Author Topic: [IC] Noxary XRF (Aluminum Realforce Case) - Group Buy Live!  (Read 92680 times)
Offline xondat
  • i'm not a star
Re: [IC] Noxary XRF (Aluminum Realforce Case)
« Reply #150 on: Mon, 14 May 2018, 15:41:34 »
will the plate be compatible with the black housing of the 86U realforce or only with RGB housing? I apologize if it has already been asked but I lost it
The plates are designed for the Realforce case.
Planning these plates so far:
  • Black housings 86U
  • Black housings 87U
  • RGB housings 86U
I might add some more, but unsure right now.
I don't plan to do any plates for RGB boards for now, they aren't popular enough.
Offline Kerasan
« Reply #151 on: Mon, 14 May 2018, 15:58:36 »
  • RGB housings 86U
is there a realforce rgb 86u? I lost it
KMK Labs.
Offline xondat
  • i'm not a star
« Reply #152 on: Mon, 14 May 2018, 16:03:16 »
  • RGB housings 86U
No, I mean the 86 key layout. So you'd use RGB housings/stabilizers, 86U PCB, custom plate, and RF/XRF case.
Offline Kerasan
« Reply #153 on: Mon, 14 May 2018, 16:53:57 »
ah ok perfect, at the moment I dont own housing and stab rgb and take a realforce rgb just for them mmhhhh.....I will think about it.
Thank you
KMK Labs.
Offline xondat
  • i'm not a star
« Reply #154 on: Mon, 14 May 2018, 16:57:41 »
Thank you
I think if you have the funds to, you should, but otherwise it isn't too maybe. You do gain stock smoothness and MX functionality.
Offline thelaughingman
  • Simultaneously the most starry-eyed idealist and t
« Reply #155 on: Mon, 14 May 2018, 20:46:37 »
  • RGB housings 86U
So would the plate support 87U & RGB housing combination? And I assumed, but would like to get your confirmation, that the LCtrl cut out is square already right?
Offline xondat
  • i'm not a star
« Reply #156 on: Mon, 14 May 2018, 20:48:14 »
  • RGB housings 86U
Nope, sizing is different. Black housing is longer and thinner.
Still unsure about that cutout.
« Reply #157 on: Mon, 14 May 2018, 21:44:20 »
  • RGB housings 86U
I see, so no plate for me this round then. Will keep a close watch on this for further updates. You're awesome  :thumb:
Offline Kerasan
« Reply #158 on: Tue, 15 May 2018, 01:43:30 »
Thank you
I will modify the rf86u with Novatouch'd (I have a spare for the mod) then I will try to find housing and mx slider of a RealForce rgb.
But I imagine that the plate is not compatible at the same time with both and I have to choose between Black housing and rgb housing, because they have a different size.
Offline xondat
  • i'm not a star
« Reply #159 on: Fri, 13 July 2018, 20:35:51 »
V1 prototype case is ready to be made, will be put into production this week. Looks nothing different from the outside but I started again and took a different approach on the internals.
Going to prototype and then change what needs to be changed, make a v2 prototype, and then you can guess what's after that. PCB work isn't happening for now, other projects are more important.
Offline Wetherbee
« Reply #160 on: Fri, 13 July 2018, 22:50:54 »
 YYEEEAAHHHH!!!
Offline Gobluebro
« Reply #161 on: Mon, 16 July 2018, 07:40:40 »
I'm interested. I missed norbauer's case so I won't be missing this one.
Offline xondat
  • i'm not a star
« Reply #162 on: Mon, 16 July 2018, 12:44:08 »
Prototype V1 ordered, will drop a delivery date soon :p
Offline xondat
  • i'm not a star
Re: [IC] Noxary XRF (Aluminum Realforce Case) (Prototype V1 Ordered)
« Reply #163 on: Wed, 18 July 2018, 12:01:01 »
Should get the sample in 10-14 days :thumb:
Offline Allo
« Reply #164 on: Wed, 18 July 2018, 20:07:45 »
Anxiously waiting!
Offline EugeneYap83
« Reply #165 on: Thu, 19 July 2018, 08:03:24 »
  • RGB housings 86U
Please be square. Please be square. Please be square. Please be square. Please be square.
Offline xondat
  • i'm not a star
« Reply #166 on: Fri, 20 July 2018, 11:41:02 »
Haha, yeah it's going to be a regular cutout but made to work with the weird housings. I need to assess the prototypes when I get them :)
Offline xondat
  • i'm not a star
« Reply #167 on: Sat, 28 July 2018, 10:51:31 »
Sneak peek :-*
Said they should finish Monday (30th), so I might have it late next week.
Offline Kerasan
« Reply #168 on: Sat, 28 July 2018, 11:00:31 »
Sneak peek :-*
wow... super clean, it's beutiful.
KMK Labs.
Offline Kallus
« Reply #169 on: Sun, 29 July 2018, 13:12:07 »
can you do a plate for the 88u?
Offline Data
« Reply #170 on: Mon, 30 July 2018, 06:46:12 »
Nice bezels.  :cool:
Offline xondat
  • i'm not a star
« Reply #171 on: Mon, 30 July 2018, 10:30:45 »
If there is demand
Offline Kallus
« Reply #172 on: Mon, 30 July 2018, 17:08:07 »
I think a pen rest would be really dope on this board, since there is unused space at the top of the board anyway.
Offline wholypantalones
  • text and icon mods plz.
« Reply #173 on: Mon, 30 July 2018, 19:41:11 »
Just from reading previous replies, am I correct in assuming that this won't work on a white case 87u because the black 87u is a different size?
Offline xondat
  • i'm not a star
« Reply #174 on: Mon, 30 July 2018, 20:30:16 »
Nah. Black plate refers to the housings types (Black & RGB).
All 84/87/88/89u etc should fit.
Offline xondat
  • i'm not a star
« Reply #175 on: Fri, 03 August 2018, 18:52:12 »
Parts are with DHL, should have it Wednesday latest :p
Offline letze
  • Here I am~
« Reply #176 on: Fri, 03 August 2018, 21:22:51 »
Alu case + win keyless + brass plate + incoming KBDfans topre keycaps set.
And BKE domes too.
Years ago, who know topre will be custom-able in the future. There is no end game.  :thumb:
HHKB Professional 2 Type S Stock | Topre RF 87U + Norbaforce + Mix BKE Heavy 60g/ Stock 55g + Silencing ring + Slight lubed with [Krytox GPL 105 housing] & [Krytox GPL 205 stab]
Offline xondat
  • i'm not a star
Re: [IC] Noxary XRF (Aluminum Realforce Case) (Prototype V1 Pictures)
« Reply #177 on: Tue, 07 August 2018, 09:00:32 »
Some quick pictures. Will test fit everything later as I have to swap housings/PCBs over and too much effort rn :p
Offline Kerasan
« Reply #178 on: Tue, 07 August 2018, 09:06:10 »
......... This is great!  :cool:
plates switches are gorgeous  :eek:
KMK Labs.
« Reply #179 on: Tue, 07 August 2018, 09:57:18 »
Man, that's nice!  :thumb:
« Reply #180 on: Tue, 07 August 2018, 10:32:39 »
WOAH! DAT PLATE IS GUD!!! I want it  :))
Offline rkfiske
« Reply #181 on: Tue, 07 August 2018, 10:36:40 »
I specifically made an account just to follow this thread. That thing is gorgeous!!
Sent from my Nexus 6 using Tapatalk
Offline nmur
  • ಠ_ಠ
« Reply #182 on: Tue, 07 August 2018, 10:52:37 »
looks great dude
Offline xondat
  • i'm not a star
« Reply #183 on: Tue, 07 August 2018, 11:20:20 »
Full picture of the case
It's more a proof of concept right now though :)) Messed up the screw sizes for the plate, which means the screw heads are too small for the plate. Not a problem though, everything else has gone as planned and I know what needs adjusting for the V2 prototype.
Will continue working on refining everything to perfection :p
Offline Lansky
  • Realest motherthocker
« Reply #184 on: Tue, 07 August 2018, 13:16:23 »
Looking good!
You have any idea on the pricing of the brass/PVD plate yet?
Offline xondat
  • i'm not a star
« Reply #185 on: Tue, 07 August 2018, 14:22:36 »
Looking good!
Nope. It was more of a test to see if it's feasible :)
Offline Lansky
« Reply #186 on: Tue, 07 August 2018, 14:29:01 »
Well, they look great! I'll be keeping an eye out.
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #187 on: Tue, 07 August 2018, 18:35:22 »
Woah yes. I’d wanna stick an IBM or terminal board sticker on that top chin.. (make the chin larger..?) :P
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline Kallus
« Reply #188 on: Wed, 08 August 2018, 09:12:40 »
How hard would it be to support iso with the case? I think that the iso board has the blockers in the same place although it may look kind of goofy its a compromise i'd be able to live with. I would really love to have iso support.
Offline xondat
  • i'm not a star
« Reply #189 on: Wed, 08 August 2018, 09:24:10 »
The case accepts any Realforce (R1) plate, so you can use whatever you want.
There will be a version with blockers, and without.
Offline Kallus
« Reply #190 on: Wed, 08 August 2018, 09:37:55 »
Alright! Sick
Offline funkybeat7
« Reply #191 on: Thu, 09 August 2018, 10:34:57 »
Those plates look great! I'm definitely going to pick one up!
Offline Gacct
« Reply #192 on: Thu, 09 August 2018, 14:32:11 »
any possibility of a case for the realforce 23u numpad in a design similar to this?
Offline EugeneYap83
« Reply #193 on: Wed, 15 August 2018, 21:55:31 »
Dat mirror polish on the switch mounting plate is astonishing!
Offline xondat
  • i'm not a star
« Reply #194 on: Fri, 24 August 2018, 15:05:14 »
It's possible but I don't know what I actually want to focus on right now regarding Topre... Probably just the RF case replacement and then other stuff can follow.
Offline xondat
  • i'm not a star
Re: [IC] Noxary XRF (Aluminum Realforce Case) - Update
« Reply #195 on: Fri, 14 June 2019, 14:42:03 »
542 days later from the topic being created, and 293 since the last post... I'll try and sum up what happened since the last post.
For a brief overview, please see the OP. It's fully accurate, and I expect nothing to change between now and when the GB runs (apart from maybe adding a winkey top piece).
Wall of detail about the past:
The main thing holding this back was factory quality.  Previous places I've used just weren't up to the high standard we all expect, so I've been working on 1) finding a very high quality manufacturer, 2) delivering previous buys, and 3) having a solid supply chain.  Step 1 is done. Step 2 is in progress (X60 Rs were delivered a few months back, some batches in between, and now some 280s are being delivered shortly), and Step 3 is the important one. I'm finally happy with every step of the way, from placing the order to shipping out boards, which means that I don't feel too bad giving some hope to the project.
The manufacturer only wants 3 colors + silver per batch to maintain a high quality of anodizing. I'll be producing boards with the colors for this anyway, so it makes sense to "tag along" with them. I could do it sooner, but I'm not confident as a whole that I want to take on more right now. This is really "here's what I'm thinking, take it with a grain of salt".
More relevant information with the present:
Design has been completely overhauled. It's now "seamless" (seam on bottom vs the side) which is better for overall aesthetic. All tolerances and measurements were done again - I have a better understand of Topre as a whole. Daughterboard was redeveloped. Lots of smaller other things.
My hopes are to do a smaller round 1 for now, then run a larger round 2 of the back of that. I don't want to take on another massive project right now, but sub 50 units is easy to handle with the good supply chain that's set up. Winkeyless only for now (based on what I've polled on my Discord), since winkey will raise the price, but will think about it if I do something closer to 50 and not 20 units.
And here's the update I posted in my Discord server earlier.
Wanted to post a quick update - will be ordering the daughterboard prototype in a couple weeks. Getting a working daughterboard is the last step before starting the group buy. Probably will have it working in a 5-6 weeks. Then I'll be happy to start a group buy for it.
As I have it scheduled now, it'd be these three colors: Lightning Silver; Hyper Red; and Meteorite Gray. I'd still like to do a smaller GB, maybe 20-40 units. Approx timeline would be start late July/early August, delivered in late October. Unsure about price, I need to decide unit count (40 is easy due to the supply chain that's currently set up [more units, cheaper GB price]).
This is still in IC, and until it's a GB, I can't really promise anything. Nothing is final timeline wise, but all the information should help to catch up.
Offline Wetherbee
« Reply #196 on: Fri, 14 June 2019, 14:43:13 »
Oh good.  :thumb:
Offline phinix
« Reply #197 on: Fri, 14 June 2019, 17:32:26 »
If we gather more buyers, WinKey would be possible:)
So lets register our interest here, we need WK! :)
Offline Kerasan
« Reply #198 on: Fri, 14 June 2019, 17:41:58 »
I imagine that by changing the design the plate will no longer be compatible with the original case, is it right?
KMK Labs.
Offline OtherAndrew
« Reply #199 on: Fri, 14 June 2019, 17:42:24 »
no
