Author Topic: What VPN does everyone use?  (Read 71165 times)
Offline _rubik
« on: Sun, 31 December 2017, 13:22:40 »
Personally, I have been using Private Internet Access (PIA) for the past ~4 years and have no issue with it. There are great linux solutions, and they have a number of servers across a number of countries.
Most importantly... no logs!
https://helpdesk.privateinternetaccess.com/hc/en-us/articles/219457547-Do-you-log-the-traffic-of-your-users-
Offline atectatifern
Re: What VPN does everyone use?
« Reply #1 on: Sun, 31 December 2017, 14:34:48 »
Been okay with PIA for several years also, but sometime's it's a victim of its own popularity and its exit IPs get blocked. VyprVPN (comes with Giganews Diamond subscription) is good for tunneling out of restrictive networks that use IPS to block OpenVPN. Was able to get a connection out of my university with obfuscation ("chameleon protocol") when regular OpenVPN connections were blocked.
« Reply #2 on: Mon, 01 January 2018, 23:48:20 »
I use Windscribe - https://windscribe.com/
Free, 10GB a month limit, more than adequate for the little browsing I do.
Offline thad
« Reply #3 on: Mon, 08 January 2018, 06:58:07 »
I have been using Whatbox.ca  no issues so far.
Sent from my SM-G950U using Tapatalk
Offline _rubik
« Reply #4 on: Mon, 08 January 2018, 21:50:12 »
I've certainly run into their blocked exit IPs. I'll have to look at obfuscating OpenVPN connections. Wondering if that can be done by my pfsense router.
Offline SBJ
  • Tactile pls
« Reply #5 on: Tue, 09 January 2018, 06:44:03 »
I don't currently use a VPN but I used to use ExpressVPN.
Have nothing but positive things to say about them. If I recall a bit on the expensive side but I felt like the customer service was great and quick.
I'll be checking out the ones you guys recommend here and compare pricings etc.
Offline ander
  • I type, therefore I am
« Reply #6 on: Mon, 15 January 2018, 17:49:50 »
Sorry, I can't tell you. It's private.
Offline roostrc0gburn
  • its just plastic
« Reply #7 on: Mon, 15 January 2018, 18:14:54 »
nice try, NSA
Offline iri
« Reply #8 on: Tue, 16 January 2018, 07:43:49 »
A good one.
-Ray Bradbury
Offline _rubik
Offline Deephouse_jedi
« Reply #10 on: Thu, 07 June 2018, 14:14:14 »
I use PIA as well.
Offline floatingskull
« Reply #11 on: Thu, 07 June 2018, 14:34:45 »
Also a longtime PIA user but I'm switching over to Nord because it seems like less of the IPs are blocked. I can't connect to craigslist on PIA most of the time but it works fine with Nord, for example. Great price with PIA though.
Offline Pewpew
« Reply #12 on: Thu, 07 June 2018, 20:54:50 »
Use Hola. Free and stable.
Offline quazikun
« Reply #13 on: Thu, 07 June 2018, 23:30:57 »
vouch for PIA as well
Offline JianYang
« Reply #14 on: Fri, 08 June 2018, 04:32:02 »
Offline hilltopchill
« Reply #15 on: Fri, 08 June 2018, 10:11:40 »
I've been using NordVPN for the past couple of years, their prices are quite decent if you get a long term subscription when they're doing a sale. Easy to use interface, can also use it on my phone. Everything I need.
Offline feedbaack
« Reply #16 on: Fri, 08 June 2018, 11:29:54 »
I agree, NordVPN is doing a great job  :thumb:
Offline brianjking
  • always carry a towel.
    • @brianjking
« Reply #17 on: Fri, 08 June 2018, 17:23:45 »
NordVPN does seem great, I had a trial of it a bit ago and was nice and fast. Outline from Alphabet's Project Jigsaw is neat and I've tested it a bit. It's powered by Shadowsocks (socks5 proxy) and is opensource. Anyone try it out yet? https://getoutline.org/en/home
Offline 89sec
« Reply #18 on: Fri, 08 June 2018, 22:18:59 »
I currently use Private Internet Access, but I have lately been considering switching over to NordVPN.
Offline barrel
« Reply #19 on: Wed, 13 June 2018, 10:58:20 »
NordVPN, PIA and My own OpenVPN Based one hosted at my house in the Netherlands.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #20 on: Wed, 13 June 2018, 15:46:16 »
nice try, NSA
A good one.
Yeah, what they said. Pretty much the same response I had for the router thread :)
Offline fracno
« Reply #21 on: Sat, 16 June 2018, 19:39:28 »
Currently using Express VPN and seeing as how I have little to no experience with other services, I can't tell if it's considered good or not, haha. I tried tunnel bear and I think I prefer this. Helpful to be able to use on all my devices.
Offline FrostyToast
  • Litshoard
« Reply #22 on: Sat, 16 June 2018, 21:20:56 »
Currently using express and the speed seems to be good.
It is, however, more expensive than the other services by a significant margin so I am wondering if anything else compares.
All of the review sites I have checked list it as the fastest service but I wouldn't know by what margin.
Quote from: elton5354
Offline haanuman
« Reply #23 on: Mon, 18 June 2018, 03:49:42 »
I am using tunnelbear for a while now on my phone and pc as well. I know they give like limited usage but the speeds are never affected because of the VPN. Customer support is great as well. If you don't use much bandwidth then tunnelbear is great.
Offline oumakavoula
« Reply #24 on: Mon, 18 June 2018, 07:45:11 »
i moved from express to nordvpn because of the cost and beside the chrome extension that is better on express I prefer nordVPN
Offline Lanx
« Reply #25 on: Sun, 08 July 2018, 18:35:19 »
ipvanish, no logs and full download speed from not so nice places
Offline WireStart
« Reply #26 on: Mon, 09 July 2018, 02:37:46 »
I use NordVPN: nice speeds and many servers to choose from. Also based in Panama and out of 14 eyes jurisdiction which is a must for a VPN IMO. As someone mentioned the price is good if you are after the sale, for example this gives you a nice 77% off discount. Maybe it will be of use to someone.
« Reply #27 on: Fri, 27 July 2018, 16:34:58 »
Hello. I wanted to talk about one really obscure VPN called Surfshark VPN . . . (Surfshark hagiography and link to review snipped)
I'm impressed that a VPN reviewer/advertiser dug deep enough to find VPN threads on a keyboard forum.
Offline Coreda
« Reply #28 on: Fri, 27 July 2018, 16:44:05 »
Heh. I was also going to call out WireStart at the time but gave them the benefit of the doubt since I figured maybe they'd joined to give people a heads up on a discount and would engage otherwise with the community, but apparently not. They also registered on Reddit at the same time.
Offline _rubik
« Reply #29 on: Sun, 29 July 2018, 10:39:21 »
Talk about community outreach. Those google alerts must have a WIDE net.
« Reply #30 on: Mon, 30 July 2018, 05:51:55 »
Still using Windscribe, and it is still working as advertised.  They even send out email notification when the monthly usage is reset.
Offline nickhudson
« Reply #31 on: Mon, 30 July 2018, 07:21:27 »
I have been using PureVPN for 3 years, bought its 5 year deal on cyber monday.
Offline dgneo
  • Supervillain
« Reply #32 on: Mon, 30 July 2018, 08:24:38 »
none
Offline Jackorias
  • Jack, UK.
« Reply #33 on: Tue, 07 August 2018, 10:49:55 »
I use PIA because I got it with HumbleBundle.
Works fine for what I use it for, and ~£15 for the year was too good to pass up. Might look into renewing it, or moving to NordVPN when the year is up.
Offline method_
« Reply #34 on: Thu, 16 August 2018, 03:58:24 »
Personally I highly advise Nord Vpn, it's pretty fast compared to other solutions.
thock program.
Offline Flame
« Reply #35 on: Mon, 20 August 2018, 08:27:22 »
I've used Private Internet Access and Windscribe for the last ~2 years. PIA is the best in my opinion because they truly abide to their "logless" policy. Windscribe is pretty solid too, but they do keep a record of how much data is transferred within that month (not where the data is coming from, etc. as far as I know).
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #36 on: Wed, 22 August 2018, 06:00:08 »
Another vote for Nord. I got it a few months ago and it's worked great so far. I do forget to turn it off when I'm playing games and it slows down my PUBG loading a lot, but with everything else I have no issues.
Offline Polard55
« Reply #37 on: Thu, 06 September 2018, 06:32:07 »
Personally, I am using purevpn, and it's working great for me, Specially I use it for streaming and it works great after the update with platforms like Netflix and btsports. I have bought its 5-year subscription in $119, also you can read about it more in this purevpn review or check out other platforms.
« Last Edit: Fri, 19 October 2018, 03:13:31 by Polard55 »
Offline ctrl
« Reply #38 on: Wed, 17 October 2018, 03:24:03 »
Been using ExpressVPN for some time and it's the first VPN I've used so I don't have anything else to compare with. I lose connection often enough for it to be a hassle though and in addition to the price, I'm considering switching to Nord.
Offline kelvinpalmer
« Reply #39 on: Fri, 19 October 2018, 04:33:40 »
I purchased PureVPN because of its dedicated app over Linux after reading positive PureVPN user reviews over its website.
Offline patrickjburt
« Reply #40 on: Fri, 19 October 2018, 06:32:33 »
I've been using PureVPN for the better part of the year. I have 100/100 Internet and get about 50/50 with PureVPN.
« Reply #41 on: Sun, 21 October 2018, 20:44:56 »
That's a good point - to mention the speed you get through the VPN.
I only have ADSL2+ (not suffering under the NBN yet) and my speeds are usually about 10-20% slower through the VPN than a native connection.
Mine you, ADSL2+ is not exactly flooding the pipes :))
Offline FLFisherman
  • I'd rather be fishing.
« Reply #42 on: Sun, 21 October 2018, 20:49:58 »
I have a lifetime subscription to Windscribe. It seems to work for what I use it for (torrenting). Speeds are pretty good and I think it has a good privacy rating.
Offline no, the other guy
  • actually, this guy
« Reply #43 on: Sat, 27 October 2018, 17:42:02 »
I had been using Perfect Privacy for years. Simply awesome.
<armin> i have the impression the only reason the mx red switch was invented was drunk people
Unicomp PC122 (review) * IBM Model F XT * Dell AT101W
Offline onefivenine
    • Project Keyboard LLC
« Reply #44 on: Tue, 30 October 2018, 00:46:37 »
I’ve been using torguard for years with no issues. Bandwidth is fast and they have 50% promos all the time.
Offline John12Z
« Reply #45 on: Tue, 30 October 2018, 08:27:00 »
I used 3 VPNs in total. First ever was PureVPN. I even paid for that one. At one point it stopped working completely. It also never worked on Netflix and similar sites. I had to give up after 6 months using it despite paying for 1 year in advance (not very smart).
Then I switched to ExpressVPN and have been using that one too for around 6 months. I did not like their interface but it did seem to work just fine. Around June this year it started to have problems with Netflix too. Now I'm on NordVPN and it seems to be working just fine. I guess at some point all VPNs will be banned by sites such as Netflix. Here it's being claimed that Netflix will not be able to completely ban VPNs and it will always be a cat and mouse game. I do expect it to become worse in the future though, all they need to do is to create a region restricted website that requires region-specific payments for every country and then no VPN will help to unblock it. HBO already does this.
Offline _rubik
« Reply #46 on: Tue, 30 October 2018, 10:32:54 »
I'm a little blown away by how many 'users' posted on this thread with 1 post, and still only have 1 post...
Hmmmm... did I accidentally stumble into the magic words to summon the vpn bots?
« Reply #47 on: Tue, 30 October 2018, 10:34:18 »
Beep.
« Reply #48 on: Tue, 30 October 2018, 20:52:43 »
It happens from time to time.
A little while back we had a bunch of new members join (maybe as many as a couple of dozen), each made one post in New Members, and never came back.
And all the posts said, in a slight variety of different ways, that they worked for a large chemical company and liked keyboards.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #49 on: Sun, 04 November 2018, 11:34:02 »
Seems as though Firefox may or may not include some ProtonVPN integration in the near future. :cool:
