Author Topic: [IC] Programmable drop-in G80-1800 PCB  (Read 44140 times)
Offline hineybush
  • student of error
    • hineybush keyboards
Re: [IC] QMK G80-1800 PCB
« Reply #50 on: Sat, 02 December 2017, 03:33:05 »
Fixed all issues, did not include the bootloader flashing pins but I believe that is an outlier to actual necessity of the board. Ordered the new PCBs tonight as well.
Offline TalkingTree
    • My projects
« Reply #51 on: Sat, 02 December 2017, 05:22:04 »
Do you mean the Serial Peripheral Interface? That's not necessary unless you use ATMega32u4RC which comes without a bootloader but, as far as I know, they are not being produced anymore.
Offline .
« Reply #52 on: Sat, 02 December 2017, 17:00:46 »
In-system Programming, actually.
Offline hineybush
  • student of error
« Reply #53 on: Sat, 02 December 2017, 17:27:40 »
Yeah, for ISP/JTAG programming in case the bootloader gets corrupted or something. I'm using a regular 32u4-au so it'll come with one installed.
Offline ramnes
  • T fou, mec?
« Reply #54 on: Sat, 02 December 2017, 18:01:43 »
Excellent project, thank you for doing this.
Although, I'd be in only with LEDs added, and ideally a plate. I don't see myself resoldering everything just for changing the PCB and not having more "fun". :)
Offline Pwner
  • soon™
« Reply #55 on: Sat, 02 December 2017, 19:21:32 »
I believe leds will be added for the standard run.
Offline hineybush
  • student of error
« Reply #56 on: Sat, 02 December 2017, 19:34:28 »
Yeah I'd like to add LEDs once I get a new controller working with QMK, that's another side project of mine atm
Same with a full/half plate, I'd like to get something working with minimal cutting to the case itself
Offline duynguyenle
  • Personal text? What personal text???
« Reply #57 on: Sat, 02 December 2017, 19:53:42 »
The standard plate that's been floating around does not require much cutting, and provides a pretty good solid reinforcement for the keyboard itself, it is possible to have three separate mini-plate, and thus require no modding at all to the G80 case, but I think that somewhat defeats the point of using a plate in the first place (reduce the 'cheapness' feel of the plastic G80 cases)
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline hineybush
  • student of error
« Reply #58 on: Sat, 02 December 2017, 20:12:48 »
The difficult part will be fastening the plate to the case, i think. there's a few screw mounts in the top-middle of the case around 3/4 and backspace, but they won't provide super good support for areas far away from em.
Offline .
« Reply #59 on: Sun, 03 December 2017, 01:34:45 »
A plate is held by the switches so no need to mount it, like many 60% keyboards.
Offline hineybush
  • student of error
« Reply #60 on: Sun, 03 December 2017, 11:34:21 »
Yeah that's the other option. Makes sense, I figure securing it to the actual case itself will provide more rigidity though.
Offline hineybush
  • student of error
« Reply #61 on: Sun, 03 December 2017, 22:57:29 »
Updated/fixed PCB protos have been ordered
Here's an IC form for the first run of "production" boards. These will hopefully run in a month or so, maybe Feb. Timeline depends on how things with the new controller go. Main purpose of this IC is to gauge interest in a thicker version (2.0mm instead of 1.6mm) for more stiffness and a black-on-red silk/mask Cartel Keyboards version, as opposed to the "standard" white-on-black.
https://goo.gl/forms/OXJZtKoFJVVNOqfV2
« Last Edit: Sun, 03 December 2017, 23:05:20 by hineybush »
Offline hineybush
  • student of error
« Reply #62 on: Sat, 09 December 2017, 03:52:05 »
I'll have the PCBs Monday. Can't wait to check em out.
Offline Giorgio
« Reply #63 on: Sat, 09 December 2017, 05:27:49 »
What firmware are you planning to use?
Offline TalkingTree
    • My projects
« Reply #64 on: Sat, 09 December 2017, 05:29:02 »
Ahem, it's in the thread title.
Offline hineybush
  • student of error
« Reply #65 on: Sun, 10 December 2017, 22:39:29 »
Put one together and whipped up a quick firmware on kbfirmware.com... IT WORKS
I've noticed two of the indicator LED silkscreens are backwards, not a huge deal. And the solderable pads for a cable aren't labelled which I'll make a note of in the "user manual". I need to solder diodes and get the indicator LEDs in, but aside from me checking them it's fully working.
Offline TalkingTree
    • My projects
« Reply #66 on: Mon, 11 December 2017, 04:16:08 »
Looks very nice.
Offline hineybush
  • student of error
« Reply #67 on: Mon, 11 December 2017, 05:12:07 »
After looking at a few of the PCBs I don't recommend using ALLPCB for stuff like this. 4 of the 5 in the pack I opened were scratched to hell and back:
^ this is the one I built to test, and noticed these marks once I was soldering.
^ Did they try to fill it in with sharpie?
The original broken protos were done through EasyEDA, and have no scratches. I will likely be using them in the future.
« Last Edit: Mon, 11 December 2017, 05:18:08 by hineybush »
Offline TalkingTree
    • My projects
« Reply #68 on: Mon, 11 December 2017, 05:29:17 »
I'm afraid some scratches are deep enough to cut the traces.
Never tried ALLPCB myself but I can vouch for EasyEDA's quality.
Offline hineybush
  • student of error
« Reply #69 on: Mon, 11 December 2017, 05:42:32 »
I'll have to check closer, but it looks like they're mainly in the mask.
I've used EasyEDA and PCBWay before - both have been solid. I'm somewhat partial to PCBWay because they can also do assembly, and the GB for these will feature boards fully assembled from the factory.
Offline TalkingTree
    • My projects
« Reply #70 on: Mon, 11 December 2017, 07:07:46 »
EasyEDA also does do assembly. Email Dillon He or the support centre for a quote or simply more info.
Offline hineybush
  • student of error
« Reply #71 on: Mon, 11 December 2017, 07:10:23 »
Nice, thanks! Didn't realize they did that.
Offline TalkingTree
    • My projects
« Reply #72 on: Mon, 11 December 2017, 07:15:50 »
Since this is an interest check, and I'm interested, I urge to ask if there are plans for a european proxy, also, if it there will be any bare PCB for sale, I can do the soldering myself.
Offline duynguyenle
« Reply #73 on: Mon, 11 December 2017, 12:51:02 »
Mechboards has acted as a proxy for quite a few GBs recently, he is available on the MKUK Discord if you want to explore the option of having an EU based proxy for bulk shipment!
Offline asen1994
« Reply #74 on: Mon, 11 December 2017, 12:55:53 »
Hi, can i join this gb?? I need one for my dolch pac
Offline threedawg
« Reply #75 on: Tue, 12 December 2017, 00:01:07 »
really interested in this project and already filling the interest check, but a question: will this support additional LED?? Planning on making a custom sandwich case and really wanted to adding underglow LED effect
Offline hineybush
  • student of error
« Reply #76 on: Tue, 12 December 2017, 00:08:42 »
Hey - going to rework some stuff matrix wise to allow for in-switch and underglow LED. Stay tuned ;)
I might have 1 or 2 extras once I'm done building/shipping these out, I should know in 2-3 weeks. I'll let you know.
Offline asen1994
« Reply #77 on: Tue, 12 December 2017, 10:50:16 »
Okay, i will wait your pm, thanks bro
Offline captsis
  • Formerly matt2dlg
« Reply #78 on: Tue, 12 December 2017, 23:59:28 »
so the pcb will drop into a g80 case?
« Reply #79 on: Wed, 13 December 2017, 00:42:44 »
the case is the same for g80 and g81
Offline hineybush
  • student of error
« Reply #80 on: Wed, 13 December 2017, 02:02:54 »
thanks puddboy
yes, G80-1800 and G81-1800 share the same case.
source: someone sent me a G81 case, and i swapped the parts around/examined them and they're the same lol
Offline kimbles
« Reply #81 on: Wed, 13 December 2017, 21:13:46 »
Huh, I thought when I saw QMK 1800 PCB this was what the Key Company was working on.. haha
Offline hineybush
  • student of error
« Reply #82 on: Wed, 13 December 2017, 23:15:50 »
Turns out they've been working on their project too, and announced it around the same time that I did lol. No problem though!
Offline mindcomputing
Re: [IC] QMK-powered G80-1800 PCB
« Reply #83 on: Sun, 31 December 2017, 08:51:30 »
Count me in for 2-3 pcbs!
Offline hineybush
  • student of error
« Reply #84 on: Sun, 31 December 2017, 11:40:01 »
Cool!
Currently working on finishing up assembly of the prototypes so I can ship them next week.
Offline xZ3ROx
« Reply #85 on: Sun, 31 December 2017, 13:22:03 »
Count me in for a pcb
Offline broden
« Reply #86 on: Tue, 02 January 2018, 11:18:50 »
I have been watching this for a little while. Fantastic work.
I would be very interested in a PCB as well. :)
Offline steinerlein
« Reply #87 on: Thu, 11 January 2018, 06:47:57 »
Hey man, do you still have a pcb left? I'd love to buy one off of you. Looks awesome!
Offline hineybush
  • student of error
« Reply #88 on: Thu, 11 January 2018, 12:11:12 »
Nope, all protos are claimed atm. Hoping for a full run of these in the next month or two.
Offline hineybush
  • student of error
« Reply #89 on: Tue, 16 January 2018, 15:43:42 »
Shipped the European ones out last Thurs. Today I sent the rest of the international ones (two Aus, one Japan) and about half of the US ones. I'm going to get the rest of the US ones (all of the soldered diode ones) out this week.
Offline hineybush
  • student of error
« Reply #90 on: Fri, 19 January 2018, 16:40:36 »
All but two are shipped. The European ones will be delayed, because they got held up in customs (somewhat expected). Shouldn't be long.
Offline punkpc
« Reply #91 on: Fri, 19 January 2018, 22:30:12 »
I'm interested in the GB when you finish the new design.
Also did you ever get the pictures you needed for the Dolch Pac LED layout?
186880-0
The LED's go on a separate PCB. So you just solder them into the standard 1800 LED holes.
186882-1
Picture from digi Leeku 1800 build log https://geekhack.org/index.php?topic=72783.msg1776728#msg1776728
Offline captsis
  • Formerly matt2dlg
« Reply #92 on: Mon, 29 January 2018, 18:25:09 »
Got an ETA on approximately when the GB will go live? Really excited about this!
Offline hineybush
  • student of error
« Reply #93 on: Tue, 30 January 2018, 12:50:04 »
Yep, thanks! Seems like the Dolch LEDs can just be wired to the PCB.
Not sure at this point, in the next few months is my best guess.
Update on the Euro orders: My contact moved from Great Britain during the transit of the package to him. It was supposed to reach him by when he moved, but was held in customs. It was released with the condition he'd have to pick it up, in person. Since he's in the Netherlands now, he cannot do that, so they will be returned to me. I'll ship them out to the Europeans as soon as I can once I have them.
Offline punkpc
« Reply #94 on: Tue, 30 January 2018, 13:18:27 »
Let me know if you need more pictures or to test fit with the Dolch Pac. I would be more then happy to help out.
Offline hineybush
  • student of error
« Reply #95 on: Tue, 30 January 2018, 14:20:09 »
I actually just received one last week! I'll have to check.
Offline Rayndalf
« Reply #96 on: Tue, 13 February 2018, 14:31:39 »
Any update on this? I've fallen down the 1800 rabbit hole, and have found myself with multiple boards in need of PCBs, so a lower price point appeals to me
Offline RealLaugh
« Reply #97 on: Tue, 13 February 2018, 15:04:48 »
do you have any updates on the EU orders? I guess they're making their slow way back from customs in the UK
Offline hineybush
  • student of error
« Reply #98 on: Tue, 13 February 2018, 19:38:09 »
Yep, still on the way to me. Yesterday I asked if he was given a tracking number, waiting to see what they tell him.
Offline RealLaugh
« Reply #99 on: Mon, 05 March 2018, 16:41:33 »
Is it too s00n to ask for an update?  :p
