Author Topic: [IC] GMK SkIIdata (March 13 Launch)  (Read 130176 times)
Offline mimalik
Re: [IC] GMK Skidata (official name TBD)
« Reply #200 on: Mon, 24 September 2018, 20:04:46 »
TKC, have you decided on kits for this? Will orange mods be part of base or separate kit? If you are planning to offer orange mods as separate kit, then please consider the complete mod kit with numpad mods in orange.
The original skidata orange mod kit didn't include full coverage for 75%. Was missing the right column of keys in the correct profiles
I’m mobile so I can’t share the files. BUT I was planning to basically copy Terminal R2 and change the green to orange. So there would be a base kit, all N9 with orange legends. Then an orange modifier kit. On the fence about the 40 kit we did; not sure this will have the same steam that Terminal gets.  I’d also like to do relegendables like the last Skidata ha.
Any thoughts?
Just saw the terminal at your portal, love the mods setup. Just one suggestion. Could the rest of mod keys over arrows section also be offered in orange (in del, home ...)? I would love to have full orange mods section  for that full uniform mod look. It may increase the cost but I am sure we have enough orangephiles in community to gobble it up.
Offline avid
« Reply #201 on: Tue, 25 September 2018, 08:24:51 »
Please include blue enters (ISO ANSI) in the orange modifier kit  :thumb:
Would also love the sublegends on keys like Q and M to be the same as OG skidata.
« Reply #202 on: Tue, 25 September 2018, 09:22:26 »
"TBD" is a weird name for a set. Why choose that?
"The Big D"?
Offline enrique.aliaga
« Reply #203 on: Tue, 25 September 2018, 10:31:22 »
"The Big D"?
I don’t know whether you’re joking or not, but... TBD is “to be defined”. That is, there’s no official name yet.
« Last Edit: Tue, 25 September 2018, 14:13:49 by enrique.aliaga »
Offline Waateva
« Reply #204 on: Tue, 25 September 2018, 10:34:49 »
"The Big D"?
GOOD point
Offline P1kas
  • AKA Crono
« Reply #205 on: Tue, 25 September 2018, 12:20:10 »
Terminal R2 color kits, like the Skidata R1 GB, do not have full support for 75%/65% right column.
In fact, the Terminal R2 color mod kit is missing some keys that were included in the first Skidata GB.
Skidata Round 1 color kit had R1 Print Screen, Scroll Lock & Pause/brk.
I would love to see these, plus R1 Delete and either:
R1 Home, R2 PgUp, R3 PgDn, R4 End
or
R1 Home, R2 End, R3 PgUp, R4 PgDn
These would allow full orange coverage of 75% and 65% boards' right hand side, pictured here:
https://cdn.discordapp.com/attachments/299585906900205568/494196397344686094/Screen_Shot_2018-09-25_at_1.19.51_PM.png
« Last Edit: Tue, 25 September 2018, 13:24:41 by P1kas »
« Reply #206 on: Tue, 25 September 2018, 12:23:29 »
"The Big D"?
I don’t whether you’re joking or not, but... TBD is “to be defined”. That is, there’s no official name yet.
Ah, so To Be Defined is the unofficial name? Why'd you pick that name? Is it a code/reference to what may be the official name down the road?
I think the name "SD" (SkiData) is a better acronym than "TBD"; the latter can be euphemistic.
Offline TheKeyCompany
  • Because You Need the Feels...
    • The Key Dot Company
Re: [IC] GMK SkIIdata
« Reply #207 on: Wed, 03 October 2018, 12:16:20 »
Hey everyone. I completely revamped the post. Lets get this ball rolling again.
For those truly interested, please give it a look / read, fill out the new form, and spread the word!
Thanks for your patience. I love you all.
-M1keHonch0
« Reply #208 on: Wed, 03 October 2018, 12:26:16 »
First of all, thanks for the update and your dedication to the project!
Second of all... Can’t we get the blue accents in the base kit? I sure am not the only one who couldn’t care less for orange mods, but really digs the blue keys.
Offline DJSwayde
« Reply #209 on: Wed, 03 October 2018, 12:31:18 »
I'm guessing it's because the original run also had the blue keys in the color pack.
60%: CannonKeys Bakeneko60
BUILD 1: Black | FR4 plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
BUILD 2: Black | 1upkeyboards π60 (pi60) PCB | 1upkeyboards FR4 plate | Akko Rosewoods | HammerWorks CRP R6 Egyptian Alphas kit & CRP R7 kits (40%, 60%, Spacebars, Stepped Modifiers) keycaps
 | GEONWORKS Frog Mini
Silver | HHKB | 4pplet Steezy60 (Alps) PCB | Custom SS plate | Alps SKCL Yellows | Canon S-14 & S-16S keycaps
| GEONWORKS LAUNCHER60
Silver | Custom PCB | Custom SS plate | Alps SKCL Creams | C.Itoh CIT224F & IBM 5140 keycaps
| LSJ Ares
Silver | Custom PCB | Custom SS plate | Alps SKCL Browns & SKCL Amber | IBM Multistation 5556-CC1 (TW) & P70 (ANSI-US, 06-89) keycaps
 | LZ CLS h
Silver | Custom PCB | Custom SS plate | Alps SKCM Creams | MET Micro Officer 6000 (R315-00) & Zenith Data Systems TurbosPORT 386 keycaps
| MONOKEI Kei R1
Standard Red | Aluminum plate | Cherry Vintage Blacks & Vintage Grey (TX 55g springs) | Cherry G81-1291SAW & G81-3090SAQ (Schneider) keycaps
| SINGAKBD Unikorn R1
Black | Black aluminum plate | Cherry Retooled Blacks (TX 60g springs) | G80-3485LWNUS (Das Keyboard II) keycaps
| Wangus x KEZEWA Snake60 R2
Sage (re-anodized hot pink) | WKL | Custom PCB | Custom SS plate | NMB "Space Invader" (White one-eye linear [fourth generation]) | NMB RT-101 (NCD) keycaps
 | Weaston GSKT-00-Z
Silver | AEK HHKB | Aluminum plate | Alps SKCL Greens | Apple Extended Keyboard II (M3501, Taiwanese) & Standard Keyboard (M0116, US) keycaps
Pad: KBDFans KBDPAD MKII
Black | FR4 plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G80-3485LWNUS (Das Keyboard II) keycaps
| KBDMania KMAC Pad
Titanium grey | Aluminum plate | Cherry Vintage Blacks (TX 60g springs) | Cherry G81-3090SAQ (Schneider) keycaps
| Leopold FC 210TP
White | Custom PCB | Custom SS plate | Alps SKCL Compact Greens & Alps SKCL Browns | C.Itoh CIT224F keycaps
| Momokai Aurora
Cherry Vintage Blacks (TX 55g springs) | Cherry G80-3000LPCXY-2 keycaps
Topre: PFU Ltd. HHKB Pro 1 (PD-KB300BN)
hasu Alt USB controller | Topre Realforce 91UDK-G (NG02B0) & Realforce 103UB (SE42B0) keycaps
| PFU Ltd. HHKB Pro 2 (PD-KB400B)
hasu Alt Bluetooth controller | Purple sliders | 35g domes | Stock & Topre Realforce Taiwanese kit (dark gray) keycaps
| PFU Ltd. HHKB Pro 2 Type-S (PD-KB400WS)
4pplet SHKB Lite controller | 25g domes | Topre Realforce 87UW55 (SE08T0), Realforce 91UW (NE0100), Realforce Taiwanese kit (white) keycaps
| Topre Realforce 23U (WC0100)
Cipulot EC23U PCB | Purple sliders | SS plate (modified to allow for 24U) | 25g domes | JUKI Celavi keycaps
 | Topre Realforce 87UW (SE08T0)
Purple sliders | 30g domes | Sony BKE-9400A, MKS-8050, PVE-500, stock keycaps
| Topre Realforce 91 (NE0100)
Cipulot RF R1 8-9Xu PCB | 30g domes | JUKI Celavi & Topre Realforce 108UG-HiPro (YK0100) keycaps
Other: Apple Desktop Bus Keyboard (C658-4081) (CA)
Alps SKCM Oranges & SKCL Lock Cream
| Apple M0110A (US)
Beige | Vortex ViBE (US) (case installed inside) | Custom PCB | Custom SS plate | Alps SKCM Blues | Hewlett Packard HP Portable Vectra CS (US) & R/332 Instrument Controller (US) keycaps
| KUL ES-87
Black | Keygeek Su Color V2s (45g) | MW Heresy (with Gluttony & Envy kits) keycaps
| Zuoya HE30
Black | Hotswap: Keytok Novas / Wooting Lekker Tikken Mediums | Ranked POM keycaps
Collection
« Reply #210 on: Wed, 03 October 2018, 12:38:42 »
Youre welcome! Its long overdue.
Thanks for the feedback! Can you please put the feedback in the form so I can keep track of it all. Its a change we could certainly consider.
Offline young_won
« Reply #211 on: Wed, 03 October 2018, 20:14:50 »
i'm interested in
Offline iNViSiBiLiTi
« Reply #212 on: Thu, 04 October 2018, 00:17:38 »
just noticed this IC.  Def in.  Skidata's the only GMK set I'm willing to buy.
60%: Prophet, GSKT-00 x2, Poly GSKT-00-Z, Weaven, Sangeo60, Unikorn R2.1, Ciel60, DNworks DM
TKL: TGR Jane V2, Jane V2 CE, KFE, Noxary 280 S, Acrylic Unicorn, Igris V1, LZ-GHv2, Bias R2, HMKB
Misc: Bulgogi Board (VA104M), Belle En Rose, Treeleaf 917, TGR 910 ME, ai03 Vega
Offline portbaron
« Reply #213 on: Thu, 04 October 2018, 01:18:27 »
Good name.
| LIVING THE 1800 LIFE |
Offline clasicks
  • Formerly KeyboardUser4
« Reply #214 on: Thu, 04 October 2018, 09:46:47 »
interested!
Offline holtenc
« Reply #215 on: Mon, 08 October 2018, 15:42:40 »
A rare GMK set with proper 40% support. I would be in.
Offline DJSwayde
« Reply #216 on: Tue, 09 October 2018, 10:20:18 »
Have you given any thought to adding an international kit?
| LSJ Ares
 | LZ CLS h
| MONOKEI Kei R1
| SINGAKBD Unikorn R1
 | Weaston GSKT-00-Z
| KBDMania KMAC Pad
| Leopold FC 210TP
| Momokai Aurora
| Apple M0110A (US)
| KUL ES-87
| Zuoya HE30
Collection
Offline P1kas
  • AKA Crono
« Reply #217 on: Tue, 09 October 2018, 10:24:04 »
I am extremely glad to see you've added support for the right column on 65/75% layouts.
One question:
What are the stepped R4 keys meant for in the orange mod kit?
Offline dantambok
« Reply #218 on: Tue, 09 October 2018, 10:25:24 »
i'll prolly be poor when this comes out but so happy to see this alive again!
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
« Reply #219 on: Tue, 09 October 2018, 10:43:22 »
One question:
Windowed keys. One of them is in the wrong row though, Ill get it fixed before we run.
Offline P1kas
  • AKA Crono
« Reply #220 on: Wed, 10 October 2018, 08:14:53 »
Okay, so I took another look at the orange mod kit.
I believe we're still missing this small cluster of caps:
205191-0
The R1 Home key is particularly important for a 75% column consisting of:
R1 Delete
R1 Home
R2 PgUp
R3 PgDn
R4 End.
Aside from that, I have a question:
205193-1
What layouts are these R1 End and R1 PgDn supposed to be used with? I can't think of any off the top of my head. These two caps are also present in the orange mod kit
« Reply #221 on: Wed, 10 October 2018, 08:20:19 »
R1 Delete
R1 Home
R2 PgUp
R3 PgDn
R4 End.
I look at adding that cluster.
The keys you question are used on 1800 layouts.
Offline P1kas
  • AKA Crono
« Reply #222 on: Wed, 10 October 2018, 08:24:09 »
Oh, that makes sense.
One other thing I was wondering about:
205195-0
I understand that some layouts use 1u ctrl/alt on the right side of the bottom row. Do any layouts require two 1u alts or two 1u ctrl?
Offline portbaron
« Reply #223 on: Wed, 10 October 2018, 12:21:38 »
cherry g80 1800
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #224 on: Thu, 11 October 2018, 16:29:18 »
Any chance for a r3 1u icon return for a Planck? I know it isn't the standard Planck layout but I think it is a fairly common option.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #225 on: Thu, 11 October 2018, 19:29:20 »
Also 1800 (certain variants that uses the full mod row with 6u spacebar)
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline P1kas
  • AKA Crono
« Reply #226 on: Thu, 11 October 2018, 23:12:13 »
Alright, thank you for the clarification.
Offline haydoselefantes
« Reply #227 on: Fri, 09 November 2018, 11:45:44 »
I assume the SkIIdata orange is not the same as the GMK Carbon R2 orange.     Has anyone compared the R1 carbon to the original skidata?  Do they clash or complement each other?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #228 on: Fri, 09 November 2018, 11:49:17 »
The grey is not the same so they will clash to some degree.
Offline Kawamashi
« Reply #230 on: Fri, 09 November 2018, 17:05:05 »
Offline equalunique
« Reply #231 on: Mon, 19 November 2018, 23:09:36 »
Any possibility of an ergoplanck kit?
Sent from my LG-H918 using Tapatalk
Offline Kawamashi
« Reply #232 on: Tue, 20 November 2018, 03:11:03 »
It would be great !!!
Offline kevinzavier
« Reply #233 on: Mon, 10 December 2018, 20:20:21 »
when is this planned to run?
« Reply #234 on: Thu, 03 January 2019, 08:15:17 »
Happy New Year. The holidays are over. Vomageddon 2018 has subsided. Im ready. Are you ready? Lets bring this project back to life!
Whats say go live February 2019?
Im going to be working on the layouts a little bit this week (and shipping the TKC1800s out). Stay tuned for updates!
Offline holtenc
« Reply #235 on: Thu, 03 January 2019, 08:32:28 »
nice
Offline dantambok
« Reply #236 on: Thu, 03 January 2019, 08:33:23 »
YES and YES!
Stuff  I have
100+ GMK sets
Re: [IC] GMK SkIIdata (Goal February 2019 Launch)
« Reply #237 on: Thu, 03 January 2019, 09:01:23 »
Hooray !!! So excited!!
Offline nasp
« Reply #238 on: Thu, 03 January 2019, 09:14:20 »
Filled out the IC form.
Some renders on the first post would be nice, even if they were renders of round 1. I think it gives a much better impression of what to expect this set to look like on a keyboard.
« Reply #239 on: Thu, 03 January 2019, 14:42:53 »
Renders will come forthwith as soon as the kits are decided upon. If you want to see what Skidata looks like on a board just do a search on Reddit. There should be a bunch!
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #240 on: Mon, 07 January 2019, 09:32:26 »
NEED THIS!
Offline whytwokay
« Reply #241 on: Mon, 07 January 2019, 11:46:16 »
I can't wait for the group buy for this set! I'm definitely in for the base and relegendables kits!
I don't think the blue spacebars kit goes particularly well with the orange/black theme, though. Black (and/or possibly orange) keys in that kit would be a better match in my opinion. The base and 40's kits look great, though!  :thumb:
Offline RETURNISO
  • I do get excited about keyboard stuff..
« Reply #242 on: Mon, 07 January 2019, 14:01:34 »
Offline dantambok
« Reply #243 on: Mon, 07 January 2019, 17:43:41 »
does this set use stock or custom colors?
Stuff  I have
100+ GMK sets
Offline ArchDill
« Reply #244 on: Mon, 07 January 2019, 17:47:50 »
This set is always going to remind me of Leandren haha
Offline Emir
  • icon mods
  • Bandit
    • Discord
« Reply #245 on: Tue, 08 January 2019, 01:13:42 »
Standard GMK Colors N9 with V2. The accent blue is N5.
Offline dantambok
« Reply #246 on: Tue, 08 January 2019, 02:44:08 »
that means only an MOQ of 150 right?
Stuff  I have
100+ GMK sets
Offline Vigrith
« Reply #247 on: Tue, 08 January 2019, 09:37:44 »
Yes, however I don't think any sort of rendition of Skidata will have trouble hitting higher MOQs if it were to be necessary for basically any of its kits. It's such a popular set and TKC are a well respected, trusted brand given their track record who work with other competent proxies, this is going to be a hit for sure.
Offline KaosJ
« Reply #248 on: Tue, 08 January 2019, 16:30:09 »
If the base set would contains basic accents (ESC/ENTER vertical and Enter Horizontal) i would probably join.
In the style of the GMK Terminal
« Reply #249 on: Tue, 08 January 2019, 16:38:03 »
Yes please! Basic accents in the Base set would be great! I’d hate to have to buy a *whole* expensive Modifiers set just to use an orange Esc and an orange Enter.
« Last Edit: Tue, 08 January 2019, 17:16:28 by enrique.aliaga »
