Author Topic: Topre keycaps  (Read 4524 times)
Offline nogoodnames444
  • I like keyboards
Topre keycaps
« on: Tue, 16 January 2018, 15:21:36 »
I will be getting a type heaven soon i would to know if their are any full keycaps sets i can get
thanks!
Offline futurecrime
  • Get Zooted
Re: Topre keycaps
« Reply #1 on: Tue, 16 January 2018, 15:49:10 »
ebay seller widebasket has full sets in a few colours for Realforce.
  • I like keyboards
Re: Topre keycaps
« Reply #2 on: Tue, 16 January 2018, 15:58:51 »
Offline Deefenestrate
Re: Topre keycaps
« Reply #3 on: Sun, 04 February 2018, 09:23:12 »
Sooo expensive.
  • I like keyboards
Re: Topre keycaps
« Reply #4 on: Sun, 04 February 2018, 11:56:50 »
Sooo expensive.
I know I putting cherry sliders because the keycaps are so expensive
Re: Topre keycaps
« Reply #5 on: Sun, 04 February 2018, 14:22:48 »
Sooo expensive.
the KBDfans ones are the best ones you can easily find.
  • I like keyboards
Re: Topre keycaps
« Reply #6 on: Sun, 04 February 2018, 22:55:14 »
Sooo expensive.
Yeah I got the kbd fans ones cause they seemed like the ones that made the most sense
Offline tylernm
Re: Topre keycaps
« Reply #7 on: Sun, 11 February 2018, 01:14:43 »
How do the replacement cherry stems feel?  I heard they had some wobble and the stems where pretty tight and difficult to put caps on.
  • I like keyboards
Re: Topre keycaps
« Reply #8 on: Sun, 11 February 2018, 21:11:43 »
They are tight
