Author Topic: GMK SNES  (Read 232010 times)
Offline FoC_Tow
  • Brokehlicious
Re: GMK SNES
« Reply #100 on: Thu, 09 November 2017, 03:36:23 »
but the buttons on the original controllers were purple...
As already stated, only the us version was purple.
Intellis set was designed to capture the asthetics of both, US and Jpn/Eu Versions.
Offline kconfire
Re: GMK SNES
« Reply #101 on: Fri, 10 November 2017, 08:24:04 »
I had the Super Famicom when I was a kid in Korea and it had colorful buttons.
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
Offline BAS1C
Re: GMK SNES
« Reply #102 on: Fri, 10 November 2017, 09:47:14 »
I meant the hhkb style arrows and matching dpad wasz from the og snes set.
Going wasd looks cheap to me and feels like a bad compromise at best imo.
Also while the original render may have been incorrect, white is definitely too bright for an snes set, snes should definitely be gray on gray.
Tbh I think it would be best to either stick to Intellis design, or (maybe even bette)  start fresh with a new design based on the jp/pal snes like many suggested.
I don’t think anyone would mind a fresh take on the real deal reminecant of intellis set rather then a rough copy.
Just my two cents.
This is my favourite. If the mods only come with rgby legends, no dice for me.
Love the WASZ and HHKB Arrows, i think going WASD on this set is a bad idea.
Offline rawrjau
  • Stop making nice things so I can stop spending
Re: GMK SNES
« Reply #103 on: Fri, 10 November 2017, 22:12:17 »
So the greys and purple are based off of the SNES colors. Those colors are the ones that are inaccurate in the following picture:
https://imgur.com/KyzZ3S3
I'll work with thesis to have a better idea of the actual colors.
 I think the initial attraction of the set is because of a distinct set of features that have been removed, and from this render, my definitely in turned into ehh. Maybe.
A few things that would put me into instabuy...
1. Get rid of the plain jane ESC - Pause Row (R1) to reduce key count... don't think anyone would actually use them.
2. Bring Back WASZ in the dark grey.
3. Bring Back the [;/' Cluster in RGBY (Key colour, legends to be light grey)
Other considerations...
4. The RGBY arrows are okay to stay, but won't care if they disappeared as well.
5. Power/Reset on Enter/Backspace
But whatever happens, I do hope this thing goes through with consideration to everyone's input
Offline Qu4troQu4tro
Re: GMK SNES
« Reply #104 on: Sun, 12 November 2017, 12:25:24 »
I completely agree with rawrjau
Offline AlexG
Re: GMK SNES
« Reply #105 on: Sun, 12 November 2017, 14:46:57 »
I do as well. Doesn't make sense using only a fraction of the original design. The original design is what got everyone excited in the first place.
Offline spacegh0st
Re: GMK SNES
« Reply #106 on: Mon, 13 November 2017, 11:02:43 »
This sounds good to me...I especially like the Power/Reset idea.
Offline neralo
Re: GMK SNES
« Reply #107 on: Wed, 15 November 2017, 00:37:05 »
I'm a sucker for nostalgia, so I'll be keeping an eye on this set.
HHKB Pro 2 55g | TGR 910 55g Vintage Blacks | Apple Standard M0116 Orange Alps | Rosewill RK9000 Cherry MX Blues | Diverge TM 2 WKLears
Offline luxuryx
Re: GMK SNES
« Reply #108 on: Wed, 15 November 2017, 01:38:25 »
Group buys should be up this or next week.
When does GB begin?  ;)
Offline AlexG
Re: GMK SNES
« Reply #109 on: Tue, 28 November 2017, 14:33:57 »
Any updates?
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: GMK SNES
« Reply #110 on: Tue, 28 November 2017, 16:16:44 »
https://imgur.com/UvDkDyM
Do people still want the Dark Arrow clusters?
Offline roostrc0gburn
  • its just plastic
Re: GMK SNES
« Reply #111 on: Tue, 28 November 2017, 16:29:35 »
i am still interested in N9 WASZ cluster, like intelli's original layout, with legends either white or purple to match the rest of the alphas. not N9 arrow keys, please.
i would also be interested in a child/add-on kit like this:
but not the colored WASD keys, just the N9 mods.
Also, i would suggest removing the center-stem 6u spacebar and replace it with a 7u spacebar in purple. imo, center-stem is still an unproven technology, and basically only benefits people with mx modded hhkb. otherwise, i think you have a nice kit that will cover most popular layouts
edit. just for reference, here is the original -
« Last Edit: Tue, 28 November 2017, 16:49:38 by roostrc0gburn »
Re: GMK SNES
« Reply #112 on: Tue, 28 November 2017, 16:48:02 »
N9 WASZ and some sort of matching mod kit would be perfect, i think
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: GMK SNES
« Reply #113 on: Tue, 28 November 2017, 16:53:13 »
At this time, I don't think we can add the N9 mods, but we can definitely add the WASZ cluster.
« Last Edit: Tue, 28 November 2017, 16:57:46 by sherryton »
  • its just plastic
Re: GMK SNES
« Reply #114 on: Tue, 28 November 2017, 16:55:02 »
At this time, I don't think we can add the N9 mods, but we can definitely add the WASD cluster.
WASZ
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: GMK SNES
« Reply #115 on: Tue, 28 November 2017, 16:56:33 »
WASZ
My bad, WASZ lol. Edited
  • its just plastic
Re: GMK SNES
« Reply #116 on: Tue, 28 November 2017, 17:14:54 »
WASZ
:D sounds great! hope you consider adding a purple 7u spacebar. i doubt you will find more than ~5 people who need that center-stem.
might also be worthwhile to take a poll or something on the N9 mods i showed above. i think they could be run as a child kit with its own MOQ. those keys would be very versatile and could be used with any dolch variant keyset. just a thought
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: GMK SNES
« Reply #117 on: Tue, 28 November 2017, 17:29:07 »
WASZ
Child Kit will work.
Offline nightdriver
  • life is like t. rex
Re: GMK SNES
« Reply #118 on: Wed, 29 November 2017, 03:20:27 »
i'm still hoping for a darker gray on the alphas.  there was nothing on the super nintendo that close to white.
Offline sherryton
  • * Moderator
  • Kībōdo
    • Originative
Re: GMK SNES
« Reply #119 on: Wed, 29 November 2017, 17:18:48 »
We are still working on toxic and a few gmk sets group buy as well as the EXENT. When these are all done, we will get started on the SNES set.
Offline AlexG
Re: GMK SNES
« Reply #120 on: Wed, 29 November 2017, 20:44:39 »
What is the n9? Is that the HHKB arrows? in RGBY?
  • its just plastic
Re: GMK SNES
« Reply #121 on: Wed, 29 November 2017, 21:12:17 »
N9 is the GMK color code for dark grey that is used for dolch mods and is also a very common color for legends.
Offline AlexG
Re: GMK SNES
« Reply #122 on: Wed, 29 November 2017, 21:34:08 »
ooooooooooooh
Offline a_ak57
Re: GMK SNES
« Reply #123 on: Thu, 30 November 2017, 14:47:14 »
Reworked kit with the inclusion of N9 WASZ is good, glad to see feedback taken into account.  While it'd be nice to have more options like dark mods and extra spacebars, can't really fault Oco for not wanting to get too ambitious with a set that failed MOQ before.
Offline nightdriver
Re: GMK SNES
« Reply #124 on: Thu, 30 November 2017, 16:44:19 »
that was a couple of years ago. we've got way more people in the hobby now.
Offline a_ak57
Re: GMK SNES
« Reply #125 on: Thu, 30 November 2017, 18:20:36 »
Yeah, but there are also a lot more sets being run these days. Look at the struggles GMK Necro and Eclipse, sets that would have been fine a year or two ago.  Even massdrop has its own SP-style queue forming.
Offline HandiHanyut
  • pika, pikaaa doet
Re: GMK SNES
« Reply #126 on: Mon, 04 December 2017, 01:15:56 »
can't wait !  ;D
« Last Edit: Mon, 04 December 2017, 22:12:10 by HandiHanyut »
Soon™ |TGR Jane V2CE | TX75 | Realforce RGB | KBDLite67 | Elis Acrylic Keyboard | UTD360C
Offline tristinDLC
Re: GMK SNES
« Reply #127 on: Wed, 06 December 2017, 05:59:10 »
Just need final color and key choices decided (even if included as add-ons), before I 100% commit. I have a huge SNES/SFC (and NES/FC... and really anything custom old school Nintendo, but SNES is my favorite) before I fully commit. The original colorway was great, but they were also some interesting in member suggestions after this project came back into the light. Some were better than others, and while I know progress is nice, you can't please everyone with the number of people involved and the number of keys included/needing to be included to cover everyone's needs.
Just hope a nice middle ground can be reached, so we can start an official GB thread to see if MOQ is hit this time. I have some additional accessories I would be adding to a SNES/SFC keyset, so hopefully, this gets products for sure this time as well as in the problem colors to match the additional mods I plan for my completed project.
Regardless, hopefully, this set gets the official GB greenlight, so we can start placing orders.
Offline livingspeedbump
    • KeyChatter
Re: GMK SNES
« Reply #128 on: Thu, 07 December 2017, 07:50:53 »
In some ways I think the multitudes of sets running are good for the community so people can get exactly what they want, but it does make it a challenge for designers to get sets to reach the higher numbers of sales just because of all the options out there, so sets really need to be much closer to perfect these days.
That being said, I do think this is a great set, both on its own for how well it will play with other sets. There are some really stellar mix-n-match opportunities to be had with this set and other GMK sets.
<- My Collection (so far)
Offline BAS1C
Re: GMK SNES
« Reply #129 on: Mon, 18 December 2017, 00:54:08 »
So are the modifiers going to be RGBY like this pic?
  • its just plastic
Re: GMK SNES
« Reply #130 on: Mon, 18 December 2017, 01:48:45 »
probably. they have been since day 1, but imo they could be purple or even black and the set would still be dope. the purple and N9 and other accents really make the set - rgby legends kinda make it look busy...
Offline FoC_Tow
  • Brokehlicious
Re: GMK SNES
« Reply #131 on: Mon, 18 December 2017, 09:03:26 »
I personally prefer uniform mod legends aswell, rather then rgby legends.
Dark gray wasz and rgby hhkb arrows is a must for this set tho!
Offline BAS1C
Re: GMK SNES
« Reply #132 on: Mon, 18 December 2017, 14:03:32 »
Yeah, i really don't like the RGBY legends on the mods, too busy. Will be out if they stay like that unfortunately. :(
Offline Asbrodeus
Re: GMK SNES
« Reply #133 on: Wed, 20 December 2017, 09:59:50 »
I'm still worried about the alpha base being too light. I don't need another shade of white and purple set.
Offline nightdriver
Re: GMK SNES
« Reply #134 on: Wed, 20 December 2017, 13:19:59 »
yeah i've already got hyperfuse.  if i get the set and it looks like that, up to the classifieds it goes!
Offline a_ak57
Re: GMK SNES
« Reply #135 on: Wed, 20 December 2017, 18:54:46 »
I wouldn't worry about the colors; unless I missed something the only pics in this thread have been GMK renders which are notorious for being inaccurate, and someone mentioned that GMK received SNES samples to match for the original GB attempt.
Offline xondat
  • i'm not a star
Re: GMK SNES
« Reply #136 on: Wed, 21 February 2018, 23:02:24 »
Any update? Really disappointing this has gone on for so long without the buy starting.
Re: GMK SNES
« Reply #137 on: Thu, 22 February 2018, 15:23:21 »
i think sherry is focused on getting type machina up and running right now, so it'll be a bit
haven't talked to him in a week or two though, so things may have changed
Offline Asbrodeus
Re: GMK SNES
« Reply #138 on: Tue, 27 March 2018, 13:02:01 »
https://originative.co/snes-co
new website render is waaaay too light.
Offline AlexG
Re: GMK SNES
« Reply #139 on: Tue, 27 March 2018, 16:25:17 »
Yeah, saw that few weeks ago. It looks like **** and the mods look awful as well. Looks nothing like the original renders. Wouldn't waste money on that.
  • its just plastic
Re: GMK SNES
« Reply #140 on: Tue, 27 March 2018, 16:39:13 »
idk how old that post is on the website, but i thought i saw sherry say that rygb mod legends were abandoned for RYGB cluster
Offline AlexG
Re: GMK SNES
« Reply #141 on: Tue, 27 March 2018, 17:18:05 »
Really really really hope so. That makes this set from meh to amazing.
Offline Vigrith
Re: GMK SNES
« Reply #142 on: Thu, 29 March 2018, 07:39:08 »
Might just be me but the new render seems pretty well colour matched to the console. I think it'd sell well, too. I like it.
  • its just plastic
Re: GMK SNES
« Reply #143 on: Tue, 08 May 2018, 11:51:14 »
sherry plz tell me this year. while violet tendencies and royal are running, i think it is probably a good idea to hold off on another purple set for now...
but if you plan on stocking these, why not run it in Q3 this year?
Offline pr0ximity
Re: GMK SNES
« Reply #144 on: Tue, 08 May 2018, 21:11:50 »
More purple can't hurt  :cool:
Re: GMK SNES
« Reply #145 on: Tue, 08 May 2018, 21:38:34 »
But a lot can kill you.
Offline mypainishurt
Re: GMK SNES
« Reply #146 on: Thu, 07 June 2018, 20:12:56 »
Did we lose traction on this?
Offline AlexG
Re: GMK SNES
« Reply #147 on: Sat, 09 June 2018, 08:13:26 »
Last I heard was it's going to be ran after they run the Originative set. Not sure if this got sidelined by Necro. Haven't had any update in a while.
Re: GMK SNES
« Reply #148 on: Sat, 09 June 2018, 22:24:17 »
Pls can I get a GMK SNES for the love of god this is the only set I’ve ever wanted bad enough to enter into a group buy
Re: GMK SNES
« Reply #149 on: Sun, 10 June 2018, 00:31:19 »
