Author Topic: Is this ErgoDox infinity?  (Read 2119 times)
Offline FinancialWar
« on: Sat, 21 October 2017, 09:29:00 »
https://www.ebay.com.au/itm/Ergodox-Infinity-Keyboard-Cherry-MX-Clear-Aluminium-Assembled/322838306581?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2748.l2649
I bought this ergodox, the title says infinity, but I couldn't tell if it has a LCD since the top plate is not transparent. So from under the Ergodox, can you tell if it a infinity or normal Ergodox?
Re: Is this ErgoDox infinity?
« Reply #1 on: Sat, 21 October 2017, 09:49:08 »
I think you should have asked the question before buying.
Offline robotsokk
« Reply #2 on: Sat, 21 October 2017, 10:47:49 »
From the picture of the underside, it looks like an original (i.e. non-Infinity) Ergodox. See this PCB:
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=537
« Last Edit: Sat, 21 October 2017, 10:49:51 by robotsokk »
@home      @work Swapping out boards... coming soon     wtb
Offline robotsokk
« Reply #3 on: Sat, 21 October 2017, 10:49:33 »
[Removed unintentional dupe post.]
Offline ojrask
  • juuh elikkäs
« Reply #4 on: Sat, 21 October 2017, 11:29:42 »
The PCB does not look like Infinity, seemingly the MCUs are where the LCDs should be and the USB connectors are too far apart.
Current:
Coming up:
IC/GB:
Offline _rubik
« Reply #5 on: Mon, 23 October 2017, 10:31:44 »
You sir bought yourself an original, non-Infinity, dox. Maybe open a case against the seller and get your money back?
