Author Topic: Mx Mount alps switch  (Read 3217 times)
Offline pixelpusher
« on: Fri, 03 November 2017, 07:42:16 »
Anyone tried these out?  Bought some yesterday.
http://s.aliexpress.com/jYjIrAzq
Offline Sup
Re: Mx Mount alps switch
« Reply #1 on: Fri, 03 November 2017, 07:52:41 »
Those are not alps  switches i think those are SMK 2nd MX mount. I am also interested on how they feel.
« Last Edit: Fri, 03 November 2017, 07:54:56 by Sup »
current
Coming soon
Offline rich1051414
« Reply #2 on: Sat, 04 November 2017, 03:30:14 »
It should be these:
https://deskthority.net/wiki/SMK_Cherry_MX_mount
The mechanism does appear to be in the vein of alps.
« Last Edit: Sat, 04 November 2017, 03:35:11 by rich1051414 »
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #3 on: Mon, 06 November 2017, 00:16:26 »
I hate to be the bearer of bad news here, but you seriously overpaid for these. You could have got 100 for $16AUD + proxy fees and shipping through TaoBao: https://world.taobao.com/item/540513185273.htm
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline pixelpusher
« Reply #4 on: Mon, 06 November 2017, 00:20:54 »
Money doesn't really matter to me.  Also, I don't know how to order off taobao.  So no bad news.  The thing I'm most worried about is that IF these happen to fit in place of normal alps switches, those extra two plastic pins are only going to work for PCBs with mx PCB holes.  So, I'm more than likely going to have to cut them off, which will suck a bit.
Offline _haru
« Reply #5 on: Mon, 06 November 2017, 00:23:10 »
Okay then. But ordering off Taobao is easy, just paste the link into a proxy service like Bhiner and then it's pretty self explanatory :)
These require a different set of mount holes for the switches. They will NOT fit in a standard Alps PCB. You need one designed specifically for SMK switches, like the Bleach60 etc.
Offline pixelpusher
« Reply #6 on: Mon, 06 November 2017, 00:37:43 »
Okay, I'm watchinng the Bleach60 thread on DT
