Author Topic: Painting stainless steel plate.  (Read 2751 times)
Offline futurecrime
  • Get Zooted
« on: Tue, 30 January 2018, 11:13:22 »
Alright, I'm gonna spray paint my plate. Just wanna check this is a good way before going ahead.
1: rough it up a little with wire wool/sandpaper.
2. Spray white primer.
3. Spray main colour in coats til satisfied.
4. Apply what? Clear coat?
My main concern is that the keys are gonna hit the plate sometimes so I don't want the paint to chip. Any advice from people who've done this before would be greatly appreciated so I can learn from your mistakes without having to make them myself. Cheers!
Re: Painting stainless steel plate.
« Reply #1 on: Tue, 30 January 2018, 11:23:59 »
I have painted several, and here is how I do it:
1. Sand the top surface of the plate with 80 grit sandpaper
2. Spray thin coats of paint (usually 3-4), allowing to dry at least 15 minutes between coats.
3. Allow plate to dry for 24-48 hours before installing switches and stabilizers.
4. Profit?
I don't find the need for a clear coat. The keycaps should never hit the plate, as the switch bottoms out before the sides of the cap would touch.
Offline futurecrime
  • Get Zooted
« Reply #2 on: Tue, 30 January 2018, 12:55:22 »
4. Profit?
Thank you, I guess I had a misconception of what bottoming out is. I'm planning on using Krylon, which I'm guessing is fine. Do you have any particular recommendation?
« Reply #3 on: Tue, 30 January 2018, 13:21:19 »
I normally use Krylon, also, so you should be good.
I have also used Rustoleum with good results.
Offline futurecrime
  • Get Zooted
« Reply #4 on: Tue, 30 January 2018, 16:40:10 »
****ing wonderful. Advice from Geekhack himself. Thanks much.
