Author Topic: Cherry G84-4400?  (Read 2747 times)
Offline okan
Cherry G84-4400?
« on: Mon, 13 November 2017, 06:55:16 »
Hi,
I have a question, why is this keyboard so expensive? Even the ps/2 ones...Tried one and it feels kinda light..like a toy keyboard :P
http://www.touchwindow.com/c/CherryG84-4400SmallKeyboards.html
Re: Cherry G84-4400?
« Reply #1 on: Mon, 13 November 2017, 07:03:50 »
Because the target market isn't consumers and you can probably find it much cheaper elsewhere.
Offline jackalopephoto
« Reply #2 on: Mon, 13 November 2017, 08:22:10 »
Hi,
Get a Cherry G86. I love mine, and it feels solid
« Reply #3 on: Mon, 13 November 2017, 12:48:56 »
Hi,
very different keyboards. G84 is low-profile (2mm travel) mechanical (ML ) switches, G86 is normal profile (4mm) rubber dome switches (except the G86 ricercar spos, which has MX switches. Somewhat uncommon though). Personally, I like the G84 and have one with dyesubs that I use sometimes. The only bad part is 2KRO. Mine is only a 4100 so no trackball.
Anyway the lack of a metal plate, and low-profile switches and keycaps makes it weigh almost nothing. Good for laptops, which is why some manufatures switched to ML from M87 or whatever before going to scissor.
« Reply #4 on: Tue, 14 November 2017, 07:46:17 »
Interesting, I didn't know there were short travel mechanical switches
Offline SamirD
« Reply #5 on: Thu, 16 November 2017, 00:43:46 »
I have an ML based Cherry that I got for a steal and while I didn't think I would like it, my hands do typing almost as effortlessly and as fast as they do on the modlel M.  Definitely one of those 'try and see whatcha think' switches.  :thumb:
Online Findecanor
« Reply #6 on: Thu, 16 November 2017, 01:11:54 »
BTW, the keys are a little bit smaller than standard.
