Author Topic: Detect Bluetooth Mouse & keyboard C#  (Read 2243 times)
Offline pom88
« on: Thu, 15 February 2018, 06:16:57 »
Hi All;
I'm developing desktop application using C#, its main function is to detect any hanrware connected & paired through Bluetooth & monitor its strength..please reply ASAP..any SDK or Library would be helpful..
PS: Windows API should be used to develop this application. แทงบอลสเต็ป2
Regards;
pom thanong
Offline killyou
Re: Detect Bluetooth Mouse & keyboard C#
« Reply #1 on: Thu, 15 February 2018, 09:29:21 »
I'm not sure whether you are developing it as clearly you haven't started yet :) Try google first and then check on StackOverflow if you can't find anything.
