Author Topic: Beginner buying a buckling spring IBM Model M: check part number!  (Read 5886 times)
Offline spremino
Hello,
I've just been bitten by assuming all Model Ms were BS. Well, as you may already know they are not. So here is my advice to beginners: check its part number first. Wikipedia has a record of part numbers here http://en.wikipedia.org/w/index.php?title=Model_M_keyboard#Features_by_part_number
I've just updated that record with my (unwanted) find.
Happy typing ^_^
A long space bar... what a waste of space!
Offline ch_123
« Reply #1 on: Thu, 01 April 2010, 03:55:03 »
Ah, the 71G'... lol
Moral of the story - search model numbers before you buy. If you had put that model number in the Geekhack search, or even went into the IBM Wiki and Ctrl-F with it, stuff like this could be avoided.
The other one to be avoided is the Unicomp 96U1114. People think they're getting a cheap M5-2, in fact, they're getting a rubber dome board.
« Last Edit: Thu, 01 April 2010, 03:59:22 by ch_123 »
Offline spremino
« Reply #2 on: Thu, 01 April 2010, 04:16:15 »
Quote from: ch_123;168582
Ah, the 71G'... lol
Right. You should have seen my face when I opened the box and pressed a key... then another one... THEN ANOTHER ONE... GASP!
What disappoints me the most is that Model Ms are difficult to come by in my country.
Yeah. However no online article warns the beginner. Time to write a blog entry about that.
Offline ch_123
« Reply #3 on: Thu, 01 April 2010, 04:26:25 »
Other than about a kazillion articles in our wiki?
Offline spremino
« Reply #4 on: Thu, 01 April 2010, 05:13:17 »
Quote from: ch_123;168588
Yes. Search our wiki or the Internet for 71G4630.
What I was saying is: after reading tons of articles about Model Ms, in my mind - and in minds of newcomers, I think - Model Ms become THE BS keyboards. I learned a lot about grey/blue labels, drainage channels, IBM/Lexmark/Unicomp, AT vs PS/2, single/double pieces keycaps... yet I somewhat missed this pitfall. Luckily I just thrashed few bucks. I hope my fix to Wikipedia and this thread will help other people looking for a deal.
Happy typing.
Offline ch_123
« Reply #5 on: Thu, 01 April 2010, 05:23:09 »
Mhmm. With international variants it becomes a bit problematic. It is noted in the IBM wiki in regards to the internation layouts that -
"They also made some rubber dome equipped variants, these can be avoided by ensuring to buy a keyboards with a 13914xx part number. Most of them however had part numbers of the form 71Gxxxx."
I do admit that the IBM Wiki in it's current form is rather verbose, and probably could do with a tl;dr summary at the top.
Offline spremino
« Reply #6 on: Thu, 01 April 2010, 05:37:16 »
ch_123, your "IBM Wiki" effort is both remarkable and admirable. Thank you very much.
Maybe we just need a dedicated "Buyers guide" forum. A really concise guide for confused newcomers. Something along this lines:
   IBM Model M
Buyers beware
Check the plug
Terminal Model Ms do not work with PCs.
Check part number
Not all Model Ms are buckling spring based. For instance, part numbers of the form 71Gxxxx are acknowledged to be dome switch based. Check "IBM Wiki" to learn more.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #7 on: Thu, 01 April 2010, 05:46:29 »
Quote from: spremino;168595
Check the plug
Oh HELL NO you didn't!
kishy.ca
Offline spremino
« Reply #8 on: Thu, 01 April 2010, 06:30:19 »
Quote from: kishy;168597
Oh no, I didn't. At least I knew about terminal Model Ms ;-)
However a newcomer could fall for it.
Offline erricrice
« Reply #9 on: Thu, 01 April 2010, 08:33:08 »
Quote from: spremino;168599
I think he was referring to this.  His PC compatible terminal Model M lol.  Or PC converted rather haha.
« Last Edit: Thu, 01 April 2010, 08:35:42 by erricrice »
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #10 on: Thu, 01 April 2010, 09:34:50 »
Quote from: erricrice;168623
Lol well I guess it depends on how you define compatible. I'd say compatible is uh..."works even if it needed some hacks".
That might contradict something I said before, but whatever.
kishy.ca
