Author Topic: Wheelwriter keeb, got cheap (I think)  (Read 3129 times)
Offline ander
  • I type, therefore I am
« on: Wed, 20 September 2017, 20:43:09 »
I just snagged this lightly used IBM Wheelwriter 1500 board:
...for $19.75 + shipping, which seemed like a pretty decent deal—was it?
My plan is to use the distinctive keys (incl. spacebar) on one of my Model M's, so if anyone would like the rest of it for the price of shipping, PM me.
Offline OldIsNew
Re: Wheelwriter keeb, got cheap (I think)
« Reply #1 on: Wed, 20 September 2017, 20:59:52 »
The keys are sharp looking! Heck, considering that Unicomp single unit printed keys are $0.80 each, I think $20 was a good deal for sure.
Offline 0100010
  • Not Sure
« Reply #2 on: Wed, 20 September 2017, 21:15:45 »
Great price.   I would ANSI mod the big ass enter, split the backspace (would have to bolt mod it), put front printed function keys on the number row and add a controller.
Offline ander
« Reply #3 on: Thu, 21 September 2017, 06:26:40 »
Glad you guys think I did okay.
I'll just be harvesting the keys, though; this layout would be way too sparse for my needs. Adding layers seems like a step backward—why make typing more complicated and time-consuming than it needs to be? Texting's retrograde enough, thanks.
Offline ander
« Reply #4 on: Thu, 21 September 2017, 07:31:16 »
I have a taker for the board, sans keys...
They changed their mind, so the board's still available.
« Last Edit: Thu, 21 September 2017, 17:55:21 by ander »
Offline 0100010
  • Not Sure
« Reply #5 on: Thu, 21 September 2017, 08:25:44 »
If you just wanted WW keys, I think I have two sets of them.  (I should probably go through all my stuff that is collecting dust and unload it, since I am not using.)
Offline Thereminz
« Reply #6 on: Thu, 21 September 2017, 11:04:40 »
Nice, i made a keyboard out of a wheelwriter 3
Layers are fine, do wish it had dedicated arrow keys but it's cool, just put it on wasd in the other layer
Shame to wate those buckling springs though
« Reply #7 on: Thu, 21 September 2017, 16:15:09 »
I used a set of those on my faux-steampunk F-122. That "Code" key is particularly desirable if you can make a place for it.
- Plato
Offline ander
« Reply #8 on: Thu, 21 September 2017, 17:58:54 »
Nice, i made a keyboard out of a wheelwriter 3... Layers are fine, do wish it had dedicated arrow keys but it's cool, just put it on wasd in the other layer...
I don't want to argue with you, but I have too much typing to do to suddenly start having to use key combinations for things like moving a cursor.  :?P
Shame to [waste] those buckling springs though
I'm not wasting them—I'm offering the board to anyone who can use it. If I don't get a response from this, I'll post it in Free Stuff.
Nice—and yes, very steampunk! I definitely appreciate such creativity, but I also have to be realistic about what I would and wouldn't be able to use.
« Reply #9 on: Sat, 23 September 2017, 21:38:31 »
I was thinking about making another split spacebar model M
https://geekhack.org/index.php?topic=89656.msg2427579#msg2427579
Can always use more of the wheelwriter spacebar and "code" key for that.
