017, 15:10:15 »
Just ordered the blue/gray. Omg gorgeous. Only cherry type switches compatible? Kaihl, cherry, zelios?
Sent from my Nexus 6P using Tapatalk
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #114 on: Sat, 23 September 2017, 15:16:01 »
Btw will I be able to change the address later on? Looks like I'll be moving before the boards ship
« Reply #115 on: Sat, 23 September 2017, 16:45:02 »
correct
Offline beerafffe1
« Reply #116 on: Sat, 23 September 2017, 17:26:49 »
I am new to the whole custom keyboard area, so please help a newbie out. I built my first keyboard recently and fried the first PCB, so I was wondering
  • If extra PCBs are an option without getting a plate
  • Will other TKL PCBs fit in the case? If yes, which ones?
Thanks for your help, this Blue-Grey option looks so nice I am going to get my first custom.
Offline LiQuiDs
« Reply #117 on: Sun, 24 September 2017, 00:38:29 »
can you guys upload MAO Black color C225 please? i want to see it what is different to just Black?
also i ask you guys Is the red color of the picture the color of the actual keyboard? same hot red?
Great art is an instant arrested in eternity.
Offline Cyllinus
« Reply #118 on: Sun, 24 September 2017, 02:23:57 »
I would also like to see MAO in black.
Offline SuperVan
« Reply #119 on: Sun, 24 September 2017, 08:57:15 »
1. You can leave a note. 2. No.
Offline SuperVan
« Reply #120 on: Sun, 24 September 2017, 08:57:50 »
I will update later.
Offline beerafffe1
« Reply #121 on: Sun, 24 September 2017, 09:05:34 »
Thanks! Submitted my response and Camp is going to be my first custom!
Offline SuperVan
« Reply #122 on: Sun, 24 September 2017, 09:08:08 »
Thanks for your support.
Offline Softkore
« Reply #123 on: Sun, 24 September 2017, 09:17:38 »
Would the Camp Pad support splitting the 2u keys, like 0 and +? I'd rather have all 1u keys.
« Reply #124 on: Sun, 24 September 2017, 14:17:21 »
if you look at the picture, you can see that it supports that setup
Offline Softkore
« Reply #125 on: Sun, 24 September 2017, 14:30:46 »
Sorry, I'm still new and not really experienced enough to easily tell from looking at the PCB :/
« Reply #126 on: Sun, 24 September 2017, 14:34:22 »
no worries, we all start somewhere
you can tell because there are 3 centered holes in the PCB under the longer plate holes
if there was only 1, then it would not support all 1u
and the plate is the right shape for it as well, but that's a more complicated issue
Offline Softkore
« Reply #127 on: Sun, 24 September 2017, 20:01:33 »
Thanks very much - I thought the plate looked right, but wasn't sure about the PCB. Now I know :B
« Reply #128 on: Sun, 24 September 2017, 20:29:49 »
 :thumb:
Offline 9999hp
« Reply #129 on: Mon, 25 September 2017, 19:49:09 »
That's a beautiful keyboard
« Reply #130 on: Mon, 25 September 2017, 22:10:34 »
Im in and paid. the low post count by OP is a bit alarming......
this is legit right? LOL
« Reply #131 on: Mon, 25 September 2017, 22:26:10 »
it's already run twice in china, to good reception
Offline laughatpain
« Reply #132 on: Mon, 25 September 2017, 22:46:13 »
Post count too high, must be a **** poster. Don't listen to anything he says.
JK
Actually though, CAMP is legit. Baby blue looks great.
Offline Bits
« Reply #133 on: Tue, 26 September 2017, 03:46:50 »
It took a bit longer to pay than I thought, but paid my invoice for my WKL+Pad! In it for real now :D
Sent from my ONEPLUS A3000 using Tapatalk
Offline Pell99
« Reply #134 on: Tue, 26 September 2017, 05:41:40 »
What is the weight of the C225?
« Reply #135 on: Tue, 26 September 2017, 05:45:42 »
That's what I thought. Just making sure. Thanks all. Super excited. First real custom.
« Reply #136 on: Tue, 26 September 2017, 09:53:04 »
1.8kg
Offline LiQuiDs
« Reply #137 on: Tue, 26 September 2017, 18:46:49 »
Any pictures of the MAO black?
We will update later.
please upload MAO Black pictures!!! i want to see and decide color!!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #138 on: Tue, 26 September 2017, 19:02:36 »
Dude, it's just gonna be a flat black
Offline just
« Reply #139 on: Wed, 27 September 2017, 05:59:27 »
most like that,but white(mao) is special,it is not pure white
cc is all
Offline Helldrop
« Reply #140 on: Thu, 28 September 2017, 04:56:21 »
I ordered one two days ago, but haven't received the invoice yet. Please send it to me.
Offline wukong_bot
« Reply #141 on: Thu, 28 September 2017, 10:01:08 »
Is there a way to change the color after we order? I'm not sure what color I want to get, but I want to join before the groupbuy ends. If you could show some pictures of MAO black and white this would help out a lot :)
Offline wise_star
« Reply #142 on: Thu, 28 September 2017, 11:03:18 »
Yea same here. Gonna be sad if I don't see one before the groupbuy ends.
Sent from my SM-N950U using Tapatalk
Offline just
« Reply #143 on: Thu, 28 September 2017, 12:12:30 »
Don't worry,we will give you  new pictures later
cc is all
Offline just
« Reply #144 on: Thu, 28 September 2017, 12:33:05 »
I send it to you  on  23rd September ,but I don't know why it  cancelled
cc is all
Offline beerafffe1
« Reply #145 on: Thu, 28 September 2017, 13:27:22 »
I am in the same boat, no invoice yet. But I submitted my form just last week though.
Offline Helldrop
« Reply #146 on: Thu, 28 September 2017, 14:18:43 »
I'm not sure, but might have deleted it by mistake or written a wrong email....
Anyway, thank you for sending the invoice to me again.
« Last Edit: Thu, 28 September 2017, 14:20:31 by Helldrop »
Offline Cyllinus
« Reply #147 on: Thu, 28 September 2017, 15:46:35 »
I filled out a form twice for a black case and received an invoice for titanium both times. Am I missing something?
Can I pay for titanium then change my color to black?
« Last Edit: Thu, 28 September 2017, 16:17:31 by Cyllinus »
Offline wise_star
« Reply #148 on: Thu, 28 September 2017, 19:34:29 »
I just put in for one yesterday. Are invoices still going out? Worried I missed it since it's only a couple days till it ends haha.
« Reply #149 on: Thu, 28 September 2017, 19:41:08 »
Was thinking about making my first zelios with this board......65g
