Author Topic: [IC] budget96 PCB and Case - mmm, QMK?  (Read 54163 times)
Offline azachhh
Re: [IC] budget96 PCB and Case - mmm, QMK?
« Reply #150 on: Fri, 27 April 2018, 10:50:39 »
man, I am so excited for this. i've probably said that a few times...  :p :p
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #151 on: Mon, 30 April 2018, 10:51:29 »
GB form available at https://donutcables.com/budget96-gb-form/
GB thread available at https://geekhack.org/index.php?topic=95390.0 once approved!
Offline runsamok
« Reply #152 on: Mon, 30 April 2018, 11:09:45 »
Quick question before this gets locked:
I see the PCB supports the layout I want (3x1u right of the spacebar vs 2x1.5), but the plate/case does not as depicted in all the pictures.
Am I gonna have to come up with my own top plate solution?
Offline donutcat
    • Donut Cables
« Reply #153 on: Mon, 30 April 2018, 11:14:56 »
The initial protos of the case only had a single layout since we weren't focusing on the layouts at the time, plates for the GB will support at minimum the common 96key layouts and we're aiming to support everything the PCB supports if it doesn't compromise the plates.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #154 on: Mon, 30 April 2018, 12:05:22 »
Whoa!!! That was a surprise. Sitting in the airport and saw the post on /r/mechmarket. Glad this is finally going live =D
