Author Topic: Anyone tried KBDFans topre ADAPTER-X mx sliders?  (Read 8671 times)
Offline DuckNorris
« on: Wed, 14 February 2018, 00:00:03 »
After a lot of research on topre to mx sliders, I came to conclusions based on what I read.
1) Nothing beats the feel of original topre sliders
2) Best one recommended are KBDFans sliders (some say lube them up as well)
However, I saw that Ali express no longer sells the original kbdfans topre to mx sliders, however the only ones I could find are these new adapter-x sliders... Anyone tried them or any reviews recommendation?
I want to use a GMK set on a Leopold FC660C
Re: Anyone tried KBDFans topre ADAPTER-X mx sliders?
« Reply #1 on: Wed, 14 February 2018, 00:50:47 »
i have heard that they are the best option that is not NT sliders, but they are kinda tight
Offline HotRoderX
« Reply #2 on: Wed, 14 February 2018, 00:58:26 »
When you say tight Puddy are we talking so tight they gotta be lubed to even install them. Are we talking tighter and less wobble then the originals.
Offline DuckNorris
« Reply #3 on: Wed, 14 February 2018, 12:53:02 »
Yeah someone said it they had a cracked keycap stem, does lube help with that? If so , which lube is recommended or any tutorials? Thanks!
Offline Lepidus
« Reply #4 on: Wed, 14 February 2018, 13:44:36 »
This feedback someone left on aliexpress worried me.
Offline DuckNorris
« Reply #5 on: Wed, 14 February 2018, 13:53:33 »
That is very concerning, thank you for this ... It is 2018 WHY DO WE STILL STRUGGLE WITH TOPRE TO MX SLIDERS  :'(
Any other better sliders?
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
« Reply #6 on: Thu, 15 February 2018, 19:00:22 »
JTK made a bunch of them, you might be able to find them after market?
Offline DuckNorris
« Reply #7 on: Thu, 15 February 2018, 20:00:20 »
A good amount of people said the old KBDfan ones were pretty good, did you or anyone you know have a good experience with JTK sliders?
Offline hasu
  • @tmk
« Reply #8 on: Sat, 17 February 2018, 21:36:40 »
The keycap leaning happens even with Topre sliders,  if you care it you better pass topre boards or have to relax your criterion.
Offline phinix
« Reply #9 on: Mon, 08 October 2018, 04:22:20 »
Bringing this one back:)
Are JTK better, rotation wise?
So far all KBDFans sliders are rotated a bit - some people can get used to it, some not.
