Author Topic: Rama USB3.1 A > C cable 1M + MiniB GB  (Read 7942 times)
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« on: Sat, 30 December 2017, 04:08:16 »
USB-C IN STOCK / MINI-B SHIPPING FEBRUARY
Product Name:
RAMA USB C-A 1M CABLE + RAMA USB MINI-B 1M CABLE
Part Number:
RAMA-CABLE-C-A-1M-431-01 / [/size]RAMA-CABLE-MINI-B-1M-431-01
Product Description:
Completely custom made Rama USB A-C / MINI-B 1 cable.
Custom moulded with X detailing + Rama logo on the opposing side.
Each cable includes a Rama Works Gunmetal Logo on a Signature Yellow sticker.
Product Color:
Pantone 431 - Grey
Product Length:
1M
Terminations:
USB-A > USB-C / MINI-B
Cable diameter:
4 MM
Spec:
USB 3.1 w/ 56k protection resistor // USB 2.0 (MINI B)
Buy here:
https://ramaworks.store
« Last Edit: Thu, 04 January 2018, 07:52:00 by KingRama »
Didn't notice my personal messages have been disabled for those thinking you have been blocked - to contact please reach out through Facebook messages or support email!
WEB: https://rama.works/
STORE: https://ramaworks.store/
INSTA: @ramaworks
FB: ramaworks
Offline roostrc0gburn
  • its just plastic
Offline Vigrith
Re: Rama USB3.1 A > C cable 1M + MiniB GB
« Reply #3 on: Thu, 04 January 2018, 11:42:31 »
https://www.monoprice.com/product?p_id=27932
but it doesn't say rama on it
Hole the mofukin phone roll dog, are you saying we may potentially be overpaying for branding, aesthetics and marginally (hypothetical) better quality here?
Call the police, this ****'s unexplored territory, Monoprice is gonna sue
Offline Data
« Reply #4 on: Thu, 04 January 2018, 13:53:36 »
Rama's packaging is always over-the-top good.   :p
King Rama, how long is the preorder window?  I want to get one of each.
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #5 on: Thu, 04 January 2018, 18:11:15 »
Not stopping anyone getting those! If that's what you want then go all for it - free market after all :)
What I'm doing here is much lower quantity than what those would be produced at.
Cheers Data! Preorder will be this month, but i'll probably start the production soon - I should have a good amount of stock either way :)
INSTA: @ramaworks
FB: ramaworks
Offline MikeTheTiger
« Reply #6 on: Fri, 05 January 2018, 07:23:53 »
Some people just don’t understand.  :thumb:
"all the numbers or none of them cmon man" -Kokaloo
Offline Shados
« Reply #7 on: Sun, 07 January 2018, 23:12:38 »
Ah, you might want to link the 3.1 version of that cable, not the 2.0 version. It's only marginally more expensive anyway.
...Also, anyone else find it a tad bit worrying that monoprice's cable comparison table has a row labelled "Maximum Power" that lists amperage?
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #8 on: Sun, 07 January 2018, 23:18:27 »
1 meter? what is this, a usb c cable for ants?
This cable needs to be at least 3 times bigger!
Offline KingRama
  • www.rama.works
    • RAMA WORKS®
« Reply #9 on: Mon, 08 January 2018, 04:11:15 »
Hahaha I'd totally do more lengths but each requires a new mould the way these are made :(
INSTA: @ramaworks
FB: ramaworks
