Author Topic: [IC] Artisan Case  (Read 21672 times)
Offline olivia
Re: [IC] Artisan Case
« Reply #50 on: Wed, 28 March 2018, 19:21:04 »
I need it now :D
Offline xondat
  • i'm not a star
« Reply #51 on: Wed, 28 March 2018, 19:37:39 »
Also want to shout out thanks to rmendis, who conducted sizing tests on a vast array of keycaps. Unfortunately, I can say definitely that the following caps pictured will not fit in the case. Otherwise, the sizing of the case is inclusive for just about every other cap you could think of (give or take a few other outliers):
Did you test Bruce? :p
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #52 on: Wed, 28 March 2018, 19:38:23 »
Pretty sure he said it fits.
Offline -musubi
  • Spam rice 'n eggs
« Reply #53 on: Thu, 29 March 2018, 01:08:39 »
Looks awesome so far man!  :thumb:
Offline hayt
« Reply #54 on: Thu, 19 April 2018, 16:49:45 »
194119-0
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #55 on: Sat, 21 April 2018, 11:44:26 »
No bottom finish looks good too but I'm definitely interested in bead blasted
Offline scud80
« Reply #56 on: Sat, 21 April 2018, 12:08:50 »
with the size check, is that including the foam or without it?  curious which caps will fit, but can't be transported if i want to use the foam.  for "normal" height caps, does the foam just kinda sit on top (so they could still rattle a little bit) or does it press down on them to keep them in place?
Offline scud80
« Reply #57 on: Sat, 21 April 2018, 12:09:44 »
also, the link to the interest check form isn't working any more.
Offline BestShuckleNA
  • はあちゃまっちゃま~!
« Reply #58 on: Sat, 21 April 2018, 13:05:10 »
Shipping to Canada would probably be like 15-25 bucks right? been looking for a artisan case but I don't think I just wanna grab a taobao one.
Offline hayt
« Reply #59 on: Mon, 23 April 2018, 12:07:19 »
Link updated, thanks!
I agree with you 100% dude. Especially after putting the machine finished next to the v1 prototype which was bead blasted, blasting is the way to go. That's my goal for the week, to see if I can find someone local to help me out with that final step.
Yes, die-cut foam is included. The foam is 1/2" thick light charcoal that can be compressed almost entirely between your fingers. It's a perfect fit inside the case and should work even with artisans that max out nearly the entire .81" of head space.
    • WTB/WTTF Thread
« Reply #60 on: Mon, 23 April 2018, 12:08:41 »
Looks like I'll be in for 2
Offline BobCarltheThird
« Reply #61 on: Mon, 23 April 2018, 13:48:17 »
Is it too early to ask for a price estimate?
***loads of Vaseline for my meme TMO50 -- Acereconkeys
Offline scud80
« Reply #62 on: Mon, 23 April 2018, 19:27:11 »
it's in the OP.  $93.
Offline Solotov
« Reply #63 on: Mon, 23 April 2018, 19:38:06 »
Where's the love for enter key artisans  :'(
Flex is love, flex is life.
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #64 on: Sat, 28 April 2018, 18:29:18 »
case by Dale Snail, on Flickr
Offline roostrc0gburn
  • its just plastic
« Reply #65 on: Sat, 28 April 2018, 18:51:18 »
Offline xondat
  • i'm not a star
« Reply #66 on: Sat, 28 April 2018, 18:57:54 »
It's so god damn nice.
Wish I had a use for it.
« Reply #67 on: Mon, 30 April 2018, 23:18:34 »
Reporting my interest.
OG BK will be the only cap in it.
« Last Edit: Mon, 30 April 2018, 23:24:08 by romevi »
Offline hayt
« Reply #68 on: Fri, 04 May 2018, 10:00:03 »
ty for crispy dale <3
by way of an update, I am picking up the V2 prototype on monday with a 220 glass bead media finish. If all looks well will open the GB next week, soon tm
Offline hayt
« Reply #69 on: Fri, 04 May 2018, 10:02:00 »
I'll allow it
« Reply #70 on: Fri, 04 May 2018, 10:18:26 »
I'll allow it
 :-* :p :-* :p
Offline SeedyOne
« Reply #71 on: Tue, 08 May 2018, 18:25:29 »
Interested for a bead blasted one!  :thumb:
Offline bjayswift
« Reply #72 on: Tue, 08 May 2018, 22:57:21 »
Fantastic, I've been waiting for this one.
Sent from my SAMSUNG-SM-G930A using Tapatalk
TX1800V2
    • WTB/WTTF Thread
« Reply #73 on: Wed, 09 May 2018, 05:24:58 »
