Author Topic: Krytox will be banned in 2020  (Read 6070 times)
Offline Giorgio
« on: Sun, 17 December 2017, 08:24:58 »
It will be banned because it contains pfoa
http://nipsect.dk/pfoa-to-be-banned-in-europe/
Re: Krytox will be banned in 2020
« Reply #1 on: Sun, 17 December 2017, 09:55:27 »
Are you sure that Krytox contains PFOA? I can not find it in any description of it.
Where did you see it?
Offline Giorgio
« Reply #2 on: Sun, 17 December 2017, 19:47:57 »
"The EPA's scientific advisory board found in 2005 that perfluorooctanoic acid (PFOA), a chemical compound used to make Teflon, is a "likely carcinogen." I won't use any product that requires the use of carcinogens in its manufacture just on ethical grounds alone. BTW, Krytox also uses PFOA in its manufacture (via PTFE)."
https://www.bladeforums.com/threads/the-ultimate-lubricant-thread.409621/page-7
https://www.lowtoxlife.com/teflon/
« Last Edit: Sun, 17 December 2017, 20:18:35 by Giorgio »
Offline pixelpusher
« Reply #3 on: Sun, 17 December 2017, 19:54:14 »
is there a suitable replacement?
Offline stoic-lemon
« Reply #4 on: Sun, 17 December 2017, 22:05:51 »
So this likely affects other lubes and not just Krytox?
« Reply #5 on: Sun, 17 December 2017, 23:03:53 »
There are lots of dangerous chemicals that are being used in chemical processes.
As long as nobody discovers any traces of PFOA in the end product, I believe that products containing PFTE will stay in production and continue to be sold.
« Reply #6 on: Wed, 20 December 2017, 19:48:10 »
"PFOA was a. o. used as an alternative to PFOS, which was banned in 2008."
Don't worry - we'll find an alternative to give us another 9 years of grace.
Offline Leslieann
« Reply #7 on: Thu, 21 December 2017, 00:41:48 »
I'm pretty sure this is at least the 3rd time they changed it to a slightly different toxic mix to keep ahead of it (I think it's closer to 5th).
They know the new formulas are just as bad, but because it's a new formula it resets the clock.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline TerryMathews
« Reply #8 on: Thu, 21 December 2017, 21:41:29 »
So no plated metals? No anodized aluminum?
« Reply #9 on: Fri, 22 December 2017, 11:43:45 »
Plating and anodising do not need lubricants!
Those processes use electrolysis and acids. Anodising a colour involves first electrolysis, then a bath in dye followed by boiling in water to seal the dye in the oxide's pores.
« Reply #10 on: Fri, 22 December 2017, 23:15:24 »
the koreans use wakos, stock up on that
