Author Topic: [GB] AL1 (Shipping, QMK Codes Open Sourced)  (Read 145942 times)
Offline Peppermint216
Re: [GB] AL1 (Shipping, QMK Codes Open Sourced)
« Reply #350 on: Sat, 12 May 2018, 12:40:26 »
I finallygot a tracking number, shipper is other... I am not sure where I can check its stauts
DHL was used I believe.
Offline forumusername
« Reply #351 on: Sat, 12 May 2018, 12:43:18 »
That was it thank you very much
« Reply #352 on: Tue, 15 May 2018, 10:52:11 »
Shipping from Taiwan?
DHL just text me wanting £27 tax but I don't know what for other than its come from Taiwan.
Offline xondat
  • i'm not a star
« Reply #353 on: Tue, 15 May 2018, 10:56:03 »
Someone said Hong Kong proxy
Offline prozach
« Reply #354 on: Tue, 15 May 2018, 11:50:19 »
Any word on the re-ano for the folks that got the "new color"
Offline noricon
« Reply #355 on: Tue, 15 May 2018, 11:51:51 »
Nothing for me atm.
Offline Petch
« Reply #356 on: Tue, 15 May 2018, 12:29:47 »
I thought these were supposed to get marked down
« Reply #357 on: Tue, 15 May 2018, 12:34:39 »
Without any devalue it would be at least £60. Assuming it is the AL1, I have too many things coming.
Offline floris
« Reply #358 on: Tue, 15 May 2018, 16:59:02 »
Was valued at $100 on my package
« Reply #359 on: Tue, 15 May 2018, 17:02:53 »
Can you check your old tracking and see if it departed from Taiwan please?
Offline floris
« Reply #360 on: Tue, 15 May 2018, 17:05:06 »
Departed from Hong Kong
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #361 on: Wed, 16 May 2018, 06:23:24 »
Mine also came from HK
Sent from my mobile using Tapatalk
« Reply #362 on: Wed, 16 May 2018, 09:36:29 »
Now I'm really curious to know what it is, coming Friday.
Offline homerowco
    • Homerow.Co
« Reply #363 on: Wed, 16 May 2018, 16:35:01 »
Undervalued to $100 is perfectly fine with me. I have to pay 23% so best case $77, worst case if they add duty its another 9%, which appears to happen here randomly, then its 32% or $108... at $100 it's only $23, I can live with that :D
« Reply #364 on: Thu, 17 May 2018, 10:49:31 »
So my Taiwanese package arrived today. It was indeed the AL1.
Packaging was pretty bad, when the driver brought it I thought how is there a keyboard in this thin box. When I opened it the board was filthy, marks and dust etc, there was even a cobweb in the stiletto side bit.
After a clean-up I am pretty happy with how it turned out, my only flaws seem to be on the inside. The weight is a mess and oddly the underside of it is clean aside from the machining marks. All the visible exterior pieces seem ok but not flawless, passable for the price.
Some comparison photos with a blackbird below:
195807-0
195809-1
195811-2
195813-3
195815-4
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #365 on: Thu, 17 May 2018, 10:55:41 »
Good thing it arrived safely, despite the somewhat lacking packaging. Looks good.
« Reply #366 on: Thu, 17 May 2018, 10:58:41 »
Also, the gap between G and H on the plate :confused:
Offline Petch
« Reply #367 on: Thu, 17 May 2018, 11:25:46 »
In that last picture, the seam looks quite big towards the middle. Optical illusion, not tightly screwed together, or ???
« Reply #368 on: Thu, 17 May 2018, 11:27:50 »
No Illusions, that side will not close up  :(
Offline xZ3ROx
« Reply #369 on: Thu, 17 May 2018, 13:17:37 »
anyone experiencing wobble on a corner while typing? Ive tried adjusting the rubber things and also adjusting the tension of the screws...wobble remains on the right lower side.
« Reply #370 on: Thu, 17 May 2018, 13:57:51 »
This would be why....
Offline TriangleLab
« Reply #371 on: Fri, 18 May 2018, 10:52:33 »
Quick update:
Alsoran just shipped 5 kits (/u/homerowco, /u/terrymathews, /u/IIBorNotIIB, /u/Soggy_Stargazer, /u/speaktobrett). The photos look good to me. He will fill in the tracking numbers tomorrow.
There are totally 10 kits left including the replacement ones: Petch, /u/immaterium, odd, Oatburner, FeelHoodMuzik, noricon, MegalaDump, A10J12. These 10 kits, following replacement kits, and the 6 type 2 plates, are manufactured by ALF. The original factory did a bad work and was not cooperative so Alsoran asked ALF for help. I assume ALF will be much more reliable than the previous factory. 6 of the 10 kits have already been finished by ALF and are waiting to be shipped. ALF will ship the 6 kits to Alsoran for QC tomorrow. The left 4 kits need more time to be manufactured. I will have the name list of the 6 kits tomorrow.
I just travelled from the US to Shanghai, China this week. Was being pretty busy. Sorry for the late update.
If the kits you received have quality issues, please send me a PM. Don't send emails to me because I can't access gmail currently in China. You can also send photos to Alsoran (508881408@qq.com). He can't read English tho.
« Last Edit: Sat, 19 May 2018, 09:19:16 by TriangleLab »
Offline speaktobrett
« Reply #372 on: Sat, 19 May 2018, 16:59:12 »
Quick update:
I did change my order to black, and received email confirmation.
Very exciting! Thanks
« Last Edit: Sat, 19 May 2018, 21:56:13 by speaktobrett »
« Reply #373 on: Sat, 19 May 2018, 17:01:42 »
Triangle I think I PM'd you with photos from the kits I got but I can't see them in my sent messages... I don't want to spam you can you confirm if you received them?
Offline TerryMathews
« Reply #374 on: Mon, 21 May 2018, 22:14:02 »
Quick update:
So, how bout day tracking?
Offline DukeEsquire
« Reply #375 on: Tue, 22 May 2018, 10:43:06 »
@Triangle
I haven't seen any updates for my board yet and I don't see my name on the list of people waiting for their boards.
Can you please check?
Invoice #AL0027
« Reply #376 on: Fri, 25 May 2018, 10:32:35 »
Is there a way to 'fix' the blemished weights?
Sent from my PH-1 using Tapatalk
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #377 on: Fri, 25 May 2018, 10:38:34 »
You could try using a brass polish and seeing how that goes.
Offline Petch
« Reply #378 on: Fri, 25 May 2018, 10:38:50 »
Probably sand + repolish + recoat
Offline TriangleLab
« Reply #379 on: Fri, 25 May 2018, 21:04:15 »
The status of ALF-made AL1 kits (some are replacement cases):
Finished and will be shipped on next Monday:
odd,
/u/Oatburner,
 /u/noricon,
xZ3ROx,
LightningXI
Will be finished in the next week (estimated by ALF):
Petch,
/u/immaterium,
FeelHoodMuzik,
MegalaDump,
A10J12
These are all the remaining kit waiting to be fulfilled including the replacement cases required by buyers. Please tell me if you haven't received your kit and your name is not listed here.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #380 on: Fri, 25 May 2018, 21:05:54 »
odd,
/u/Oatburner,
 /u/noricon,
xZ3ROx,
LightningXI
Petch,
/u/immaterium,
FeelHoodMuzik,
MegalaDump,
A10J12
Thanks for the update. Will we receive shipment notification / tracking information as well?
Offline floristfran
  • I Wanted a foam bath and i got a slimy eel bath
« Reply #381 on: Sat, 26 May 2018, 07:36:55 »
i got a one of the new color, but it was also an extra, so was wondering if it shipped or when it is going to, just havent really seen anything about it on any of the lists.
Offline DukeEsquire
« Reply #382 on: Sat, 26 May 2018, 08:22:42 »
odd,
/u/Oatburner,
 /u/noricon,
xZ3ROx,
LightningXI
Petch,
/u/immaterium,
FeelHoodMuzik,
MegalaDump,
A10J12
Hi,
My name is not on there.
/r/flashcats.
« Last Edit: Sat, 26 May 2018, 08:24:18 by DukeEsquire »
Offline olivia
« Reply #383 on: Sat, 26 May 2018, 08:55:27 »
odd,
/u/Oatburner,
 /u/noricon,
xZ3ROx,
LightningXI
Petch,
/u/immaterium,
FeelHoodMuzik,
MegalaDump,
A10J12
Will the fixed option 2 plates ship after these?
Offline TriangleLab
« Reply #384 on: Sun, 27 May 2018, 04:58:36 »
Alsoran will fill in the tracking numbers on paypal. I can tell you your tracking number on Discord.
Offline TriangleLab
« Reply #385 on: Sun, 27 May 2018, 05:02:50 »
Hi,
/r/flashcats.
Will get back to you in 24 hours.
Offline TriangleLab
« Reply #386 on: Sun, 27 May 2018, 05:04:55 »
The fixed option 2 plates will be shipped about the same time as the last batch AL1 kits.
Offline TriangleLab
« Reply #387 on: Sun, 27 May 2018, 05:07:08 »
I have two unread messages on Geekhack but I can't read them right now.
When I click "messages", it says "Database Error. Please try again. If you come back to this error screen, report the error to an administrator."
Anyone know what's the problem?
« Reply #388 on: Sun, 27 May 2018, 06:01:17 »
Geekhack was not working at all for me yesterday, sound like it's having temporary problems.
« Reply #389 on: Sun, 27 May 2018, 08:18:20 »
PMs were from me. Let me know if you want me to communicate with you in another way.
« Reply #390 on: Sun, 27 May 2018, 08:36:43 »
I also sent a PM
Offline DukeEsquire
« Reply #391 on: Sun, 27 May 2018, 10:01:19 »
I actually sent two PMs myself.
Lol.
« Reply #392 on: Mon, 28 May 2018, 07:52:25 »
It seems like there is still issues with PM on Geekhack.
How else can we contact you TriangleLab
Offline prozach
« Reply #393 on: Mon, 28 May 2018, 23:37:25 »
Anyone building with Holtites or other sockets to make the board hot swappable?
« Reply #394 on: Tue, 29 May 2018, 12:46:32 »
@trianglelab is there an alternate way to contact you?
Offline noricon
« Reply #395 on: Tue, 29 May 2018, 15:16:32 »
odd,
/u/Oatburner,
 /u/noricon,
xZ3ROx,
LightningXI
Petch,
/u/immaterium,
FeelHoodMuzik,
MegalaDump,
A10J12
I have not received my shipping notification yet (not sure if next Monday is what I was thinking.) Is there a way to contact you via discord since GH seems to be broken at the moment?
Offline Carifio24
« Reply #396 on: Tue, 29 May 2018, 17:32:57 »
I'm sure this is mentioned somewhere, but I can't seem to find it: how do you put the keyboard into flashing mode for using DFU programmer?
Offline merlin64
    • MechMerlin
« Reply #397 on: Tue, 29 May 2018, 19:59:48 »
The manufacturer forgot to put a reset key in the default layout, they also omitted a physical reset key.
So the only way to do that is to short the pins on the atmega32u4....sigh.
Offline TriangleLab
« Reply #398 on: Tue, 29 May 2018, 20:00:58 »
I can receive emails now. I just bought a VPN account.
Offline TriangleLab
« Reply #399 on: Tue, 29 May 2018, 20:07:26 »
There are two pins between G and H keys. Using tweezers to short these two pins is the correct way.
