Author Topic: [IC] Prime_M - Prototype delivered!! (updated 2/7/2018)  (Read 17963 times)
Offline holtenc
« on: Sat, 30 September 2017, 11:56:21 »
Features:
  • CNC aluminum case with integrated thick switch plate
  • Brass bottom cover for the extra weight
  • A full kit that includes fully assembled PCB - ATMEGA32u2
  • High profile sides to cover gap between plate and bottom of caps
  • Support for aluminum feet
  • In-switch back lighting
  • Flexible layout on bottom row and right-most column
  • Standard backlight support
  • Weighs 1.25lbs fully assembled
Kit will include the following:
  • Aluminum Case & Brass Bottom
  • PCB
  • 3x Cherry PCB mount Stabilizers
  • 10x Stainless steel scews
  • 6x Rubber bump-on pads
Updated 2/7/2018
Just a quick update. Unfortunately in order to keep overall costs/kit down to a reasonable level I've decided to limit the color choices to black, silver and blue. The particular anodizing provider only offers those 3 colors as "standard". Any other colors comes with a substantial price increase. All that being said, I don't think there is much of a reason to do a group buy / pre-order sort of thing.
For anyone that is interested in black, silver or blue, you will be able to purchase those kits from my site in around a 1-2 months. I haven't yet ordered the PCBs so I can't give an exact price. But I can guarantee that it will be below $150/kit. Hopefully around $130.
Sorry if this is disappointing to anyone that was looking forward to other colors. I'm pretty disappointed myself. Any future projects I do (prime_O will be next) will be done differently to provide more color choices.
Updated 1/26/2018
Big update. I finally got my hands on the prototype. I'm extremely pleased with the way it came out. I hope you guys are as well.
Don't worry. This is the prototype PCB. Those wires won't be there in the production version  :))  Made an amateur mistake in the routing.
Where the case and brass come together around the USB port came out to fit really nicely
Machining marks left intact. I dig it.
Game Pad Layout
Numpad Layout
SOME OF THE POTENTIAL LAYOUTS
Out dated design pics:
Front
Back w/ brass bottom
Back with PCB
Bottom Veiw (T H I C C)
Woodkeys_click made a great suggestion of making the switch plate area extra thick for the additional weight.
FRONT
BACK
To-Do:
- Add counter sunk holes in brass plate for aluminum feet
- Pricing
- Fix USB cutout in case. (too small)
- Find acceptable screws and adjust models accordingly (screws are hard  :(  )
- Work on PCB mount stabilizer cutouts on case.
- Prototype PCB
- Prototype Switch Plate
- Prototype aluminum case / brass back.
« Last Edit: Wed, 07 February 2018, 21:21:30 by holtenc »
Offline holtenc
Re: [IC] Prime_M - Macro Pad / Game Pad / Num Pad - Aluminum/Brass
« Reply #1 on: Sat, 30 September 2017, 11:57:55 »
reserved
Offline aspenc4
« Reply #2 on: Sat, 30 September 2017, 12:52:11 »
Love the idea; if this matches your primekb you can have my money now.
Offline holtenc
« Reply #3 on: Sat, 30 September 2017, 13:19:40 »
Nice! It will be about the same quality, as the same machine shop will be doing the CNC/Laser. A few differences such as rounded tops instead of chamfered etc.
Offline aspenc4
« Reply #4 on: Sat, 30 September 2017, 13:33:28 »
Sweet. Minor differences certainly aren’t a deal breaker for me
Offline olieatstofu
« Reply #5 on: Sat, 30 September 2017, 13:44:33 »
Love this more than the cospad,
Cant wait for this to unravel, I will certainly be kn!
Offline holtenc
« Reply #6 on: Sat, 30 September 2017, 14:17:12 »
Really whatever the majority wants. Rounded or chamfered makes no difference to me. Seemed there were a handful of people that did t care for the chamfered top of the Prime Keyboard
« Last Edit: Sat, 30 September 2017, 14:57:41 by holtenc »
Offline moshjaines
« Reply #7 on: Sat, 30 September 2017, 16:45:26 »
really excited about this! looks rad  :thumb:
Offline aspenc4
« Reply #8 on: Sat, 30 September 2017, 17:22:04 »
Ah, gotcha. If it were up to me I’d prefer to have a consistent aesthetic between the primekb and the m, but I can understand going with the majority on this as well.
Either way I’m in - do what’s best for the community and you can’t go wrong.
Offline Dominathan
  • Too many keyboards? Not enough hands.
« Reply #9 on: Sat, 30 September 2017, 19:36:39 »
Yes please! I'd love to make this a dedicated gaming pad!!
Sent from my iPhone using Tapatalk Pro
Offline thekiddzac
  • Lurker Extraordinaire
« Reply #10 on: Sun, 01 October 2017, 20:35:07 »
This is exactly what I need so I can use 40% comfortably! I'd be in.
Sent from my SM-G950U using Tapatalk
Leopold FC660C
Offline holtenc
« Reply #11 on: Sun, 01 October 2017, 23:38:33 »
Nice!
Offline holtenc
Re: [IC] Prime_M - Num/Macro/Game Pad - Aluminum/Brass (NEW DESIGN RENDERS)
« Reply #12 on: Mon, 02 October 2017, 11:13:38 »
Made some pretty big changes to the case and added updated renders. Woodkeys_click made a great suggestion. Due to the switch plate being integrated into the case, it's possible to make the switch plate area extra thick for added weight and rigidity.
I've started a conversation with the manufacturer about the case. If what I've posted here is feasible I'll get them working on an estimate. The more I iterate on this, the more I like it.
Offline aspenc4
« Reply #13 on: Mon, 02 October 2017, 22:07:40 »
New renders look great!
Offline holtenc
« Reply #14 on: Mon, 02 October 2017, 22:42:06 »
Thanks man
Offline Peiweisgreat
« Reply #15 on: Wed, 04 October 2017, 21:37:40 »
O wow we are getting brass plates on this bad boy now? Not sure if I need those, but a welcome addition nonetheless.
Offline holtenc
« Reply #16 on: Wed, 04 October 2017, 21:45:30 »
That's the plan. Just have to see what kind of cost the manufacturer comes up with. I would REALLY like to target $100 for the kit but honestly I have no idea.
Offline justspeechless
« Reply #17 on: Sun, 08 October 2017, 11:51:30 »
Is it possible to do a floating key layout instead of the high profile?
[CM QFR]
Offline holtenc
« Reply #18 on: Sun, 08 October 2017, 11:54:04 »
While it would be cheaper, not this time around. Perhaps if I get to do another one I'll make it floating. Keys.
« Reply #19 on: Sun, 08 October 2017, 15:10:21 »
No prob. What would be a rough estimate for when this could go live?
[CM QFR]
Offline holtenc
« Reply #20 on: Sun, 08 October 2017, 15:21:28 »
Couple three months. Not really sure. Lots of prototyping to do. Currently implementing a switch from USB mini to C.
« Last Edit: Wed, 24 January 2018, 20:39:33 by holtenc »
Offline holtenc
Re: [IC] Prime_M - Prototype delivered!! (updated 1/26/2018)
« Reply #21 on: Fri, 26 January 2018, 12:21:43 »
Updated with prototype pictures and more info.
Offline aspenc4
« Reply #22 on: Fri, 26 January 2018, 13:33:31 »
This is gonna be a slick build; definitely keeping an eye on it!!!
Offline olieatstofu
« Reply #23 on: Fri, 26 January 2018, 14:39:27 »
Yes, what an update! Glad to have waited for this.
Offline lordgiblite
« Reply #24 on: Fri, 26 January 2018, 17:20:34 »
Love it! Basically the numpad/macropad I've always wanted, just with stuff I didn't know I wanted!!!
Offline Sharklegs
« Reply #25 on: Fri, 26 January 2018, 23:11:41 »
Need so bad. Love the example gaming layout as I've been wanting to do this for a while. Was considering the cospad but this looks more like what I'd like.
Offline holtenc
« Reply #26 on: Sat, 27 January 2018, 10:25:05 »
« Reply #27 on: Sat, 27 January 2018, 13:10:17 »
Not something I'd buy, but I like the finish on the bottom of the prototype.
Offline anhthao88
« Reply #28 on: Sun, 28 January 2018, 12:23:44 »
Nice design and interesting customizable layouts. I'm in for one.
Offline holtenc
« Reply #29 on: Sun, 28 January 2018, 12:25:53 »
Great. As soon as I get final pricing I'll post over in the GB forum
Offline lordgiblite
« Reply #30 on: Sun, 28 January 2018, 12:54:43 »
Excited :)
Offline holtenc
Re: [IC] Prime_M - Prototype delivered!! (updated 2/7/2018)
« Reply #31 on: Wed, 07 February 2018, 21:21:43 »
update in OP
Offline lordgiblite
« Reply #32 on: Mon, 12 February 2018, 10:00:27 »
Thanks for the update! It is sad that you won't be able to do as many colors as you wanted but I'm just happy that this is still happening :) Can't wait that month or so for these bad boys to come up on your site!
Offline holtenc
« Reply #33 on: Mon, 12 February 2018, 10:15:33 »
♥️. And now China is shut down until Feb 23 for holiday lol. So hopefully I'll have everything ready by the end of March.
Offline lordgiblite
« Reply #34 on: Mon, 12 February 2018, 10:21:36 »
I have to wait a little before purchasing anything else so that's fine with me :) having a macropad I'll actually use everyday will be nice lol
Sent from my SM-J320P using Tapatalk
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #35 on: Thu, 15 February 2018, 01:12:42 »
Looking forward to this!
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline CallMeCam
« Reply #36 on: Tue, 20 February 2018, 03:28:48 »
Looks incredible, definitely interested
Offline holtenc
« Reply #37 on: Tue, 20 February 2018, 06:46:35 »
Great! I should be placing the PCB order in the next day or two.
Offline Data
« Reply #38 on: Tue, 20 February 2018, 09:29:06 »
This is cool.  Prototype looks great.
Offline FailureToLoad
« Reply #39 on: Wed, 21 February 2018, 07:18:34 »
This is pretty much what I wanted instead of a Gherkin. Thank you for forging ahead with this project!
