Author Topic: 25% 16MM Stenward - First Potato Pics  (Read 2288 times)
Offline Tiramisuu
« on: Tue, 26 September 2017, 15:45:00 »
Fullsize, 60% and 30% to provide a sense of how small this will be.
This is going to be about the smallest practical mechanical stenoboard I can build.
Prototype PCB's arrived from China today. Woo hoo! Almost had a fit when I noticed there were no screw holes.... But then remembered that I have steel top places being made. Phew.
Going to start with:
15cN at 2MM activation springs (I may cut them down further but I am hoping for about 12cN at 1.1MM) in Kailh Speed Silvers ( 1.1MM activation and 4mm Travel) PCB by EasyEDA
Steel Plates from the Woodkeys group buy
Key Caps will be G20's dremelled down to fit the 16MM spacing.
Still noodling on the case. I will likely start with something simple and acrylic but I am extremely tempted to CNC some aluminum bar stock and anodize it for a nicer result.
.... Was pricing out Desktop CNC machines last night.   Around $1.5k all in by the time it is all pieced together (Openbuilds C-Beam and 800w spindle kind of thing).
« Last Edit: Tue, 26 September 2017, 15:47:14 by Tiramisuu »
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline Tiramisuu
Re: 25% 16MM Stenward - First Potato Pics
« Reply #1 on: Tue, 26 September 2017, 22:41:58 »
... realized I needed a couple of thousand 1n4148's.   Get to wait for another order from China.
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #2 on: Wed, 27 September 2017, 00:19:35 »
You should use D9K diodes :P
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline Tiramisuu
« Reply #3 on: Wed, 27 September 2017, 14:43:44 »
Umm .. yeah no.
