Author Topic: Unknown error after upgrading Windows  (Read 3471 times)
Offline StephenSs
« on: Tue, 05 December 2017, 05:40:41 »
Hello community.
After upgrading to Windows 10 i cannot open OST extension file which is on my flash drive.
A warning message: "Unknown error"
How can i remove the error or what should I do? Any suggestions ideas would be great.
Offline ander
  • I type, therefore I am
Re: Unknown error after upgrading Windows
« Reply #1 on: Tue, 05 December 2017, 06:05:08 »
Have you just been trying to open the file from within Outlook?
Maybe your file association is broken for .ost files. Try right-clicking the file, pointing to "Open With...", then clicking "Outlook" in the list. (If Outlook isn't in the list, click "Choose Default Program..." to find and select Outlook.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #2 on: Tue, 05 December 2017, 14:12:14 »
NO ONE NEEDS WINDOWS TEN. GO BACK TO WINDOWS NINETY-EIGHT.
Offline rob292
« Reply #3 on: Wed, 06 December 2017, 01:50:07 »
OST is a cache file that syncs outlook with the mail server. It is created when you setup your account in Outlook.You can export your email account (OST) to a PST in Outlook under import/export options. Also you can try to open the file here: https://www.viewertool.com/ostviewer.html
« Reply #4 on: Wed, 06 December 2017, 05:50:06 »
:spam:
