Author Topic: Any ideas about what this keyboard is from?  (Read 3391 times)
Offline invariance
  • ...here with all the other boson's
« on: Tue, 12 December 2017, 06:12:23 »
Received this recently and I can find very little about the switches and absolutely nothing about the keyboard or the pc/system it could have come from.
Does anyone else have any ideas or more info about the origins of this thing?
184179-0
184181-1
The back.
184183-2
The casing appears to have been machine fabricated by the appearance of the bends, and the top has a nice rough texture.  The timber sides make me wonder if it was pulled from something and the sides were then made for it, and the ribbon cable adds to that theory as it would have run to the mainboard.
184185-3
Some distinctive keys that make me wonder if it was an input device on a 'mainframe' or possibly an electronic typewriter: Control, Line Feed, Repeat, Null and the best one, Super Shift.
This is the inside and the switches at the top are SMK but are unused.  No manufacturer name on the pcb but has the date code of 8103.
184187-4
The keyswitches are Clare-Pendar foil and foam, for which there is very little info on also.
184189-5
I would love to have some idea about it's origins if possible.
« Last Edit: Tue, 19 December 2017, 04:06:31 by invariance »
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Any ideas about what this keyboard is from?
« Reply #1 on: Thu, 14 December 2017, 02:38:39 »
I've so far chosen not to document Clare foam and foil on the wiki, because information on them is too scarce. There are some patents for them, though, filed by General Instrument. In your case, there is a date code, which helps, as now we have a slightly clearer idea. It's interesting to note that the 1981 date code makes yours older than all the General Instrument patents, presumably from the time before the Clare brand was phased out. Are all the switches marked in the same way? There's another keyboard with these switches where only one is marked CP Clare and the rest are unbranded:
https://deskthority.net/keyboards-f2/cray-research-inc-keyboard-made-by-ampex-t11783.html
The PCB is likely Clare/General Instrument as it matches others:
https://deskthority.net/keyboards-f2/identify-this-keyboard-thread-t10405-690.html#p327597
Bore Awards
Offline invariance
« Reply #2 on: Thu, 14 December 2017, 04:29:07 »
Thanks Daniel.
All of my keyswitches are marked the same.
Interesting my pcb date code predate the General Instruments patents.
The seller also had listed a The Data Group computer at the same time and even though the placement of the arrow keys is the same, everything else about the keyboard is remotely different.
184398-0
Besides, the company went bankrupt in 1979: http://www.bytecollector.com/the_digital_group.htm
Google comes up empty handed even with "Super Shift"  :( :(
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
  • RIP
    • Boring twaddle
« Reply #3 on: Fri, 15 December 2017, 02:42:10 »
I've added what little I know so far to the wiki: Clare foam and foil
Bore Awards
Offline invariance
« Reply #4 on: Tue, 19 December 2017, 04:21:26 »
I thought I was getting close with an Apple clone "Pluto", but no....  :'(
184666-0
From Peter's z80.eu site blog.
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
