Hey guys!
Just wanted to have a bit of Interest Check for a keyset I have been trying to work on. Got some feedback from good friends, but I felt that I needed more input from everyone.
The keyset is inspired by
Flash from DC Comics, but their nickname is "
Speedsters" thus the keyset name.
Bear with me as, honestly, I suck at using GH (since im a redditor) so the post might not look the most nicest.
THE KEYSET...so far This is going to be the original BASE "Speedster" set ![[IC] GMK or SA "Speedster" Keyset 188879-0](https://geekhack.org/index.php?PHPSESSID=7f9t96sfc08hn4suk48vqe697223v81c&action=dlattach;topic=94072.0;attach=188880;image)
<-- Click for bigger picture
While this is the "Reverse Speedster" set![[IC] GMK or SA "Speedster" Keyset 188881-1](https://geekhack.org/index.php?PHPSESSID=7f9t96sfc08hn4suk48vqe697223v81c&action=dlattach;topic=94072.0;attach=188882;image)
Personally I am satisfied with how Reverse Speedster looks, and am mostly satisfied with Speedster.
Only issue I have is that I dont really like how the ESC/Enter/Arrow colors are going on Speedster.
I dont want to have to split up everything into multiple kits like those done on Massdrop (not going with them btw..)
But at the same time, I am not sure how effectively it would work, trying to sell 2 different keysets.
So need some input on that.
Some feedback needed on the following: - GMK? or SA? or some other profile?
- Need input on colors for SPEEDSTER set
- Novelty ideas?
- Should I choose only one of the keysets to run?
- Any other feedback
Stuff I need to do: - Novelties
- Compatibility
- Color samples
- etc...
