Author Topic: [IC] Noxary XRF (Aluminum Realforce Case) - Group Buy Live!  (Read 92764 times)
Offline clasicks
  • Formerly KeyboardUser4
Re: [IC] Noxary XRF (Aluminum Realforce Case)
« Reply #50 on: Thu, 21 December 2017, 19:22:40 »
+1 for 6 degrees
I’m in the camp that really loves the current Realforce badge. Would there be any way to transplant from the original case, or source a replica Realforce badge??
agreed... but if uhhh trademark issues arise there should be a custom / noxary / topre badge choice that is talked about
Offline duynguyenle
  • Personal text? What personal text???
« Reply #51 on: Thu, 21 December 2017, 20:17:41 »
I do feel like the "forehead" looks a little bit empty without the Realforce logo, perhaps someone with some graphics design experience could produce a vectorised version and get some metallic stickers made? (kinda like all the metallic HHKB stickers you can get from Taobao/Aliexpress)
I think that would complement the aesthetic design of the case and provide a nice visual point of emphasis on an otherwise quite plain top bezel.
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline Wetherbee
« Reply #52 on: Thu, 21 December 2017, 21:07:13 »
Stickers can be applied without a physical recess or relief.. like the HHKB used in your example. I find the big forehead rather charming and iconic. Hell, you could stick some metal Cherry stickers on there if Xondat is successful with the MX custom plate. Seen some photos of that done in jest on the old Digilogs.
As I learned with the Norbaforce IC though, people want options. I was totally against Winkeyless because I thought it would delay the project, but it ended up being an option that people loved.
I guess it would be up to Xondat to see how many top plate options he is able to accommodate. If each is a custom CNC run maybe it isn't a big deal to have several options - don't know how MOQ of multiple choices impacts group buy pricing. He already sounds committed to at least a regular top in addition to a Winkeyless option.
« Last Edit: Thu, 21 December 2017, 21:13:42 by amoswetherbee »
Offline afrokobe
« Reply #53 on: Thu, 21 December 2017, 21:27:45 »
i use mine with feet.
Offline moh18one
« Reply #54 on: Thu, 21 December 2017, 21:36:42 »
Cool!!! A ****ing case with the same shape that the original one!! Hype!!!
Flat is so comfortable to type one.
May I ask you somethings?
For OP: With the upcoming Realforce RGB TKL and Realforce R2 TKL that are going to be sold by Topre next year, can we expect a custom case for them as well? Although, the actuation point changer is quite useless for me, it a good addition to their keyboards and both models share the same case and bottom row (more standard layout), which is a big plus.
For those who own both Realforce RGB and a Topre with more conventional sliders, is it possible to swap them without the plastic housings or do they work only with these one. I don't want to use a keyboard with a plastic housing. Such a downgrade in my opinion...
Thanks ;)
« Last Edit: Thu, 21 December 2017, 21:57:27 by moh18one »
Offline Wetherbee
« Reply #55 on: Thu, 21 December 2017, 21:57:12 »
Realforce and Realforce RGB both use ABS plastic housings and sliders. RGB is a clear housing, regular is black. Shape of the slider is different to make room at the top of the housing for the LED.
Realforce RGB TKL has not been released but is scheduled for 2018. The mounting holes on the sides and in the ears on the corners are different to work with the new, square case, so adapters will be needed or a replacement plate to mount them in regular Realforce cases, assuming they keep the key dimensions the same.
« Last Edit: Thu, 21 December 2017, 21:58:55 by amoswetherbee »
Offline xondat
  • i'm not a star
« Reply #56 on: Thu, 21 December 2017, 22:02:17 »
With the upcoming Realforce RGB TKL and Realforce R2 TKL that are going to be selling by Topre next year, can we expect a custom case for them as well? Although, the actuation point changer is quite useless for me, it a good addition to their keyboards and both models share the same case and bottom row (more standard layout), which is a big plus.
Maybe if there is a lot of demand, but not a lot will own them vs this which has been around for years.
You should be able to swap just the sliders (or pick up JTK Sliders or something).
Offline xondat
  • i'm not a star
« Reply #57 on: Thu, 21 December 2017, 22:02:51 »
There are a few things that need to be decided, so to save people posting every time I ask something, I'll just put all the "pending" things here:
  • 6 degrees/flat, 9 degrees/raised, or in between?
  • Recess for sticker/badge, something custom, or nothing?
  • Brass weight?
  • Dip switch cutout?
Offline afrokobe
« Reply #58 on: Thu, 21 December 2017, 22:10:09 »
- 9 degrees raised
- nothing or something don't really matter; could do custom nameplate in brass if doing brass weight ;)
- yes, absolutely
- sure
Offline Wetherbee
« Reply #59 on: Thu, 21 December 2017, 22:14:45 »
  • Brass weight?
No idea on degrees.. I've never used the stock case, only ever used the Digilog which has a fixed height.
No for recess, or make it optional for those who must have it.
Brass plate will be enough weight. (Or even an aluminum one if you go in that direction). Realforce in aluminum is heavy AF already. Adding even more weight would just be for bragging rights over who has the heaviest non-portable small keyboard. I won't complain if it has a brass plate, though, as long as it is clean and not obnoxious with branding. Some of the brass plates coming out these days are ridiculously ugly - thankfully they are on the bottom.
No dip switch cutouts. How often are people changing their dip switches? You set it once and then never use it again. Sound could attenuate out of the hole like an instrument, no hole means more solid feel and sound (maybe not a real concern given that the whole bottom is closed in Noxary's design). What if the RGB TKL can be adapted to this case in the future with a custom plate or an adapter? If so, the dip switches probably won't be in the same place, leaving an empty hole at the bottom.
Just my humble opinion.
« Last Edit: Thu, 21 December 2017, 22:41:41 by amoswetherbee »
Offline avid
« Reply #60 on: Thu, 21 December 2017, 23:05:03 »
6 degree.
no branding.
no weight.
no dip.
I think 6 degree is most important. How many are using the RF with feet up?
Offline Wetherbee
« Reply #61 on: Thu, 21 December 2017, 23:12:04 »
6 degree.
no branding.
no weight.
no dip.
That's a much more succinct way to express my thoughts as well.
A case designed for 6 degrees can always be changed to support 9 degree with some feet (may look ugly but whatevs), but going the other way around is impossible without cutting off aluminum.
Offline jb1830
  • @jonboulton
    • 1upkeyboards.com
« Reply #62 on: Fri, 22 December 2017, 00:02:02 »
I'm in for this.
Definitely 6 degrees. Small brass piece with your logo in the factory location would be sweet. No big weight. No dip cutout, that's a set it and forget it type thing.
    IBM Model M            Fjell 002           Klippe            KC60           Planck
Offline moh18one
« Reply #63 on: Fri, 22 December 2017, 00:41:33 »
1. 6 degrees
2. Why not?
3. Neutral
4. Dip switches aren't important especially if the board is fully programmable (in the future)
Offline nurupism
« Reply #64 on: Fri, 22 December 2017, 01:44:09 »
1. 6 degrees
2. No opinion on branding
3. Yes for weight
4. Either is fine for dip switch
Offline avid
« Reply #65 on: Fri, 22 December 2017, 01:48:11 »
For everyone voting for weight, keep in mind its +50 in price.
« Last Edit: Fri, 22 December 2017, 04:30:24 by avid »
Offline pixelpusher
« Reply #66 on: Fri, 22 December 2017, 02:08:52 »
6 degree.
no branding.
no weight.
no dip.
I prefer to have the feet out on mine, raising the keyboard to 9 degrees.  The bottom row profile feels wrong at 6 degrees to me
Offline duynguyenle
« Reply #67 on: Fri, 22 December 2017, 04:58:03 »
1. 6 deg
2. Small recess at the same location and size as the OG RF logo
3. I'm indifferent about weight
4. No dip switches
Offline poolside
« Reply #68 on: Fri, 22 December 2017, 07:08:22 »
1. 6° and 9° are both fine
2. larger bottom bezel to balance out the large empty forehead area?
3. I need the weight. Plain bottoms look so empty
4. No DIP cutout? Some TKL Realforces don't have any DIP switches
Is the OG Realforce logo badge just a sticker or something stiffer?
Offline nmur
  • ಠ_ಠ
« Reply #69 on: Fri, 22 December 2017, 08:39:11 »
  • Brass weight?
preference for 9 deg
indifferent for the rest
Offline pr0ximity
« Reply #70 on: Fri, 22 December 2017, 08:56:11 »
I think a 7.5 deg would be pretty slick
Noxary engraved logo in place of the badge would be best imo
I'd prefer an option for no weight/alu weight, but I'd be cool with an empty cutout where a weight would be
Indifferent on dip switches
Offline vegs
« Reply #71 on: Fri, 22 December 2017, 11:13:41 »
  • 6 deg
  • Nothing, no strong opinion
  • Yes!
  • No need (I will be getting the nordic version anyways which doesn't have dip switches)
hhkb 4 life
buy less
Offline afrokobe
« Reply #72 on: Fri, 22 December 2017, 11:32:51 »
bring it on, I'm game
Offline braidn
« Reply #73 on: Fri, 22 December 2017, 11:55:16 »
No feet flappers engaged. Totally flat. Love it at that angle.
Offline mason
  • have fun with her, ryan
« Reply #74 on: Fri, 22 December 2017, 12:12:07 »
FLAT
Offline xondat
  • i'm not a star
« Reply #75 on: Fri, 22 December 2017, 12:40:11 »
So far:
  • There are more for 6 degrees (more than triple), so I can see it going that way. I personally use raised, so I might figure out a solution that isn't ugly.
  • Still not sure on the branding. I think it's nice, but not sure if it's needed.
  • Brass is even so far, so keep the thoughts coming in. I'm still not sure on this so all opinions are valued :-*
  • Pretty clear where people stand with the dip switch cutout, everyone is either no or indifferent. There will be no cutout.
Another thing I've mostly decided on is the connector; I'd like to use USB C. It makes sense to move to as it's just the better connector, but not many have USB C cables (however I don't think this should be a main argument in not moving to adoption).
Any strong feelings on either side? LMK.
Offline Wetherbee
« Reply #76 on: Fri, 22 December 2017, 12:43:15 »
I made a commitment this year to not buy any electronics in 2018 unless it had USB C. New years resolution. The custom cable makers will eventually catch on once we reach critical mass and regular USB C cables are plentiful, affordable, and no longer have early adopter issues with missing resistors.
« Last Edit: Fri, 22 December 2017, 12:45:56 by amoswetherbee »
Offline afrokobe
« Reply #77 on: Fri, 22 December 2017, 13:15:14 »
i like usb-c but its not a deal breaker for me
Offline norbauer
  • Plz email shop@norbauer.com; I miss PMs sometimes
    • Ryan Norbauer's personal site
« Reply #78 on: Fri, 22 December 2017, 13:20:49 »
This project is awesome! 2018 is the year we Topre nerds take over the keyboard world! <3
Offline pvd
« Reply #79 on: Fri, 22 December 2017, 15:35:40 »
If the case and programmable controller support a 91u JIS realforce, I would be very interested  :cool:
Offline xondat
  • i'm not a star
« Reply #80 on: Wed, 27 December 2017, 19:32:02 »
Sending my RF in a day or two so that the breakout board can start development :D
Main goal is programmable, with the secondaries being a bit more advanced (genuinely don't know if they're possible, but aim high). The two musts are USB-C and being a "bolt on" mod (aka only having to plug it in, no modification of anything original needed, and can be reverted).
Still not sure on the weight or branding. Weight will most likely be a price thing, so got to figure that out later on.
Offline le_wraith
« Reply #81 on: Wed, 27 December 2017, 19:36:35 »
IN BETWEEN
I'D LOVE THE OPTION OF A BADGE WITH "NOXARY-RF" OR SOMETHING LIKE THAT, AS LONG AS IT'S MINIMALISTIC AND LOOKS DOPE . WHEN IT COMES TO A REALFORCE, I WANT IT TO LOOK EVIL AND MYSTERIOUS IN A SOMEWHAT LO-FI WAY, SO THE BADGE HAS TO WORK WITHIN THAT AESTHETIC
  • Brass weight?
YES!!! I SEE THIS AS CRITICAL. HEAVIER & BRASSIER = BETTER
NO.
[/list]
« Last Edit: Wed, 27 December 2017, 19:41:29 by le_wraith »
Offline xondat
  • i'm not a star
« Reply #82 on: Tue, 02 January 2018, 10:08:51 »
Hey, got a question for everyone -
I have concerns with long prototyping turnaround with my current manufacturer, it'd delay this for a month upwards. The reason I would prototype is so I know everything physically works. We already know the quality with the manufacturer is very good, so that isn't a thing that I'd be testing.
My current thoughts are to either look locally for a CNC aluminum prototype, or to look into 3D printing. Not sure whether I'd anodize the aluminum prototype, as it would take time for no physical change. Only downside is that people are usually judging whether to join a buy because of what the finished product looks like, and I won't be able to show that. Let me know your thoughts please.
In short: alternative prototyping to save time, prototype may be "uglier", but no massive waiting periods. Thoughts?
Offline pixelpusher
« Reply #83 on: Tue, 02 January 2018, 10:22:27 »
I'm fine with raw aluminum for prototype.  LZ boards have run this way, no?  Just show the raw cnc case and show images of the finish from the x60 stating they will be done by the same factory.
Offline dgneo
  • Supervillain
« Reply #84 on: Tue, 02 January 2018, 10:23:47 »
Personally think it's a good idea, seeing as it's just a prototype
Offline avid
« Reply #85 on: Tue, 02 January 2018, 10:46:20 »
Raw prototype is good.
Offline dreamx420
« Reply #86 on: Tue, 02 January 2018, 10:50:49 »
+1 for raw prototype
Offline le_wraith
« Reply #87 on: Tue, 02 January 2018, 10:51:27 »
I agree with the idea of alternative (raw or 3d printed) prototyping. How much faster is 3D printing than a raw aluminum prototype? If 3d printing is significantly faster it might be the way to go (albeit the downside is that people will have less of an idea of what the finished product might look like than if you did the aluminum prototype).
« Reply #88 on: Tue, 02 January 2018, 11:34:27 »
it's a new factory (i hope)
koreans usually do raw prototypes cause they've had the same shops for ages
a lot of early boards were prototyped in wood, not aluminum
Offline xondat
  • i'm not a star
« Reply #89 on: Tue, 02 January 2018, 11:47:10 »
Same factory as 268, Klippe, Fjell etc. This is not the same factory as X60.
@le_wraith, I haven't looked into 3D printing personally, but I know of people that've had same week order to delivery.
I just spoke to Leandren, and it's realistic to get samples made in 3 weeks. 268 took longer because of a mistake they made (I must've missed this info earlier on which has lead to my above question).
Thanks for the feedback all, every comment is valuable at this stage :-* If you have anything you want to say about the design, or breakout PCB etc, please do so.
Tiny update on the angle of the board, I've been using 6 degrees/flat for the past couple of days and I think I'm used to it, so the XRF will 95% be stock 6 degrees. I'm still interested in pursuing something to raise it for 9 degrees, but it has to be done perfectly otherwise it won't make it to production. I've yet to think of a decent way to do it, so if you really want 9 deg, and you think you have an elegant solution, let me know!
Offline avid
« Reply #90 on: Tue, 02 January 2018, 12:33:48 »
design:
-do not like the "realforce" logo cutout. Would much prefer a clean front.
-have you considered making the side edges thicker?
Rest looks really good  :thumb:
« Reply #91 on: Tue, 02 January 2018, 12:35:14 »
design:
no more huge bezels pls thanks
Offline xondat
  • i'm not a star
« Reply #92 on: Tue, 02 January 2018, 12:48:54 »
design:
Cutout - fair. If I can afford two tops, I will get one with, and one without.
Side edges - why? I'm aiming for minimum change from the stock case, whilst keeping my aesthetic.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #93 on: Tue, 02 January 2018, 13:18:50 »
I'm really into this board because it stays true to the original case, I Really like the cutout idea as well, it adds something to an otherwise empty forehead.  :p
Offline xondat
  • i'm not a star
« Reply #94 on: Fri, 19 January 2018, 23:47:32 »
Minor update.
Spent the past 5 hours redoing most of the fundamentals, this'll be close to what the sample looks like. Still got a couple things to do though. I hope to have one in time for the UK meetup ^-^
Nothing really looks different (as with all my things when I start again) so I'll explain a little.
  • I updated the mockup plate to a normal 86u layout so I don't confuse anyone again.
  • Removed name tag for now, not sure whether I want it there or not.
  • Finally placed USB position, it's now in the standard horizontal position as A.87.
  • Added place for the breakout PCB too.
  • Mounting now just makes more sense, was a little weird before.
  • Actually added screws to hold the case together.
  • Kept it 6 degrees.
  • Increase chamfer + rounded edge sizing to make it look a little smaller & neater.
  • Kept it low, think it's a 16mm front face.
  • Lots of other minor things that aren't worth going into :confused:
Next "goal" is to finish the USB cutout, just need to get a cable from my girlfriend before doing that. Fitment must be perfect :))
Now for some potentially bad news.
I won't be going forward with the brass weight. I want to keep it simple in order to keep the price down. I don't think the case needs to be $300+ considering the cost of the internals anyway. Still toying with the idea that Duck uses (having a cutout but no weight), but I'd make the brass optional. Not sure.
The worst news is that I'm not sure when I can run the group buy. I was going to get it going relatively soon, but as I've unexpectedly started X60 R, I cannot have more than 2 GBs open at once (a rule enforced by the mods for decent reasons). So either I run this off GH, or wait a couple months (or longer, depending on when I complete 268).
On that topic, someone has asked if they could pay for an extra prototype for them to have, which I'm completely fine with, so if that's something that's interesting, then you know what to do.
Sorry for the ramble, but that's everything I have to update on! :-*
« Last Edit: Fri, 19 January 2018, 23:55:26 by xondat »
Offline megaforce
« Reply #95 on: Tue, 23 January 2018, 21:50:06 »
Don't listen to the normies about not having a brass weight all the way through -- do it -- stay true to the Noxary line. Have a brass weight all the way through.
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline le_wraith
« Reply #96 on: Tue, 23 January 2018, 22:22:36 »
+1 brass weight / normie hate
Offline MMKB
« Reply #97 on: Wed, 24 January 2018, 00:16:30 »
Without a chamfered edge at the bottom or a strap you will never be able to pick it up.  ;)
« Last Edit: Mon, 29 January 2018, 12:44:34 by MMKB »
Offline xondat
  • i'm not a star
« Reply #98 on: Sun, 28 January 2018, 09:39:28 »
Sent off the files for the first prototype last night. I'm hoping it'll be possible to get it before I go to the UK meetup later next month (on the 24th).
This will hopefully be the 1st of the 2 prototypes I plan to do. This one is mainly getting the fundamentals down (plate fitment, bezel fitment, general PCB component clearance, etc). The 2nd prototype will focus on refining everything (such as typing feel, breakout board fitment, USB hole, etc).
Hopefully there will be pictures very soon :))
Offline pixelpusher
« Reply #99 on: Sun, 28 January 2018, 12:09:24 »
Thanks for the update.  I've been dome swapping my 87u over the past few weeks.  Started with light BKE redux, then ultralight.  Probably putting stock 55g domes back in tomorrow.  They're just so elegant.  Looking forward to the prototype!
