Author Topic: E6-V2 Round 2 - 60% custom keyboard -GB OPEN  (Read 61373 times)
Offline excluisve
  • Making & Thinking.
« on: Tue, 13 February 2018, 07:41:26 »
Hi friends .
i am exclusive,this is my first time post ic here soooo excited.  Hoping my past work done  well ,now i am gonna open R2 for
E6-V2。I wish more and more people like my keyboard . :thumb:
E6-V2
Please,fill this form if you are  interested in purchasing one
https://docs.google.com/forms/d/1pmkV1lXEhpRVAA93GfQZ2QO9_tkxq14fHGnLnV-xpaA/edit
Specifications:
                         - 6063 Anodized aluminum
                         - Classic Sandwich design
                         - Anodized aluminum or Sand blasting brass Counterweight and Middle piece. name tag
                         - PC Brass Anodized aluminum plate .
                         - Layouts :ISO and ANSI (6.25u, 7u spacebar and HHKB layout) | Both stepped and normal Caps Lock is supported
                                          Supported small block https://imgur.com/8pEDKBB
                         - Fully Programmable using Bootmapper Client  .RGB bottom side LEDs
                         - Colors :  - Black-  dark green - Special teal - dark blue - Red- dark purple - rose gold- MAO  -Sliver
                                         - It only will have 5 colors for case .        we will chose color from above
                                         - plate and name tag also weight limited 3 colors
Limited Edition :
                                        - it will limited to 10 all brass version
More pictures here : - Rendering https://imgur.com/a/pcdOy
                                 - Orders pictures :https://imgur.com/a/0J9iV
                                 - Solder https://imgur.com/gallery/PVgSp
                                 - colors collection : https://imgur.com/a/kw6ts
Estimated price starts from: $320 (Full kit)  Final price is depending on different materials and colors
Expected timeline:
                                             * Group Buy open : 28 February 25 February
                                             * Group Buy closes :10 March
                                             * Keyboards will be shipped out: Early June   At the end of May
Thanks all
keep updating
« Last Edit: Sun, 25 February 2018, 18:17:11 by excluisve »
Offline excluisve
Re: E6-V2 Round 2 - 60% custom keyboard
« Reply #1 on: Tue, 13 February 2018, 07:41:48 »
Updaing  14/2  btw,Happy Valentine's Day
I have sort the asking.
FAQs:
1.Is there have sliver ?
- is okay but final colors still just have 5
2.It will have brass opton?
- yes,it have brass plate name tag weight and middle (plz check the Specifications:  )
3.Why there was no qmk pcb and left port ?    QMK Supported
-For R1 i have run 4X different pcb 2x plate 2x case it really makes me meesed up
- so in the R2 just have middle port and bootmapper ,i think  bootmapper is functional and easy to use
- my original opinion was make run smooth and clear .
4.R1 parts were fit with R2?
- i am sorry that R2 have modify something btw r1 weight and name tag was fit
5.Where is the Dark blue?
-Is show on homepage with GMK Nautilus
6.Why there was no big block ?
- personal thinks small may fit well with 60% makes it unique but for the big block may more fit with 80%
- things still way out ,final decision still depends on our discussion
« Last Edit: Tue, 13 February 2018, 22:24:42 by excluisve »
Offline InvidiousIgnoramus
« Reply #2 on: Tue, 13 February 2018, 07:46:12 »
The hardest part now is choosing what color to get.  :cool:
I long for the day when I find a beamspring. (At a not insane price)
Offline Peppermint216
« Reply #3 on: Tue, 13 February 2018, 07:48:45 »
Exactly, so many combinations to choose from.
« Reply #4 on: Tue, 13 February 2018, 07:53:56 »
Are the 7 colours fixed or is there the possibility of adding more?
Was hoping to get a silver case with purple stripe/center piece.
Offline mago
« Reply #5 on: Tue, 13 February 2018, 08:12:22 »
Yeah was hoping silver would be an option :(
Offline midnight2903
« Reply #6 on: Tue, 13 February 2018, 08:22:11 »
I assume the HHKB layout is not true HHKB but symmetric?
Offline 6FeaT
« Reply #7 on: Tue, 13 February 2018, 08:30:28 »
R1 used the symmetric layout found on boards like the Duck Viper, etc. So I would assume it's the same.
Offline 6FeaT
« Reply #8 on: Tue, 13 February 2018, 08:31:50 »
No silver?  :(
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #9 on: Tue, 13 February 2018, 08:33:36 »
Anyone interested in the 'dark green' as more of a military green (less of a leafy green)?
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline amnesia0287
  • Formerly Amnesia
« Reply #10 on: Tue, 13 February 2018, 08:37:39 »
No, better this way.
Offline kmba
  • Formerly tameone
« Reply #11 on: Tue, 13 February 2018, 08:38:55 »
Silver!!!!  :-\ :confused:
keyboards.
« Reply #12 on: Tue, 13 February 2018, 08:43:38 »
Oh boy, should I get this or Chiwi?!  :-\
EDIT: No brass plate?
« Last Edit: Tue, 13 February 2018, 08:52:16 by midnight2903 »
« Reply #13 on: Tue, 13 February 2018, 08:46:46 »
Like an Olive green? but of course, that woule be perfect!
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #14 on: Tue, 13 February 2018, 08:47:40 »
Was hoping to get true WKL and MAO white/grey.
Offline touzi
« Reply #15 on: Tue, 13 February 2018, 08:49:02 »
I'm really excited for this GB :)!!
Offline Vigrith
« Reply #16 on: Tue, 13 February 2018, 09:18:29 »
Hectic time to put out another HHKB/60% - Chiwi, CA66, M60, M0110, Tokyo60 and surely others I'm forgetting about. Would've liked to have seen this run some time in April or May, this makes decisions a lot harder.
Would it be possible to see a picture (or render) or the Rose Gold MAO? Gonna be between that and the special teal for me.
« Reply #17 on: Tue, 13 February 2018, 09:20:15 »
Does the kit include a QMK PCB or is it only BootMapper?
« Last Edit: Tue, 13 February 2018, 09:42:47 by midnight2903 »
Offline energyd
« Reply #18 on: Tue, 13 February 2018, 09:21:31 »
In the "colors collection" link the blue looks too light for me. Will it be the dark navy blue same as the pic with Gmk Nautilus or the one in the "colors collection" pic?
Offline excluisve
« Reply #19 on: Tue, 13 February 2018, 09:33:35 »
The blue is light blue, not dark blue actually
I am forgot to figure it.
Dark blue is with gmk natilus
Those are two color ,different .
Offline excluisve
« Reply #20 on: Tue, 13 February 2018, 09:36:49 »
Yea ,more choice  .
Rose gold I am trying to make it likes apples color
Mao and special teal it was show on  orders pictures
Plz click to check
Thanks
Offline energyd
« Reply #21 on: Tue, 13 February 2018, 09:45:53 »
Which one is going to be included for R2? I'm in if it's the dark blue.
Offline excluisve
« Reply #22 on: Tue, 13 February 2018, 09:47:18 »
Dark blue exactly
Offline regionfree
« Reply #23 on: Tue, 13 February 2018, 10:03:04 »
going in on this. will get one for laser.
Offline Darknight00z
« Reply #24 on: Tue, 13 February 2018, 10:03:50 »
How heavy is the case?
Offline lunr
« Reply #25 on: Tue, 13 February 2018, 10:06:43 »
I don't see MAO (white) on the google form unless it's already a confirmed colour?
Offline excluisve
« Reply #26 on: Tue, 13 February 2018, 10:11:17 »
Mao was not anodized so it was confirmed have this color
Offline excluisve
« Reply #27 on: Tue, 13 February 2018, 10:12:45 »
Almost 1.5kg with Alu parts
Offline att1cus
« Reply #28 on: Tue, 13 February 2018, 11:10:53 »
any chance we will have the option to buy just case/plate/weight?
Offline BAS1C
« Reply #29 on: Tue, 13 February 2018, 11:22:28 »
Hey Exclusive,
Is this same design as the first buy? I would like to get more pieces for my E6 I already have :)
Offline zekkin
« Reply #30 on: Tue, 13 February 2018, 11:23:31 »
So we will be able to get white MAO?
Also exclusive is there any chance to get full 1u blockers for small block?
« Reply #31 on: Tue, 13 February 2018, 11:49:12 »
if that dark blue stays i might sell stuff for this
Offline amnesia0287
  • Formerly Amnesia
« Reply #32 on: Tue, 13 February 2018, 11:51:57 »
Have you considered Dark Grey instead of Black?
Offline kmba
  • Formerly tameone
« Reply #33 on: Tue, 13 February 2018, 11:57:01 »
I'd say either dark gray or silver instead of black.  Or both instead of black and rose gold or MAO.
keyboards.
Offline ArchCel
« Reply #34 on: Tue, 13 February 2018, 12:21:59 »
Looks great :) Also really interested to know how cross compatible the parts are with the first run :)
Also any chance for QMK in this run aswell? Even if it is a rerun of the previous QMK pcb's warts and all.
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #35 on: Tue, 13 February 2018, 13:10:40 »
Ugh so many amazing boards running right now. How to pick..
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline Vadurr
  • Valar Morghulis
« Reply #36 on: Tue, 13 February 2018, 15:59:29 »
Interested in the dark blue...
Offline Harms
« Reply #37 on: Tue, 13 February 2018, 16:32:36 »
EDIT: Still not sure if this supports arrow key layouts like the DZ60.
But the navy blue is amazing :D
« Last Edit: Tue, 13 February 2018, 19:09:47 by Harms »
« Reply #38 on: Tue, 13 February 2018, 19:52:01 »
oh i'd really like to see silver offered
or apple silver, if you feel like doing that again
i want apple silver with special teal stripe
Offline afrokobe
« Reply #39 on: Tue, 13 February 2018, 20:17:36 »
definitely in again for r2 :)
Offline forumusername
« Reply #40 on: Tue, 13 February 2018, 20:30:20 »
Please do silver again!
Offline Vadurr
  • Valar Morghulis
« Reply #41 on: Tue, 13 February 2018, 20:38:08 »
When you guys say silver, are you referring to the MAO white? I'd def be in for that as well.
« Reply #42 on: Tue, 13 February 2018, 20:47:09 »
no, as in silver anodized
im not a huge fan of MAO
« Reply #43 on: Tue, 13 February 2018, 20:52:00 »
The dark green looks amazing. But I can't really think of any keycaps that would fit that aside from maybe Royal Alpha which got cancelled :(
« Reply #44 on: Tue, 13 February 2018, 20:53:27 »
epbt green
ccng
white blanks
« Reply #45 on: Tue, 13 February 2018, 20:56:00 »
epbt green
ccng
white blanks
I can understand EPBT green and CCnG (cant find it tho), but would white blanks even look good on the dark green?
Offline __foo_
« Reply #46 on: Tue, 13 February 2018, 21:14:56 »
SA/GMK Camping should look good on the dark green case.
« Reply #47 on: Tue, 13 February 2018, 21:16:57 »
epbt green
ccng
white blanks
white + dark color is graphic design 101
Offline excluisve
« Reply #48 on: Tue, 13 February 2018, 21:17:59 »
FAQs:
« Last Edit: Tue, 13 February 2018, 21:19:30 by excluisve »
« Reply #49 on: Tue, 13 February 2018, 21:19:27 »
FAQs:
sounds good, thanks
i really want apple silver and teal
and as long as there's HHKB i'll probably join regardless of color choices
