Author Topic: [IC] Noxary 280 & 220  (Read 167898 times)
Offline xondat
  • i'm not a star
« on: Mon, 19 February 2018, 22:53:30 »
Information:
  • 8 Degrees Base Angle
  • Top Mounted Plate with Switch Opening
  • Custom USB-C QMK PCB
  • 15mm Front Face
280
  • Total of 100
  • Weighs 2.4kg (5mm Brass +900g)
  • Winkeyless or Winkey
    • Case - $365
    • PCBs - $35
    • Fixed Red Aluminum - $35
    • Fixed Brass - $35
    • Universal Brass - $35
    • Partial Polycarbonate - $60
    • 5mm Brass - $100
    • 5mm Polycarbonate - $85
220
  • Total of 30
  • Weighs 600g
    • Case - $160
    • PCBs - $25
    • Universal Brass - $25
Colors
  • Black
  • Silver
  • Dark Gray (8402 C)
  • Pink (1895 U)
  • Blue Gray (8181 C)
  • Ultra Violet (18-3838 TXC)
  • Olive
  • Crimson Red
This will use an updated architecture that I've been working on. If 268 was V2 .1, this is V2.1 .2. There have been a few changes needed just to work out any kinks etc; nothing notable though.
With this, I just want a perfectly matching TKL + pad (all info will cover both). The design will stay classy and very simple. The main change is increasing bezels from 4.6/3mm to 6/4mm - I think this will work much better aesthetically. I felt that 268 was almost too thin at first (although now it's really nice). I've also increased the corner fillet, increased the edge fillet a tiny bit, increased the size of the N cutout by >.5mm, and kept pretty much everything else the same. I think it works very well as is.
I'll either have the PCB green or red; it'd be interesting to hear what people think on this. Planning USB-C, this probably won't change. Sorry about your cables, but it's time for an upgrade! ;)
I'd also like to do a limited version (probably 1 of 30) where participants can choose anodizing color freely, similar to what happened with 268 AG. I think it's going to bring some really interesting builds/combinations. Matching custom colored TKL + pad sounds dreamy to me. :'(
There will be 99% 100% be a winkey version for the TKL; just too lazy to mock it up (it isn't hard to imagine!) - I doubt I'll won't do small blockers as I don't think they're that great. Standard key choice things: split backspace/right shift/left shift; stepped caps; ISO enter; maybe 1.25u bottom row; no split spacebar crap. Numpad will have all split keys available, and no additional blockers.
Keeping the starting price sub $400 for the TKL, and sub $175 (complete guess though) is my main goal here. I'm not too sure what the price increase from 65% to 80% is, but it shouldn't be enough that it requires a $30 increase lol. Planning on starting this shortly after I finish 268/268 AG, which will be next month (hopefully)! Probably a 3 month turnaround.
« Last Edit: Fri, 10 May 2019, 13:24:30 by xondat »
Offline HardcoreDesk
Re: [IC] Noxary 280 & 220
« Reply #1 on: Mon, 19 February 2018, 22:54:01 »
Yup
Edit: Will the plate support Romer-G?
« Last Edit: Mon, 19 February 2018, 23:00:41 by HardcoreDesk »
Offline Kafka
  • i like clean things
« Reply #2 on: Mon, 19 February 2018, 22:54:58 »
Sure
Offline oatmicro
« Reply #3 on: Mon, 19 February 2018, 22:55:14 »
Yeeees pls
Offline mago
« Reply #4 on: Mon, 19 February 2018, 22:57:32 »
Hell yes
Offline SixtyLife
« Reply #5 on: Mon, 19 February 2018, 23:01:57 »
Yes
Kishsaver, JP SSK, Displaywriter SSK, 360C, HHKB Type S, X60, Jane v2, Jane v2 CE
« Reply #6 on: Mon, 19 February 2018, 23:06:46 »
all 1u support on pad pls
also will the screws on the higher side have those really annoying long holes that get in the way?
red pcb is classic
« Last Edit: Mon, 19 February 2018, 23:08:21 by Puddsy »
Offline Captain Shwah
« Reply #7 on: Mon, 19 February 2018, 23:07:30 »
Yep, gonna have to add these to my Noxary collection. Red PCB would be cool.
Offline xondat
  • i'm not a star
« Reply #8 on: Mon, 19 February 2018, 23:13:23 »
red pcb is classic
Already happening
Yeah maybe, currently 19mm, could always shorten that but might have consequences with CNC difficulty.
Yup. Red looks great, but so does green. Hard life :))
Yup
Sure
Yeeees pls
Hell yes
i love emilia
Yes
Me too thanks
Offline bjayswift
« Reply #9 on: Mon, 19 February 2018, 23:13:51 »
Just subbed. I've been waiting for a keyboard pad matching combo
Sent from my SAMSUNG-SM-G930A using Tapatalk
TX1800V2
« Reply #10 on: Mon, 19 February 2018, 23:21:30 »
In all seriousness, I'd much prefer green PCB over red.
Offline Cavemann6
« Reply #11 on: Tue, 20 February 2018, 00:10:30 »
Looks great  :thumb:
« Last Edit: Tue, 20 February 2018, 00:31:58 by Cavemann6 »
Offline amnesia0287
  • Formerly Amnesia
« Reply #12 on: Tue, 20 February 2018, 00:16:16 »
asiodjaskdjaskdjasdjasdwetsaefjsdfjkserd
I was going to ignore this, but you gotta go and do custom colors like ag >_< ****.
Offline p_blaze
« Reply #13 on: Tue, 20 February 2018, 00:36:02 »
Custom colors? i like this
Offline mudcakehoney
« Reply #14 on: Tue, 20 February 2018, 00:54:52 »
This is a yes from me
« Reply #15 on: Tue, 20 February 2018, 02:06:57 »
green pcb looks generic
red PCB looks like a ferrari
ez choice
Offline amnesia0287
  • Formerly Amnesia
« Reply #16 on: Tue, 20 February 2018, 02:31:42 »
ez choice
But green pcb under red half plate looks so gud.
Offline ak_xf1re
  • Daydreamer
« Reply #17 on: Tue, 20 February 2018, 02:51:19 »
Also in!  ;D Looking forward to it matey!
Offline Liocer
« Reply #18 on: Tue, 20 February 2018, 03:02:43 »
damn damn damn, looking really good dude :D..
Offline futurecrime
  • Get Zooted
« Reply #19 on: Tue, 20 February 2018, 05:41:45 »
I want it all.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #20 on: Tue, 20 February 2018, 06:18:50 »
Good chance of me joining if there is Winkey option with standard bottom row  :thumb:
Do a navy blue PCB :P
What case colors will be available outside the possible limited edition stuff? I love me some dark gray like the mockups are.
« Reply #21 on: Tue, 20 February 2018, 06:24:21 »
Oh damn this is lookin good
Offline ihalatch
« Reply #22 on: Tue, 20 February 2018, 06:29:47 »
$%#@ me! I like it so much I think I'll try to get into this GB too. Take it easy on my wallet mate!
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #23 on: Tue, 20 February 2018, 06:44:19 »
I think you know I want that young red PCB my guy, looking good though!  :thumb:
Offline Blackhawk
« Reply #24 on: Tue, 20 February 2018, 07:18:25 »
green pcb > red pcb
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #25 on: Tue, 20 February 2018, 07:48:34 »
yes me too thanks
limited cerakote edition spot pls
Offline frostbyte-gaming
« Reply #26 on: Tue, 20 February 2018, 08:37:27 »
Very cool definitely love Xondat's past designs and excited to see he is now doing a tkl with matching numpad.
Also really excited to see what colors for the limited edition people are looking to get. I know I would like to do some kind of green as that is a color I don't see too often but I think the dark red on the Singa r1 would also be cool.
Keep up the good work Xondat.  :thumb:
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #27 on: Tue, 20 February 2018, 09:10:51 »
Green pcb of course.
Xondat on a roll here. Great stuff  :thumb:
You're a smooth smoothie, you know? ~ Gaear Grimsrud
Offline megaforce
« Reply #28 on: Tue, 20 February 2018, 10:10:03 »
wheres the xrf
are u gonna include screws for the screw in stabs tho
« Last Edit: Tue, 20 February 2018, 10:15:48 by megaforce93 »
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #29 on: Tue, 20 February 2018, 10:19:17 »
Very nice!
Offline aznreaper
« Reply #30 on: Tue, 20 February 2018, 10:56:52 »
Interesting, will the limited editions have different weight cut outs/serial numbers like the 268?
Offline Peiweisgreat
« Reply #31 on: Tue, 20 February 2018, 12:13:03 »
YES! Finally a tkl design from you. This saves me the trouble of having to buy an elemento, but now I have to spend some on the pad as well. Anyway super excited for this buy, count me in. Also the pcb should be red. Most of your boards look black/red anyway, would just match the scheme.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #32 on: Tue, 20 February 2018, 14:23:02 »
What configuration of materials does the stated 2.4kg weight refer to?  All aluminum?  With brass options?
Offline futurecrime
  • Get Zooted
« Reply #33 on: Tue, 20 February 2018, 17:10:03 »
Oh yeah, green PCB.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #34 on: Tue, 20 February 2018, 17:50:56 »
Red PCB, no question!
Offline keebweeb
« Reply #35 on: Tue, 20 February 2018, 19:11:04 »
Red PCB pls
Offline xondat
  • i'm not a star
« Reply #36 on: Tue, 20 February 2018, 21:23:46 »
Not decided yet. Definitely Black, Silver, and Dark Gray. Down to do Red, and maybe a Navy.
wheres the xrf
Wrong thread m8
Hopefully little effort needs to be made, judging by the comments, I think there will be a quite high quantity. Should be easier on your wallet too :cool:
If I can think of something new ;D
Aluminum plate for both :)
For the sample PCBs, I'll order red and make my choice after that. Might as well mix it up a bit!
P.S. Added a hole that'll be on all plates for the reset button (for when programming). It's the worst thing when you're done assembling a case and need to undo 10 screws to press it :'(
« Last Edit: Tue, 20 February 2018, 21:50:15 by xondat »
Offline clankgy1
  • Formerly digifiend
« Reply #37 on: Tue, 20 February 2018, 22:00:50 »
MIght be intererested.  Has nothing to do with what is being offered, but everything to do with cash flow :(
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
Offline MMKB
« Reply #38 on: Tue, 20 February 2018, 22:22:32 »
No more words. Ready to place an order for white cerakoted 280+220.
Offline hayt
« Reply #39 on: Tue, 20 February 2018, 22:52:46 »
Have been enjoying seeing the progress you've made and refinements to the design! Nice work man!
Offline Nenija
« Reply #40 on: Wed, 21 February 2018, 02:58:41 »
Definitely interested in a 220 to match the 268! Which also means my vote goes for green PCB :P
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #41 on: Wed, 21 February 2018, 05:44:01 »
I’m worried that limiting the cerakote run to 30 might be too few to meet demand!
Offline amnesia0287
  • Formerly Amnesia
« Reply #42 on: Wed, 21 February 2018, 05:46:56 »
You do understand what the point of running a special limited edition is right? :P
Also, if its like 268 ag, its not 30 cerakote, its 30 custom colors and then a smaller cap on cerakote as he has to take them and get them finished himself.
He wants it limited on purpose, not because he is unaware of demand.
Offline phorx
  • ¯\_(ツ)_/¯
« Reply #43 on: Wed, 21 February 2018, 08:34:08 »
Sorry I'm still pretty new here.  So in a case like this, would there be a lottery when demand outstrips supply?  Or just FCFS?
Offline ramnes
  • T fou, mec?
« Reply #44 on: Wed, 21 February 2018, 10:04:29 »
:thinking:
Definitely interested but not now; too many projects and low on cash, sorry buddy!
Offline xondat
  • i'm not a star
« Reply #45 on: Wed, 21 February 2018, 10:30:01 »
Everything will be FCFS for this since I think there are plenty to go around over the two versions :p
I'll be doing a limited version of 30 because 1) keeps the custom stuff smaller, and easier; 2) I like limited stuff; 3) makes them even more special ;D
Offline Choppersuey
« Reply #46 on: Wed, 21 February 2018, 12:30:13 »
Is this bundle only or can you purchase the TKL without the numpad?
Offline p_blaze
« Reply #47 on: Wed, 21 February 2018, 12:33:17 »
Do i need to buy the numpad as well for the special edition?
Offline amnesia0287
  • Formerly Amnesia
« Reply #48 on: Wed, 21 February 2018, 14:07:45 »
What kind of monster buys a limited edition custom color keyboard without both parts O_o.
Offline p_blaze
« Reply #49 on: Wed, 21 February 2018, 14:11:48 »
An optimistic, yet poor one.
