Author Topic: [GB] Evil 80 (finished production)  (Read 126928 times)
Offline cirrus82
Re: [GB] Evil 80 - GB Opens NOW
« Reply #50 on: Sat, 13 January 2018, 18:10:29 »
Offline nycxandy
« Reply #51 on: Sat, 13 January 2018, 18:48:13 »
Woops -- wrong thread!
Mods: please delete.
« Last Edit: Sat, 13 January 2018, 18:53:26 by nycxandy »
Offline nycxandy
« Reply #52 on: Sat, 13 January 2018, 18:52:58 »
Offline superhot
« Reply #53 on: Sat, 13 January 2018, 18:54:40 »
Ordere'd!
very exited for my first GB
Offline senter
« Reply #54 on: Sat, 13 January 2018, 19:02:15 »
GLWB :)
Offline zl_ramiel
« Reply #55 on: Sat, 13 January 2018, 19:06:02 »
Ordere'd!
Thanks for choosing Evil80 as your first GB. I'm sure you won't regret.  :thumb:
Offline superhot
« Reply #56 on: Sat, 13 January 2018, 19:17:54 »
I'm sure I won't!
Offline ristrettoboy
« Reply #57 on: Sat, 13 January 2018, 19:33:14 »
Ordered. Super excited for this!
Offline txclack
« Reply #58 on: Sat, 13 January 2018, 22:53:01 »
Order placed thank you
My main concern is making the back plate.  What program do I use to make the file necessary for perfect cutting
Sent from my SM-N950U using Tapatalk
Offline JubJubCity
« Reply #59 on: Sun, 14 January 2018, 00:34:19 »
Order placed super excited
Offline JubJubCity
« Reply #60 on: Sun, 14 January 2018, 00:42:08 »
Just wondering if i want to make a change in my order how would i go about doing so? I just want to change the weight to brass.
Offline lyk503
« Reply #61 on: Sun, 14 January 2018, 05:06:52 »
I'm in the middle of the ordering process. If I made a custom nameplate, where would I attach the file? Would I just send it to you separately?
Offline zl_ramiel
« Reply #62 on: Sun, 14 January 2018, 07:32:54 »
Check the template file. It's pretty simple.
You can also tell me the texts and font you want to cut. Then we can make the file for you.
Offline zl_ramiel
« Reply #63 on: Sun, 14 January 2018, 07:33:35 »
Changing options or submitting files are all through emails. I'll send an email to you shortly.
« Last Edit: Sun, 14 January 2018, 07:35:07 by zl_ramiel »
Offline JubJubCity
« Reply #64 on: Sun, 14 January 2018, 12:16:50 »
Thanks appreciate it
Offline HardcoreDesk
« Reply #65 on: Sun, 14 January 2018, 12:23:58 »
How many more spots are available?
Offline zl_ramiel
« Reply #66 on: Sun, 14 January 2018, 20:46:06 »
Someone were asking for the ai file of this logo.
I attached the file here if someone else need it.
Offline SpareWalrus
« Reply #67 on: Sun, 14 January 2018, 21:51:55 »
...we set the limited available number in this GB as 60...
Offline dr_derivative
  • Not a real doctor
    • OC Lab Discord
« Reply #68 on: Mon, 15 January 2018, 11:08:05 »
I'd be all over this if I wasn't broke right now  :'(
GH/Reddit/DT/Discord: dr_derivative | IG: dr_derivative_mk | Discord server: OC Lab
Offline Quantastrophus
« Reply #69 on: Tue, 16 January 2018, 09:39:04 »
Is there a possibility to get an aluminum nameplate but a brass weight?
Offline Latto
« Reply #70 on: Tue, 16 January 2018, 12:45:28 »
I ordered an extra nameplate and wondered if its possible to have it engraved with a different design? As in each plate having its own design? Also with the extra weight will it also have the logo on it? Thanks!
Offline zl_ramiel
« Reply #71 on: Tue, 16 January 2018, 15:24:03 »
Sorry that's not an option.
Sure you can have different designs on multiple nameplates.
Every weight part has the evil triangle logo.
Offline Latto
« Reply #72 on: Tue, 16 January 2018, 22:34:03 »
Perfect thanks!
Offline Latto
« Reply #73 on: Tue, 16 January 2018, 22:43:12 »
Oh and in what way is the nameplate attached to the board?
Offline zl_ramiel
« Reply #74 on: Wed, 17 January 2018, 08:26:07 »
attached by screws.
Offline wholypantalones
  • text and icon mods plz.
« Reply #75 on: Thu, 18 January 2018, 08:24:10 »
No idea if this was asked yet, but can we order a different color nameplate from the weight? Gray nameplate, black weight combo instead of black/black.
« Last Edit: Thu, 18 January 2018, 08:30:09 by wholypantalones »
Offline Latto
« Reply #76 on: Thu, 18 January 2018, 11:11:10 »
Offline PoisonHeadcrab
« Reply #77 on: Fri, 19 January 2018, 02:40:56 »
Does the PCB support individual RGB switch LEDs?
Offline zl_ramiel
« Reply #78 on: Fri, 19 January 2018, 08:01:53 »
No, they will be per switch single color LEDs like on most other QMK PCBs.
Offline JubJubCity
Re: [GB] Evil 80 - GB Opens (last one day left. LAST CHANCE)
« Reply #79 on: Fri, 19 January 2018, 15:56:39 »
Simple question, does the kit come with stabs?
Offline xondat
  • i'm not a star
« Reply #80 on: Fri, 19 January 2018, 15:58:13 »
Isn't mentioned at all so would presume not.
Offline JubJubCity
« Reply #81 on: Fri, 19 January 2018, 19:02:10 »
yeah that's what I noticed but figured I would ask as well.
Offline zl_ramiel
« Reply #82 on: Sat, 20 January 2018, 15:37:03 »
Stabs are not included.
Offline Latto
Re: [GB] Evil 80
« Reply #83 on: Fri, 26 January 2018, 14:27:27 »
Hello just checking in if I wanted to make a minor change to my order is that still possible? Thanks!
Offline zl_ramiel
Re: [GB] Evil 80
« Reply #84 on: Sat, 27 January 2018, 08:43:01 »
Just DM me or send me an email.
Offline JubJubCity
Re: [GB] Evil 80
« Reply #85 on: Thu, 01 February 2018, 18:21:34 »
Any news as to when production will start?
Offline zl_ramiel
Re: [GB] Evil 80
« Reply #86 on: Fri, 02 February 2018, 13:15:09 »
late this month.
Offline zl_ramiel
Re: [GB] Evil 80
« Reply #87 on: Fri, 02 February 2018, 13:16:16 »
For those who joined GB and chose custom cable, pls fill in the form using your email address: https://docs.google.com/forms/d/1IlrCos2mAxjrd2Qkb8mRS0wbhqUXnQbmmcXGkaXG_Yo
Offline JubJubCity
Re: [GB] Evil 80
« Reply #88 on: Fri, 02 February 2018, 15:54:53 »
Just filled out, great thanks for the update
Offline JubJubCity
Re: [GB] Evil 80
« Reply #89 on: Tue, 20 February 2018, 10:49:42 »
Any new updates regarding production?
Offline wixxzblu
Re: [GB] Evil 80
« Reply #90 on: Tue, 20 February 2018, 11:06:47 »
Its chinese new year, so probably nothing.
Offline JubJubCity
Re: [GB] Evil 80
« Reply #91 on: Tue, 20 February 2018, 12:12:46 »
Ah yes keep forgetting about that. Thanks for the info.
Offline JubJubCity
Re: [GB] Evil 80
« Reply #92 on: Wed, 28 February 2018, 14:38:22 »
Now that CNY is over, any update regarding production?
Offline pixelpusher
Re: [GB] Evil 80
« Reply #93 on: Wed, 28 February 2018, 14:42:25 »
I believe the holiday ends on March 2nd which is Friday.
Offline JubJubCity
Re: [GB] Evil 80
« Reply #94 on: Wed, 28 February 2018, 15:03:51 »
Thanks for the info need to remember this
Re: [GB] Evil 80
« Reply #95 on: Wed, 28 February 2018, 15:49:55 »
depends on where in china you are, some places have resumed business as normal
Offline JubJubCity
Re: [GB] Evil 80
« Reply #96 on: Tue, 06 March 2018, 14:43:59 »
Sorry to sound like a broken record but are there any new updates?
Offline mmontess
Re: [GB] Evil 80
« Reply #97 on: Fri, 09 March 2018, 00:15:41 »
I would also like some updates. Will there be an order check? I sent OP an email with a small change in my order, just wondering if it went through.
Offline JubJubCity
Re: [GB] Evil 80
« Reply #98 on: Sat, 10 March 2018, 12:26:49 »
Did you check the google doc sheet to see if the change was reflected?
link  https://docs.google.com/spreadsheets/d/1QKsLA6Cw5QfIQWeyis2h2wuinRqMaQSuRN8MBfDXqTY/edit#gid=0
Offline JubJubCity
Re: [GB] Evil 80
« Reply #99 on: Tue, 13 March 2018, 11:52:37 »
just received an email from huan which is the organizer of the group by regarding the status
"Yes, the EVE studio is being produced, and these days will be updated. I'm very sorry."
I'm assuming things are progressing with the production and we should have a update in a couple of days.
