Author Topic: Arsonite - my keyboard layout  (Read 8395 times)
Offline naveed
« on: Wed, 21 February 2018, 14:58:00 »
I've been using this for about 13 years now, though I only put up the site not too long ago. I was suffering from RSI and I wanted something more efficient than QWERTY and didn't want to spend too much time relearning the layout.
www.arsonite.com
Offline emenelopee
  • *klomp klomp klomp* I step on your house 🦖
Re: Arsonite - my keyboard layout
« Reply #1 on: Wed, 21 February 2018, 15:09:45 »
I was with you until I saw the semicolon - taking out the left index finger to bring the right pinky into play doesn't sound right to me. How does it feel in practice?
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Thu, 22 February 2018, 03:29:49 »
So, it uses the home row more than QWERTY, alright? Other than that, same-finger ratio is still terrible and that script doesn't measure row jumps, non-trivial hand alternation or roll direction.
If it's comparable to anything, that's Minimak.
Offline batfink
« Reply #3 on: Wed, 28 February 2018, 12:30:40 »
Looks very similar to Norman.
Good for people who prioritize speed of relearning.
But doesn't fix Qwerty's annoying same-finger issues, e.g. DE, LO, etc.
I'd also swap P with semicolon.
Offline ThoughtArtist
« Reply #4 on: Fri, 02 March 2018, 16:02:09 »
Use foot pedals for the modifiers. Thank me later
Offline naveed
« Reply #5 on: Thu, 15 March 2018, 16:27:09 »
I used to code in C# at the time, and wanted to easily access semi-colon. Worked out fine for that. I don't code in C# as much any more, but the location of the semi-colon has not been a problem.
