Author Topic: Anne Pro Owners - I need you!  (Read 4627 times)
Offline C4PPY
« on: Fri, 13 October 2017, 00:54:57 »
Hi All!
I am deeply in love the 60% and the Anne PRO would be the next purchase for me (i think).
But seeing that Gateron Red is the only linear switch in the lineup.
Would I be able to replace the springs with some heavier springs without soldering?
Offline clickityClackity
Re: Anne Pro Owners - I need you!
« Reply #1 on: Fri, 13 October 2017, 03:23:21 »
Yes, you can do it the dirty way... Wouldn't recommend, but it works just fine.
Offline C4PPY
« Reply #2 on: Fri, 13 October 2017, 03:47:48 »
Cool - thanks mate.
Why wouldn't you recommend it? enlighten a rookie.
« Reply #3 on: Fri, 13 October 2017, 03:53:30 »
Well, it's not hard to do, but at the same time it's easy enough to **** up. Some switches are easier than others as well... But really the worse case scenario is that you scratch the backplate or crack a switch case. You could potentially crack a plastic backplate but you'd have to really be going at it! If those aren't a big deal for your situation, give it a go!
Offline C4PPY
« Reply #4 on: Fri, 13 October 2017, 03:55:15 »
Roger that, think I will give it a go :-)
Many many thanks.
« Reply #5 on: Fri, 13 October 2017, 04:37:47 »
No problem and good luck! One quick note: be careful when  putting the top back on. It's generally easy as well, but if one of the legs bends it becomes somewhat of a pain.
Offline sony
  • Formerly ultraidiot
« Reply #6 on: Sat, 14 October 2017, 08:46:10 »
Don't do that. Those photos show a board that has a plate that supports switch top opening. The Anne pro does not. Doing this to your Anne pro could damage the switches. To change the springs you would have to desolder the switches.
Sent from my ONEPLUS A3000 using Tapatalk
« Reply #7 on: Sun, 15 October 2017, 00:11:48 »
Ah crap... For some reason I thought the Anne Pro was as well, but didn't check like a dumb***. My apologies C4PPY!!!
Offline C4PPY
« Reply #8 on: Tue, 17 October 2017, 05:27:38 »
@Ultraidiot - Thanks for the headsup
@clickityClackity - No worries mate.
