Author Topic: cherry mx stem for custom resin keycap  (Read 6973 times)
Offline ju6ju8Oo
« on: Mon, 12 February 2018, 02:36:39 »
Is there a stem-only or a thin keycap that I can use to build a custom resin keycap on top of it?
Re: cherry mx stem for custom resin keycap
« Reply #1 on: Mon, 12 February 2018, 11:43:40 »
https://geekhack.org/index.php?topic=78551.0
« Reply #2 on: Mon, 12 February 2018, 19:45:42 »
Or you can get a bunch of old keycaps, say from one of SP's crap bags - some people give away the ones they don't want, and cut and dice as required.
Offline ju6ju8Oo
« Reply #3 on: Mon, 12 February 2018, 21:29:57 »
Is it difficult to make a 2-part keycap from Resin on top of ABS/PBT keycap? I do not find any keycaps using this method though.
« Reply #4 on: Tue, 13 February 2018, 19:47:15 »
I have no idea.  Model M keycaps are two piece, so the idea is sound.
A lot of people use an old keycap as a base to sculpt something on top, then make a mold from that piece.
