Author Topic: Looking for a fullsize ISO Board with flat case.  (Read 1347 times)
Offline Flowshi
« on: Sat, 14 October 2017, 10:15:33 »
So, it's hard to describe what I want: most TKL boards come with a flat case, where you can see the switches if you look from the side and most fullsizes boards come with a thinker case, so you don't see the switches.
I'm looking for a black or gray fullsize ISO board with a flat case. It's for my secondary workplace with customer traffic so it needs to be regular looking board (no fancy gaming stuff). Switch-wise I prefer mx-clear, but would also go for blacks or reds. Keycaps dont matter cause I got some double shots spare, but it needs to be standard layout.
Any suggestions?
Here is a link to the Varmilo Sakura where you can see the difference between TKL and fullsize board.
Offline TalkingTree
    • My projects
Re: Looking for a fullsize ISO Board with flat case.
« Reply #1 on: Sun, 15 October 2017, 07:39:11 »
Such keyboards are commonly referred as suspended keys or floating keys. There are several low cost models that you can easily buy from Amazon, such as this Aukey's.
