Author Topic: [GB COMPLETE] SaiB - CP  (Read 182717 times)
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [GB COMPLETE] SaiB - CP
« Reply #500 on: Sun, 17 February 2019, 02:49:34 »
Hi everyone, I'm not sure if this would still help, but I want to point out the fact that the runner's uploaded drawing of the bottom plate is incorrect in the four corners. I was able to ask a friend of mine of modify the drawing so that it would fit in the cutout on the bottom, and you can download it below.
Please note that the thickness of the plate is 3mm, and while it was the best my friend could do off of the original drawing, it's still not a 100% fit. I had to shave off 2 corners of the plate a bit further, but the result was more than ok, at least better than having an empty space.
Cool observation. Much appreciated that you've decide to share the finding and the file. Do you have pics of what this ended up looking like?
Offline flying1911
    • Mechlovin' Studio
« Reply #501 on: Sun, 17 February 2019, 03:20:38 »
For sure:
I've only tried it with black mica, which cost like $2 for the piece and it looks pretty good. Will definitely come to a more permanent solution such as stainless steel in the future.
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #502 on: Sun, 17 February 2019, 03:25:55 »
For sure:
Wow, very neat. If you manage to do it in metal, and you have to edit the file again (since you have to still shave off a few milimeters) would you mind sharing that again? I'd be interested in getting one done in steel as well.
Offline flying1911
    • Mechlovin' Studio
« Reply #503 on: Sun, 17 February 2019, 05:53:20 »
To be honest the amount of shaving was so minimal I intend to stop making further changes to the file, and there's a possibility it could get worse. I imagine the stainless steel piece will have to be polished to look good anyway, so you can make sure that it fits before having it done. Again, I only had to shave half a mm of material off 2 corners.
Good luck with your project, I'm sure it'll be worth it  :thumb: :thumb:
Offline forumusername
« Reply #504 on: Fri, 22 February 2019, 10:19:31 »
I've got a titan grey kit that I'd like to part with its unbuilt pm me if you are interested :thumb:
Offline yaya
« Reply #505 on: Tue, 05 March 2019, 11:52:19 »
Has anyone made any more progress on getting a weight made?
« Reply #506 on: Tue, 02 April 2019, 22:21:22 »
I either lost the screws that came with my kit or didn't get them... in either case can someone educate me on what screws I need for the kit please and thank you
Offline Vloshko
« Reply #507 on: Sun, 21 April 2019, 18:33:41 »
Just found out plate is too tight for 7u spacebar. Easy 30 second fix by filing right metal side of left stabilizer
« Last Edit: Sun, 21 April 2019, 19:10:14 by Vloshko »
Keycap Compendium
Discord: Vloshko#1327
Key Cap Wishlist
2019: Configure Optimal Audio Settings
HHKB Pro 2, Model M, Unicorn X Legend, ESPECTRO 96, SaiB CP, E8-V1.
Offline Vloshko
« Reply #508 on: Sun, 21 April 2019, 18:38:14 »
9/16" long
Strangely looks like 2/10 cm diameter
« Last Edit: Sun, 21 April 2019, 18:46:16 by Vloshko »
Keycap Compendium
Key Cap Wishlist
« Reply #509 on: Sun, 21 April 2019, 18:43:25 »
9/16" long
Thank you!
Offline Vloshko
« Reply #510 on: Wed, 24 April 2019, 21:34:30 »
Is there supposed to be a gasket for this for the leds?
Keycap Compendium
Key Cap Wishlist
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #511 on: Wed, 24 April 2019, 21:37:52 »
Not really. Mine has the LEDs on.
« Reply #512 on: Sun, 28 April 2019, 18:05:17 »
9/16" long
I am actually a little confused on what you are referring to any way you could link me or if anyone else could chime in I'd greatly appreciate it!
Offline yaya
« Reply #513 on: Mon, 29 April 2019, 07:34:36 »
Pretty sure they are twelve M3 x 15mm countersunk allen screws
« Last Edit: Mon, 29 April 2019, 07:37:00 by yaya »
Offline Carlobv
« Reply #514 on: Thu, 09 May 2019, 09:20:48 »
Hey guys, troubleshooting question if anyone can help:
I spilled some beer on my board last night.  I disconnected from the computer and cleaned it.  It didn't seem too bad.
Nothing worked on reconnect, but I loaded new firmware and was able to connect.  Everything is working fine until I disconnect from usb.  When I reconnect, I hear the "something is connecting via usb sound," but the board doesn't work until I flash the firmware again.
Any ideas?
Offline dubious
  • 쏘쿨
« Reply #515 on: Thu, 09 May 2019, 18:31:08 »
Any ideas?
Something is probably fried if it wont hold firmware, but it's possible something is being shorted. How long did you wait until you plugged it back in, and did you do anything besides just wipe up the beer? (Like put the pcb/plate/switches in rice, or silica or wtvr)
« Reply #516 on: Thu, 09 May 2019, 18:42:43 »
Any ideas?
sounds like something the controller fried or is shorting
might be worth going over those contacts with a bit of iso alcohol and seeing if that helps
but if it doesn't hold firmware it's probably screwed
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
« Reply #517 on: Thu, 20 June 2019, 00:54:05 »
WOW -
I read this by chance.
I'm surprised that communication happen yet.
Thank you very much for your interest. !!!
If you have any questions, please tell me in the comments.
I'll answer as much as I can.
During the production of SAB-CP,
In order not to reproduce the hard work that had to be done unintentionally,
I'm developing our own PCB (with QMK).
221453-0
SaiB-CP Black - Kailh Bronze (Non Click / 58g) - Finish
Light Saver v1 Black - Cherry Wyze Black (Linear / 64g)
Light Saver v2 Gray - Cherry 1501 Black (Linear / 64g)
Light Saver v3 Silver - Cherry 8200 White (Non Click / 64g)
Light Saver Acryl (Duck96 base) - Gateron Yellow (Linear / 62g) - Season 1 Fin.
Octagon v1 Black - Cherry 1501 Black (Linear / 64g) / TX-1800 v1 Red/Black - Cherry Wyze Black (Linear / 58g)
VE.A Test Housing- Cherry 8113 White (Non Click / 58g)
TC-V3 , LZ*ASRH Black, VE.A 2nd
... etc.
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
« Reply #518 on: Thu, 20 June 2019, 00:56:42 »
WOW -
I'm developing our own 3 types PCB (with QMK).
80%
60%
OTD replica
(http://kbdlab.co.kr/index.php?mid=board_Lsno50&document_srl=5822124)
... etc.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #519 on: Thu, 20 June 2019, 02:52:04 »
WOW -
80%
60%
OTD replica
This looks promising and exciting. Now, where to find an OTD so I can use that latter PCB....
Offline poolside
« Reply #520 on: Thu, 20 June 2019, 17:28:33 »
> 2018-09-28 Update.
    SaiB - CP's Bottom weight plate Document Open !
    You can edit it, as long as you specify the source (SaiB - CP).
Hey PainMaster, could you please release a fixed weight plate file? Did you have weight plates made for your personal SaiB-CPs?
The plate corner radius in your original file seems to be incorrect. It is about 5.5mm whereas the actual bottom piece weight plate cutout has corner radiuses closer to 10mm.
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
« Reply #521 on: Fri, 21 June 2019, 00:24:18 »
> 2018-09-28 Update.
I'll check this. :)
... etc.
Offline PainMaster
  • Formerly cjakma
  • IBM(PainMaster)
« Reply #522 on: Mon, 24 June 2019, 20:55:39 »
> 2018-09-28 Update.
It looks like it's going to be tight.
The figures on the drawing are correct.
put up the 0.5mm cut drawings.
* CP_190625_BOTTOM PLATE.zip (36 kB - downloaded 164 times.)
... etc.
Offline poolside
« Reply #523 on: Thu, 27 June 2019, 06:34:38 »
Thanks for taking the time to review the plate file.
If corner radiuses don't match, the weight plate won't fit into the bottom piece cutout (?).
221821-0
221823-1
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #524 on: Thu, 25 July 2019, 08:48:04 »
Did this ever end up being resolved?
Offline poolside
« Reply #525 on: Thu, 25 July 2019, 16:54:14 »
Not yet, unfortunately. I should ask him again if he can provide that missing measurement.
Offline Vloshko
« Reply #526 on: Thu, 22 August 2019, 11:48:08 »
224950-0
224952-1
224954-2
Keycap Compendium
Key Cap Wishlist
