Author Topic: [IC] Atom49 - Fully programmable PCB for the Magicforce 49  (Read 15018 times)
Offline .
« on: Sun, 17 December 2017, 07:43:31 »
A friend of mine got himself a Magicforce 49, which is a small and affordable keyboard. Being small, it has a weird layout and sometimes makes no sense. He wants to have QMK on it, so I designed a PCB which fits loke a glove. I know it does because I have printed it out and put it in its case. I have not ordered any prototypes yet, but I will once I hear some feedback from you.
Well, here it is:
It is a pretty basic PCB, and has no lighting effects like the original does. You can control the brightness levels, change every key there is, have layers, macro's, all thanks to QMK which it will have. The backlight effects are probably possible, but it is kind of useless in my opinion.
If there is anything you'd like to see, let me know :)
« Last Edit: Mon, 25 June 2018, 10:08:27 by . »
Offline neon_tom
Re: [IC] Fully programmable PCB for the Magicforce 49
« Reply #1 on: Sun, 17 December 2017, 13:22:03 »
I’d be down for one or two. I love the layout of this board but I’ve avoided it because of lack of programmability.
Offline t_southwell
« Reply #2 on: Sun, 17 December 2017, 21:18:33 »
I got a magicforce 49 from massdrop and hate how its not programmable (why the split spacebar) so would definitely be interested.
FC660C, Model F XT, AT102W, Pok3r, DIY-71, Anne Pro, Tada68, Magicforce 49, CONTRA, Smith Corona XL1500
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #3 on: Sun, 17 December 2017, 21:42:27 »
Hey, like I said on Reddit you'll need to reposition your components around the controller. The decoupling caps (the 0.1uF ones) need to be as close as possible to the Vcc pins on the MCU. Check out schematics of other boards (esp planck/60/etc ones) to get a sense of proper placement practices.
Aside from that, this is a really cool idea - I love the thought of OEM replacement boards that're fully programmable.
Offline .
« Reply #4 on: Mon, 18 December 2017, 02:56:45 »
Hey Hiney, thanks for your suggestion :thumb:. I have changed the placement of those capacitors.
Offline t_southwell
« Reply #5 on: Wed, 27 December 2017, 09:53:46 »
Have you tested the PCB is working with the magicforce or only tested if it fits in the case?
Offline .
« Reply #6 on: Thu, 28 December 2017, 17:20:36 »
I have no prototype yet so I can't say that it works but I am quite sure it does actually work. I have tested if it fits by printing the pcb outlines out and see if it fits. It does.
Offline t_southwell
« Reply #7 on: Tue, 16 January 2018, 15:12:53 »
Any updates on the prototype?
Offline .
« Reply #8 on: Wed, 17 January 2018, 15:01:36 »
I'll order one after the group buy of the Atom47 is finished, so that will take a little while.
Offline slot demon
« Reply #9 on: Wed, 17 January 2018, 15:18:43 »
Iso compatibly (I know I have to modify the plate, but I hate that the magicforce is only ANSI).
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #10 on: Tue, 27 February 2018, 00:20:33 »
I would be interested for sure.
Offline TonyD
    • dtronixs
« Reply #11 on: Thu, 01 March 2018, 05:32:33 »
Offline llisandro
« Reply #12 on: Fri, 30 March 2018, 20:22:04 »
Ditto
Offline .
« Reply #13 on: Sat, 31 March 2018, 11:30:59 »
I'll continue with this once I'm done with the Atom47.
Offline brooklynlou
« Reply #14 on: Tue, 03 April 2018, 15:51:48 »
Watching as well ...
« Reply #15 on: Tue, 10 April 2018, 13:21:47 »
The layout on the MF49 is even worse than the Vortex Core...
Small keyboards shouldn't be expensive, but they should be fully programmable! I would probably buy a MF49 if this GB ran.
Offline t_southwell
« Reply #16 on: Tue, 10 April 2018, 13:23:05 »
yeah if this gb doesn't start soon I might just get a hasu usb to usb
Sent from my ONEPLUS A3003 using Tapatalk
Offline brooklynlou
« Reply #17 on: Wed, 11 April 2018, 15:12:36 »
Same here ... I'd repurchase a MF49 if this one came to fruition
Offline .
« Reply #18 on: Wed, 11 April 2018, 16:21:45 »
How soon?
Offline t_southwell
« Reply #19 on: Wed, 11 April 2018, 16:23:08 »
In the next few months, don't really mind just my magicforce is just sitting in its box atm because without programming the layout it almost unusable
Offline .
« Reply #20 on: Wed, 11 April 2018, 16:37:55 »
That's definitely possible. Stay tuned!  :)
« Reply #21 on: Mon, 23 April 2018, 10:56:25 »
You should give bakingpy a heads up when you start on this, he had a similar idea.
Offline .
« Reply #22 on: Mon, 25 June 2018, 10:08:05 »
Hi! It's been a while. The design of this PCB is done, and all I have to do now is to order some prototypes. I'll let you know when they arrive and if they're working  :)
Edit: I forgot to mention that it has south-facing LEDs and support for PCB-mounted stabilizers (though that requires modifications to the plate)
« Last Edit: Mon, 25 June 2018, 10:11:15 by . »
Re: [IC] Atom49 - Fully programmable PCB for the Magicforce 49
« Reply #23 on: Tue, 26 June 2018, 10:20:19 »
 I am in for this 100%
Offline .
Offline .
« Reply #25 on: Mon, 09 July 2018, 03:25:00 »
I got a few responses and I think I'm gonna run the group buy next month. :thumb:
Offline .
« Reply #26 on: Fri, 20 July 2018, 16:43:38 »
I have ordered a few prototypes, they'll hopefully arrive next week or so.
Offline EvvL
« Reply #27 on: Mon, 23 July 2018, 10:32:59 »
Looking forward to this. Hopefully the prototypes work out.  :thumb:
Offline reijikyosuke
« Reply #28 on: Sun, 12 August 2018, 03:58:48 »
Looking forward with this programmable PCBs. Need new keyboard for travelling :D
Offline worldspawn
« Reply #29 on: Sat, 17 November 2018, 17:18:41 »
Any status updates?
Only mod I'd like to see would be the option to replace the enter key with 2x single keys so you could get back the ; and ' and move the enter down to the thumb-row in place of the shift key.
I can make acrylic laser cut cases/plates PM for info
