Author Topic: [GB] Chiwi60 kit w/ brass plate [under glow][Non-floating 7 deg] - Shipping  (Read 82208 times)
Offline sennin32
    • Doyu Studio
update Jan '19
Update some more images!
Pic from geeks!
See more images here!
PVD/DLC
Anodized
Some more
end of update Jan '19
update Oct '18
Hi, we uploaded the plate cad file w/ ANSI sample!
https://gitlab.com/sennin32/chiwi60/blob/master/plate/output/drw_plate_ansi.dwg
end of update Oct '18
update Aug '18
Sorry for the delay.
We're packing the cases and they're going to start being shipped from this week!
end of update Aug '18
Hey everyone!
This is group buy for Doyu Studio Model B - Chiwi60 case kit.
Chiwi60 is a case kit for standard 60% keyboard.
We also offer HHKB(6u space) layout.
Interest Check Threat : https://geekhack.org/index.php?topic=92790
Groupbuy Links :
Brass version : https://shopkey.doyustudio.com/001kit00bp-gd
Aluminum version : https://shopkey.doyustudio.com/001kit00bsg
Kit include :
1. Body
2. Mount plate
3. Bottom plate
4. Name plate
5. Screws
6. Round rubber feet
7. User manual
Est. time :
Order end of Brass ver : Feb 18th '18
Order end of Aluminum ver : Mar 6th '18
Est. deliver : late Jun ~ early Jul, '18
Features/Specs :
Non-floating
7 deg angled
Aluminum Body /  Brass Body
Brass plate and name plate
PVD gold brass with mirrored polishing.
PC bottom plate with sandblast
1.5mm thickness mount plate
Surface finishing:
PVD with mirror polished  brass
Sandblast & ED for white
*Why not powercoating?
1. ED offer a thinner and controllable coating layer
2. ED is much more even than powercoating
3. Lesser humen work, stable quality, powercoating rely on worker skill
4. Better corrosion protection
Sandblast & Anodized for the rest colors.
Time frame :
Order end in Feb, depends on different versions.
Deliver around late Jun to early Jul '18.
stablizers support :
Default : plate mounted
HHKB : PCB mounted
Universal ANSI : PCB mounted
Universal ISO & ANSI : PCB mounted
* stabilizer pack contains :
plastic part for 6 caps (Genuine Cherry parts)
4*2u wires, 2*3u wires, 1* 6u wire, 1*6.25u wire, 1*7u wire
Things you might want to know / FAQs :
type-c ver might not fit all type-c PCB, different pcb has little difference.
Shipping cost : put item into cart and you can check it before pay
Will we run away with your money? Maybe A_A
- If you've joined our DO60 groupbuy, please enter your coupon code we sent you when check ouy by clicking "Apply Discount Code"
If you haven't received it, contact us please.
« Last Edit: Thu, 14 February 2019, 22:06:47 by sennin32 »
Offline bluesclera
Re: [GB] Chiwi60 kit w/ brass plate [under glow][Non-floating 7 deg]
« Reply #1 on: Fri, 09 February 2018, 14:45:27 »
So no brass bottom option?
Offline Darknight00z
« Reply #2 on: Fri, 09 February 2018, 14:49:24 »
So many GB running at the same time and I want them all  :-\ :-\
Offline kiwi99
  • that's a gnarly dookie
« Reply #3 on: Fri, 09 February 2018, 15:04:01 »
Will the HHKB version have removable blockers or will it the layout be integrated into the case?
Offline Visionaire
« Reply #4 on: Fri, 09 February 2018, 15:10:28 »
Totally getting a white one. Really clean, great price.
Offline sennin32
    • Doyu Studio
« Reply #5 on: Fri, 09 February 2018, 22:53:59 »
Not removable.
It is built in with case.
Offline desal
« Reply #6 on: Fri, 09 February 2018, 23:40:58 »
I ordered a brass plate with my DO60, can you add a no-plate option/discount to the brass case order form?
Offline PlayKeyboardTW
    • Shop
« Reply #7 on: Sat, 10 February 2018, 03:34:33 »
In for one! ;D
Offline ctrl
« Reply #8 on: Sat, 10 February 2018, 04:36:19 »
I thought the DO60 doesn't support an asymmetric HHKB layout with 6u spacebar. Or does it?
Offline SirWalross
« Reply #9 on: Sat, 10 February 2018, 07:39:25 »
I`ve got some questions:
1. Is the HHKB Layout compatible with an ISO Layout?
2. Could you post some renders of the HHKB? (I know you said that they were done rendering on the IC, but I haven't seen them, maybe I'm blind)
3. Could you post the available layouts for the HHKB?
Offline bluesclera
« Reply #10 on: Sat, 10 February 2018, 08:41:44 »
For some reason i have "Quantity: 2" how do i change to 1? I cant change the quantity on your website. How do you enter the "cart"?
Offline Lisinge
« Reply #11 on: Sat, 10 February 2018, 08:44:23 »
https://shopkey.doyustudio.com/checkout/cart/
Offline cdn-mini
« Reply #12 on: Sat, 10 February 2018, 08:45:41 »
I bought the D060 PCB so i dont need the plate. Do i pick default for the layout?
Offline Peppermint216
« Reply #13 on: Sat, 10 February 2018, 09:44:25 »
The plate from the DO60 gb will be for a tray mount case, not usable with the Chiwi60. You will need the top mount plate included in the Chiwi60 kit.
Offline cdn-mini
« Reply #14 on: Sat, 10 February 2018, 09:49:53 »
WWWHAT!!!!!! I've been bamboozled! Its the only reason i bought the D060 PCB.
Tray mount case vs top mount plate - whats the difference? link?
« Reply #15 on: Sat, 10 February 2018, 09:58:33 »
Tray mount drops in and is screwed down by the PCB to the case. You can find a lot of these on kbdfans, the Tina case or 5° case for example.
Top mount, the plate is screwed to the top of the case, pretty much standard in any custom.
Top mount is preferred in the community, it's a sign of a premium product. It is much nicer to type on.
Offline midnight2903
« Reply #16 on: Sat, 10 February 2018, 11:34:57 »
OP said the HHKB layout is being rendered on the IC thread.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #17 on: Sat, 10 February 2018, 12:12:20 »
I would drop sennin an email asking to refund the plate that you purchased during the PCB GB.
You will need to give him the details of the order.
It may take a little while though as I'd imagine that he'd be receiving quite a lot of emails due to the back to back group buys as well as his usual influx of emails from his store.
Offline KaosJ
« Reply #18 on: Sat, 10 February 2018, 13:40:21 »
Hey Sennin,
i sent you a mail but no answer so far.
It is possible to have PVD of another color, not gold?  I mean brass case with another color for pvd
Offline jebbra
  • jebbra.net
« Reply #19 on: Sat, 10 February 2018, 21:30:00 »
Is this pseudo hipro like M65A (keycaps not really sink in case) or real hipro like Duck Viper / KMAC Happy (keycaps beautifully snuggedly sinking)?
Offline sennin32
    • Doyu Studio
« Reply #20 on: Sat, 10 February 2018, 22:37:05 »
It does, and support split HHKB 6u
Hi, do you mean you want buy extra aluminum/brass body?
1. yes, but not shows in render
2. rendering :)
3. sure
Offline sennin32
    • Doyu Studio
« Reply #21 on: Sat, 10 February 2018, 22:39:48 »
Hi,
The kit has plate for build.
And plate you order in DO60 GB is not for this case :)
Offline sennin32
    • Doyu Studio
« Reply #22 on: Sat, 10 February 2018, 22:40:38 »
Hey Sennin,
Sorry, only gold this time :(
Offline sennin32
    • Doyu Studio
« Reply #23 on: Sat, 10 February 2018, 22:41:19 »
High profile that hide the edge of caps, you can take a look on new pics.
Offline sennin32
    • Doyu Studio
« Reply #24 on: Sat, 10 February 2018, 22:46:15 »
HHKB body(plate in rendering is not for HHKB):
Offline lanyusea
« Reply #25 on: Sat, 10 February 2018, 23:30:12 »
Quick question:
1. any prototype of the HHKB one?
2. any prototype of the Brass one?
3. is the Aluminum 6061?
4. is the Stabilizer coming with HHKB option with 6u wire?
HHKB Type-s / 4x KMAC Happy / 3x Duck Viper v1 / 2x Duck Viper v2 / 4x Duck Viper Duck TCV3 / Red Scarf 77 / 2x Infinity 60 / 2x ALF HHKB / LZ-CE / FJELL / Canoe / Canoe PC / Canoe FE / ARES Prototype / 2x Ares / LC-CLSh / TX60 / YODA2 / E6-V2 / E6-V2 FE / CAMP LC60 / 2x EM 7 / 4x Leaf 60 / UHK / Project F / Polaris / 4x Duck Viper v3 / TX60 v2 / Thermal / Matrix Falcon / TX60 v3 / 2x TMO50 / 2x Dolice / Dolphin 65 / Dolphin 60 / Plenty of keycaps
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #26 on: Sat, 10 February 2018, 23:36:48 »
That brass case sounds awesome! Might have to join this.
Couple questions.
1) Is there any finish on the brass to help prevent corrosion?
2) Wasn't aware of the DO60 PCB, how is programming for it and where can I find more information about it?
3) Where does the nameplate go? I didn't notice it in any of the renders
Also, I see that on the brass case, the option for universal USB port type is $15 but on the aluminum one it's only $5. Is there a reason for this $10 difference?
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #27 on: Sun, 11 February 2018, 00:54:17 »
Couple questions.
1. It's mirror finish PVD coated like the plate.
2. The PCB runs on QMK
3. The nameplate (which is also PVD coated) is mounted to the underside of the polycarbonate base.
« Reply #28 on: Sun, 11 February 2018, 00:56:16 »
What's the difference between the painted white aluminium and any other colors?
Offline JDragon
« Reply #29 on: Sun, 11 February 2018, 01:22:51 »
It won’t let me check out with a brass one, are they out of stock?
edit: Tried on both phone and desktop - I add it to cart and then when I view my cart it disappears. :(
« Last Edit: Sun, 11 February 2018, 01:50:16 by JDragon »
Offline Johnee
« Reply #30 on: Sun, 11 February 2018, 01:39:12 »
Really liking the white hhkb version but I have a couple of questions,
1. Should the blocker corners have the same radius as the upper inner corners?
2. Will you be making a prototype of the hhkb version before the main production begins?
3. The 6U spacebar should be off-centered, right?
Offline TheMissingPiece
  • TheAverageOne
« Reply #31 on: Sun, 11 February 2018, 03:29:51 »
Are there pictures of the layouts supported by each plate? I was hoping for 2u shift with split spacebar (hopefully in 2.75/1.25/2.25u configuration) support.
Offline Lisinge
« Reply #32 on: Sun, 11 February 2018, 06:39:30 »
I had the same problem. It worked after trying A LOT of times with both paypal express and their normal checkout flow.
Offline sennin32
    • Doyu Studio
« Reply #33 on: Sun, 11 February 2018, 11:55:53 »
Quick question:
1. yes, but we have to make it after CNY, and prototype might not do any surface treatment. safe time to do testing
2. once brass version reach MoQ, we'll do it, make sure the quality is nice.
3. yes, 7000 series is too expensive O_Q
4. we offer stabilizer cover most layout no matter which layout you chose, you can check "* stabilizer pack contains"  section
Couple questions.
1. PVD treatment will prevent that.
2. it is powered by QMK, we're working on how to do that without even single command line.
3. on the bottom side
2u shift version got too less interesting, we're not able to make it under the quantity :(
1. the radius on upper side is to fit outline of case. but lower side does not have to match outline, we make it shaper.
2. yes, but we have to make it after CNY, and prototype might not do any surface treatment. safe time to do testing
3. correct, just the same as origin hhkb
For check out issue.
Could you send me a mail?
I'll create order manually.
It will be great if you can take screenshot of failure.
And I'll try find out reason  of failure.
I'm not sure if it is related to the attack this morning.
Somebody was trying hack our server, lead high cpu usage, and the server got some issue after that.
I should already solve that and make a simple protection.
« Reply #34 on: Sun, 11 February 2018, 11:59:22 »
Sent an email also a few days ago, no response. When I ordered the kit there was no option to choose a DO60 colour. Now I see on the order page the option for black or white is there.
Looking to set the colour of my order to a black DO60 please.
Offline Johnee
« Reply #35 on: Sun, 11 February 2018, 12:07:13 »
My question was if the spacebar mount, where the MX stem goes into the cap, is off-centered? It seems most GMK 6U spacebars are like this. The original HHKB spacebar is center mount, the topre stem goes into the cap in the center of the cap.
Offline Lisinge
« Reply #36 on: Sun, 11 February 2018, 13:59:58 »
Can we know what the brass moq is and current number of brass orders? Also tell us when the brass moq is reached so we know.
  • TheAverageOne
« Reply #37 on: Sun, 11 February 2018, 16:56:34 »
If that's the case, would it be possible to release the plate files so I could make my own plate?
Offline sennin32
    • Doyu Studio
« Reply #38 on: Sun, 11 February 2018, 17:44:10 »
Hi,
Your order# is?
Offline sennin32
    • Doyu Studio
« Reply #39 on: Sun, 11 February 2018, 17:44:51 »
Both off center and centered works.
Offline sennin32
    • Doyu Studio
« Reply #40 on: Sun, 11 February 2018, 17:45:38 »
Yes, we'll release the cutout, so people can cut their own plate.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #41 on: Sun, 11 February 2018, 19:35:13 »
This was posted on the IC page:
Numberpad incoming
« Last Edit: Sun, 11 February 2018, 21:37:58 by gok101 »
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #42 on: Sun, 11 February 2018, 23:29:19 »
An actual MX HHKB :cool: we in :cool:
« Reply #43 on: Mon, 12 February 2018, 00:47:44 »
Hi,
Your order# is?
#000002286
Thanks
Offline ctrl
« Reply #44 on: Mon, 12 February 2018, 02:40:27 »
Very nice! Would it be possible to see pics comparing what the two different USB ports will look like? I just see a pic of the one fitted for the DO60. Does the universal port look the same, just more open?
Offline sennin32
    • Doyu Studio
« Reply #45 on: Mon, 12 February 2018, 04:16:05 »
Hi,
Your order# is?
#000002286
Thanks
We've already changed it into black.
I guess we just forgot send reply after done that @@
Offline sennin32
    • Doyu Studio
« Reply #46 on: Mon, 12 February 2018, 04:16:44 »
Yes, just like other 60 case.
A bigger hole.
Offline ctrl
« Reply #47 on: Mon, 12 February 2018, 07:23:45 »
A bigger hole.
Thanks for clarifying! :)
Offline Lisinge
« Reply #48 on: Mon, 12 February 2018, 16:15:21 »
Can you tell us what the brass moq is and current number of brass orders? Also it would be great if you could tell us when the brass moq is reached so we know.
Offline sennin32
    • Doyu Studio
« Reply #49 on: Mon, 12 February 2018, 22:21:52 »
I think we can make when >20.
Got around 70+ interesting.
But the order quantity is not enough now.
If moq is not able to reach by next week.
We have to cancel brass ver.
