Author Topic: 40% keyboard parts: JD40 Mark II PCBs and Sorbothane spacer gaskets  (Read 3752 times)
Offline Photoelectric
  • Trade Count: (1)
I have some left-over JD40 Mark II PCBs and custom-made Sorbothane spacer/dampening gaskets from the SmallFry group buy which are now for sale here, to help recoup some of the huge costs of salvaging the group buy.
The JD40 II PCB is fully programmable and supports in-switch LEDs.  Programming guide here:
https://geekhack.org/index.php?topic=83626.0
Sorbothane gaskets are made to fit the plates for SmallFry kits, but perhaps also fit other generic 40% plates that are made to fit JD40 PCBs.  If you are interested, you can send me the dimensions of your plates and I will check.  I recommend getting m2 size nuts and bolts in either 18mm or 20mm length, depending on how thick your plate-gasket-plate sandwich is (measure it first, get bolts based on your measurement).  Sorbothane gaskets come with no holes but are very easy to pierce with a thick needle to then follow with a bolt screwed in carefully with a screwdriver, once you align the gasket between the plates.  Thus you can adapt them to different plate hole locations.  For assembly reference, please see a picture assembly guide for the SmallFry kit here.
PCBs:
Brand new, will come pre-programmed with default layout.
$28 per PCB + PP fee and shipping.  Prefer to ship within the U.S.A.
Sorbothane gaskets for 40% "sandwich"-style kits:
$18 per gasket + PP fee and shipping.  Prefer to ship within the U.S.A.
« Last Edit: Tue, 06 March 2018, 16:26:20 by Photoelectric »
  • Trade Count: (1)
Re: 40% keyboard parts: JD40 Mark II PCBs and Sorbothane spacer gaskets
« Reply #1 on: Thu, 01 March 2018, 17:33:59 »
Bump.
  • Trade Count: (1)
« Reply #2 on: Sat, 03 March 2018, 18:54:56 »
Bump #2
  • Trade Count: (1)
« Reply #3 on: Sun, 25 March 2018, 18:05:08 »
Bump #3
  • Trade Count: (1)
« Reply #4 on: Mon, 02 April 2018, 20:46:33 »
Bump #00000100
  • Trade Count: (1)
« Reply #5 on: Sun, 22 April 2018, 16:00:52 »
Still a bunch available!
  • Trade Count: (1)
« Reply #6 on: Sat, 12 May 2018, 18:31:37 »
 :blank:
