Author Topic: Looking For A Cheap RGB Gaming Keyboard pls Help  (Read 3552 times)
Offline geronimoste
« on: Tue, 10 October 2017, 14:38:53 »
Hey
im looking for help to choose a good keyboard with rgb for gaming (better if mechanical)
i have more or less 75-50 euros
hope somebody help me
ty
« Last Edit: Wed, 18 October 2017, 19:46:26 by HoffmanMyster »
Offline Denisgsv
Re: LOOKING FOR A CHEAP RGB GAMING KEYBORAD PLS HELP
« Reply #1 on: Wed, 11 October 2017, 01:50:11 »
probably a coolermaster, or a logitech, duno about rgb tho...
You can say anything about mk, but not that its cheap  :-X
Offline typo
« Reply #2 on: Wed, 11 October 2017, 23:22:06 »
I think a great suggestion is the Razer Ornata Chroma. It is not really mechanical but neither is Topre. So there you go. Razer is generally my last recommendation but this is interesting. You are going to fall into a cycle costing you more money. A sub $200USD board usually does not last. So you keep buying $80USD keyboards and after 3 boards you are at the $200 because they fail. The Ornata might fair better exactly because it is not mechanical. Logitech is nice too if you must have actual mechanical.
Offline Duckyreddy
  • Better skadoodle, poodle.
« Reply #3 on: Wed, 11 October 2017, 23:46:08 »
Aha, I do agree with Typo in some aspects, A quality board is a good investment and will last you a lifetime if you take care of it while if you do in fact go for cheaper budget boards, they are known to have more build quality issues and in my case with the budget boards I've tried, a less satisfying experience.  :thumb:
If you can, save more and do some research and see what you like for the meantime then when you do have enough money, you know what to buy!
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
Offline rm-rf
« Reply #4 on: Thu, 12 October 2017, 00:50:51 »
i think you will find that most rgb gaming keyboards are.. "cheap"
Offline Prothrin
« Reply #5 on: Thu, 12 October 2017, 03:46:41 »
Depends if you really need full RGB, but there are plenty of low-cost options that feature "rainbow" LED backlighting on Amazon, from Aukey and other brands, if you want to keep costs down.
Offline typo
« Reply #6 on: Thu, 12 October 2017, 17:24:49 »
The Topre is cheap? Plus some Koreans.
Offline Jokuhemmo
« Reply #7 on: Fri, 13 October 2017, 00:18:10 »
Obins Anne pro
Rantopad mxx chroma
Drevo calibur rgb
Offline jackalopephoto
« Reply #8 on: Sat, 14 October 2017, 16:37:21 »
Why RGB??
Offline Denisgsv
« Reply #9 on: Sun, 15 October 2017, 05:01:51 »
Why RGB??
well cos he wrote it in the title : cheap RGB keyboard
Offline Leslieann
« Reply #10 on: Sun, 15 October 2017, 05:42:23 »
I disagree with the others.
OP doesn't know what they want, so go cheap until you find the switch you want, then spend the money on a nice board.
Buy the cheapest RGB(?) mechanical you can with a switch that sounds like what you might like (I would recommend starting with browns if you are unsure).
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline nadeemdoesgaming
« Reply #11 on: Sun, 15 October 2017, 08:34:17 »
Anne Pro is a great option  :thumb:. You should take a look at it.
Offline LoveYouFyi
« Reply #12 on: Mon, 16 October 2017, 11:30:21 »
Get a Corsair board.  You should be able to pick one up for close to 75.  They've the best quality for the best price.
Offline iLLucionist
  • Topre is Love.
« Reply #13 on: Mon, 16 October 2017, 14:21:15 »
Corsair, good quality / price balance. As a matter of fact, you can even get one of those mx speed with rgb!
