Author Topic: [GB] Noxary X60 R (Complete)  (Read 188201 times)
Offline exanile_tabasco
  • settling down
Re: [GB] Noxary X60 R (Cases Arrived)
« Reply #200 on: Sun, 30 September 2018, 19:38:44 »
yeetus it is time
Offline pixelpusher
« Reply #201 on: Sun, 30 September 2018, 20:49:58 »
I can haz my 268 that I paid for 8 months ago?   :p
Offline R4WBIT
« Reply #202 on: Mon, 01 October 2018, 01:21:12 »
Get in line :D still waiting for my ORIGINAL X60 top piece....
Offline Mcnos
    • GMK Fuyu
« Reply #203 on: Mon, 01 October 2018, 22:31:16 »
Give him time yo, or else your board will end up with issues.
Offline wholypantalones
  • text and icon mods plz.
« Reply #204 on: Tue, 02 October 2018, 16:04:45 »
Yipes.
Offline pixelpusher
« Reply #205 on: Tue, 02 October 2018, 16:09:59 »
My norbauer case is kinda like that on the top.  I pretend it's a cool texture
Offline nastrovje
« Reply #206 on: Wed, 10 October 2018, 07:26:05 »
Has anyone received their board yet?
Offline MMKB
« Reply #207 on: Wed, 10 October 2018, 09:53:02 »
Been waiting for my shipping invoice for more than a week.
Everything OK to ship, xondat?
Offline xondat
  • i'm not a star
« Reply #208 on: Wed, 10 October 2018, 12:44:10 »
Waiting on some hex keys so I can put the cases together. Want to make sure the threads are fine to avoid the 268 problems. Sorry for not posting that.
Offline MMKB
« Reply #209 on: Fri, 12 October 2018, 15:49:33 »
Oh so it won't be Phillips screws this time. I've both metric & imperial hex keys ready so hopefully I'll never strip my screws again.
Offline xondat
  • i'm not a star
« Reply #210 on: Fri, 12 October 2018, 17:54:30 »
They're metric M2 hex. I did slot for the last one but people complained about slipping and scratching the case so thought I'd go back to these as these look the second best.
Offline MMKB
« Reply #211 on: Mon, 15 October 2018, 19:08:28 »
 :-X
Offline kekstee
« Reply #212 on: Tue, 23 October 2018, 15:03:51 »
Offline Mcnos
    • GMK Fuyu
« Reply #213 on: Tue, 23 October 2018, 19:02:24 »
Offline xondat
  • i'm not a star
« Reply #214 on: Wed, 24 October 2018, 11:01:12 »
Bad news inc.
I got the hex keys and was testing the threads out. M2 screws do not fit into the bottom pieces. I asked my contact and he said "The holes are M2 threaded holes, the loose problem must be caused by several times anodizing".
This applies to all bottom pieces unfortunately. I'll be sending them back and they'll make new replacements.
As a general statement, I won't be using this factory again, although I think that goes without saying.
Offline kekstee
« Reply #215 on: Wed, 24 October 2018, 12:34:35 »
Threads? Bottom piece? Doesn't the bottom have through holes which could only be too tight?
Offline xondat
  • i'm not a star
« Reply #216 on: Wed, 24 October 2018, 12:48:38 »
It’s where the weight screws into.
Offline dyrdevil
« Reply #217 on: Wed, 24 October 2018, 12:55:53 »
Sad to hear that but I’m happy and thankful you checked it out before sending out the cases!
Offline Captainbuttmonkey
« Reply #218 on: Wed, 24 October 2018, 13:19:19 »
Probably a dumb question but would it not be possible to just find a screw that fits?
Offline kekstee
« Reply #219 on: Wed, 24 October 2018, 13:32:14 »
M2.5 is quite a difference already. You might be able to just cut a bigger thread if it isn't too close to the wall
« Last Edit: Wed, 24 October 2018, 14:17:24 by kekstee »
Offline xondat
  • i'm not a star
« Reply #220 on: Wed, 24 October 2018, 14:54:48 »
Not a dumb question.
I’d have to modify the weights to fit larger screws through, plus the “M2” holes probably aren’t any specific spec e.g. M2.5, M3 etc.
In general I expect working parts to my specification from a factory, if they can’t deliver then I need to return the faulty parts. Modifying what I already have would be a lot of work plus the factory would get away with it.
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #221 on: Wed, 24 October 2018, 15:00:44 »
So, should we expect a delay of like 6 months? less?
Offline nastrovje
« Reply #222 on: Wed, 24 October 2018, 17:59:30 »
Selling/transferring a spot for a silver HHKB if anyone is interested - GONE
« Last Edit: Thu, 25 October 2018, 11:33:42 by nastrovje »
Offline MMKB
« Reply #223 on: Wed, 24 October 2018, 23:10:39 »
If it only affect the weight I’m personally okay with super glue  ;D although as a creator you’ll find it atrocious
Offline ns90
« Reply #224 on: Thu, 25 October 2018, 09:58:37 »
WTS WKL Grey Spot with Brass Plate.
« Reply #225 on: Fri, 26 October 2018, 10:40:48 »
Ah I see, that makes sense. Yeh I agree with your response, at least you noticed it before they went out to people. Oh well I've waited far longer than this for stuff before so I'm sure I'll cope with the delay haha.
Offline regionfree
« Reply #226 on: Fri, 26 October 2018, 20:58:03 »
Still want to own one, and don't need it now. Willing to wait on this.
@xondat so only the bottom case pieces will be remade? won't this increase the chances of the top and bottom pieces not matching in color/anodization shade?
Offline xondat
  • i'm not a star
« Reply #227 on: Sat, 03 November 2018, 18:29:44 »
Think so, and they know I want matching so they should be able to match it considering they have all the parts.
  • settling down
Re: [GB] Noxary X60 R (Production x2?)
« Reply #228 on: Mon, 19 November 2018, 23:33:19 »
Seems screws and me just don't get along, eh? First the X60 was wrecked by its screws, now the X60 R needs fixing for its screws, and when I just put in Fox coilovers in my truck last week the sway bar bolts stripped out all the threads inside the frame so I drove around without a swaybar and now it's in the shop getting the frame nuts fixed because of a few screws.  :confused:
I don't mind waiting for it done right, man. :thumb: I mean, I still need to build my Klippe...
« Last Edit: Mon, 19 November 2018, 23:35:55 by exanile_tabasco »
Offline megaforce
« Reply #229 on: Tue, 20 November 2018, 11:10:20 »
tamako daisuki
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline duckboi
« Reply #230 on: Thu, 29 November 2018, 12:54:16 »
hello sir when is this rerunning thank you for your time
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline xondat
  • i'm not a star
« Reply #231 on: Mon, 31 December 2018, 11:38:56 »
Just received word these will ship to me in about 30 days. Thanks for your patience, I think it'll be worth it in the end.
Offline megaforce
« Reply #232 on: Fri, 04 January 2019, 10:56:28 »
god bless
and roll tide brother
Offline xondat
  • i'm not a star
« Reply #233 on: Sun, 20 January 2019, 16:24:10 »
Blue Gray and Black cases are ready to ship, just waiting on the other few colors now. I'll post some factory pictures shortly.
Offline xondat
  • i'm not a star
« Reply #234 on: Sun, 20 January 2019, 18:14:26 »
Offline regionfree
« Reply #235 on: Sun, 20 January 2019, 18:23:32 »
Awesome, thanks for the update!
Offline xondat
  • i'm not a star
Re: [GB] Noxary X60 R (Shipping To Me)
« Reply #236 on: Sun, 20 January 2019, 20:42:00 »
Just been told they're all done, and ready to ship. Will post new pictures when I get them. :p
Offline regionfree
« Reply #237 on: Sun, 20 January 2019, 21:10:28 »
For the love of god, please show me the purple beauty :))
Offline xondat
  • i'm not a star
« Reply #238 on: Tue, 22 January 2019, 15:41:01 »
Silver, Silver, Black Dark Gray
Pink, Ultra Violet, Blue Gray
Blue Gray, Dark Gray, Black
I think I'll have these in about a week.
The plan is approximately to quality check them, then build them all before going on a short trip (7th - 11th). I'll be able to hand deliver one of the cases on this trip (and convince him to leave some feedback or whatever), but otherwise should be ready to mail them all out when I get back. I do have one spare blue gray 60%, so PM if you're interested. I'll send out shipping forms/invoices just before I start building them, and hopefully all are paid by the time I get back.
I'm hopeful but cautious still. The manufacturer hasn't had any major problems, and when there have been minor problems, they replaced instantly. The anodizing on the T60s they produced was damn flawless, and the only problems I had were some hook marks on the inside, but those shouldn't happen again. I'm sure there will be a long story time after these are sent out, but let's get them shipped first :)
« Last Edit: Sun, 27 January 2019, 08:56:21 by xondat »
Offline kekstee
« Reply #239 on: Tue, 22 January 2019, 16:37:51 »
Damn nice :) I'm carefully optimistic.
Offline regionfree
« Reply #240 on: Tue, 22 January 2019, 20:25:45 »
that purple is mine. just want to say that out.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #241 on: Wed, 23 January 2019, 10:09:42 »
best of the batch, looks killer
Offline xondat
  • i'm not a star
« Reply #242 on: Wed, 23 January 2019, 16:03:43 »
Will arrive on the 29th.
Blue gray 60% is gone, sorry to those that missed out.
Offline xondat
  • i'm not a star
« Reply #243 on: Sun, 27 January 2019, 08:56:06 »
Made a mistake, top right is Dark Gray
Offline Coolbeanz
« Reply #244 on: Sun, 27 January 2019, 09:00:01 »
Is there any extra GB slot that I can hop on for this board? :D
Offline xondat
  • i'm not a star
« Reply #245 on: Sun, 27 January 2019, 09:01:21 »
Nope
Offline xondat
  • i'm not a star
« Reply #246 on: Tue, 29 January 2019, 11:44:36 »
Safe to say it isn't arriving today, don't know why. I'll chase them tomorrow if nothing moves :'(
Offline megaforce
« Reply #247 on: Tue, 29 January 2019, 11:52:04 »
chin up lad youll gettem next time
Offline xondat
  • i'm not a star
« Reply #248 on: Tue, 29 January 2019, 16:41:09 »
Still says delivery today, could arrive tomorrow but most likely Thursday.
Offline regionfree
« Reply #249 on: Wed, 30 January 2019, 09:15:50 »
Some of replacement parts have arrived, and more coming it seems. Excited for this!
