Author Topic: What kind of Gateron Browns used in Ergodox EZ?  (Read 2241 times)
Offline DuckNorris
« on: Wed, 03 January 2018, 11:21:51 »
Hello,
Does anyone happen to know what kind of Gateron Browns (3 pin , 5 pin etc) were used in the Gateron EZ and also how to tell of PCB mounter or Plate mounted? I am trying to take off the darn thing apart but it is not as easy as a Ergodox kit.
Thank you!
Offline davkol
  •  Post Editing Timeout
Re: What kind of Gateron Browns used in Ergodox EZ?
« Reply #1 on: Thu, 04 January 2018, 10:21:00 »
The first search result is this and there's also this review. Based on the pictures, plate-mounted 3-pin switches.
Offline DuckNorris
« Reply #2 on: Thu, 04 January 2018, 19:02:21 »
Thank you so much! That second review was EXACTLY what I needed to begin my project with this keyboard!  :)
