Author Topic: G80-1000/HBU Connection Problems  (Read 2020 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Sat, 23 December 2017, 19:29:20 »
My above keyboard will not talk to either of my Windows 10 machines with 2 different converters? Dip is set to PC, however just get a couple lights and nothing else. Anybody have any suggestions............ :-\
All of my other older boards still communicate with the converters I have been using for years :thumb:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: G80-1000/HBU Connection Problems
« Reply #1 on: Sun, 24 December 2017, 11:29:58 »
Where the DIP switch is set to "PC", what alternatives are there? Where is this DIP switch?
Bore Awards
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Mon, 25 December 2017, 18:31:22 »
It is underneath or the back side and is set to PC? Might try buying another converter, but other than that I don't know what to do with it? I took it apart and everything is soldered tight and clean. I was a mechanic at 1 time and electronics are not my strong suit-- might need to find a Jedi on the Forum to send to and trouble shoot?
If I push CAPS, etc. I just get an intermittent light :-\
Merry Christmas!!
  • RIP
    • Boring twaddle
« Reply #3 on: Mon, 25 December 2017, 18:48:41 »
What alternatives are there to "PC"?
The idea that any G80-1000 keyboard has DIP switches is new to me, and I'm not seeing any suggestion that this is true, so I have to wonder what exactly you've even got there.
"PC" could mean "XT", in which case there could be an "AT" alternative (which would be what you'd want if this were the case), but it could be "PC" as in PC vs Mac/Amiga/Sun/anything else.
Bore Awards
