Author Topic: Are there switches that will fit  (Read 2989 times)
Offline Harmvdw
« on: Fri, 22 December 2017, 04:34:06 »
Hi,
I found a old "keyboard" of a fanuc milling machine. It has omron B2R switches.
I want to use the keycaps to make a numpad. I have searched but can not find a fitting switch.
The stem is 5mm square.
The omron switches are to high.
Does anyone know a fitting switch? Or should i make adapters?
Here are the photo's
https://photos.app.goo.gl/uz5G30RozhJvcZTl2
Thanks for looking
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Are there switches that will fit
« Reply #1 on: Fri, 22 December 2017, 07:36:54 »
Those are Omron magnetic reed switches.
I think they are still in circulation.
Offline Harmvdw
« Reply #2 on: Fri, 22 December 2017, 07:41:53 »
Yes i know, i have the switches, only they are very high, en i would like some "normal"switches witch would fit the keycaps.
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Fri, 22 December 2017, 08:23:09 »
No, the mount appears to be unique.
