Author Topic: [IC] Chiwi60 brass body with black PVD  (Read 4983 times)
Offline sennin32
    • Doyu Studio
« on: Tue, 27 February 2018, 06:12:21 »
IC link : https://goo.gl/forms/tIZBydVJE2Zwt3m43
We want to know if the brass ver. Chiwi60 is possible to be made.
So we start a new check for Black PVD.
Please make sure you really want it before chose "yes".
We're asking quotation based on interesting check result.
If final quantity is far away from the quantity we are planing to order, will only make the project fail :(
We will offer only type C port cutout this time.
FAQs:
Other color?
No, quantity can not even close to MoQ for single color, not possible to offer more colors.
Full brass?
No, reason why is the same as first question.
Weight?
around 1.5~1.7 for full keyboard build.
Estimate price?
Higher than $250 for sure, if quantity is enough, we hope under $300.
Offline KaosJ
Re: [IC] Chiwi60 brass body with black PVD
« Reply #1 on: Tue, 27 February 2018, 06:19:46 »
YES YES YES YES YES! (Or dark purple)
Offline Vulcan
« Reply #2 on: Tue, 27 February 2018, 06:21:48 »
May i know how heavy is the case only with brass.. and does this support gh60 and other poker PCB?
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #3 on: Tue, 27 February 2018, 06:21:55 »
yes
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #4 on: Tue, 27 February 2018, 06:22:39 »
case is 1.2kg unbuilt without pcb, and 1.6 with everything incl. caps
should support standard 60 pcbs
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #5 on: Tue, 27 February 2018, 11:52:17 »
My vote is for black.
As we saw before, it's quite hard to reach MOQ so we need to keep it simple.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #6 on: Tue, 27 February 2018, 17:56:46 »
Also, I think a larger cutout would be better to increase compatibility with other PCBs, especially since it will be difficult to reach MOQ and people don't want to be stuck with the DO60 for better or for worse.
Offline KaosJ
« Reply #7 on: Wed, 28 February 2018, 03:06:26 »
Yeee boi, let's go black!
Offline sennin32
    • Doyu Studio
« Reply #8 on: Wed, 28 February 2018, 06:32:30 »
No, only support USB TYPE-C PCBs.
Offline ctrl
« Reply #9 on: Wed, 28 February 2018, 16:21:05 »
Looking good! But will this too offer 6u spacebar HHKB layout?
Offline KaosJ
« Reply #10 on: Fri, 02 March 2018, 09:21:45 »
How is going, enough interest?
Offline Darknight00z
« Reply #11 on: Fri, 02 March 2018, 23:24:42 »
If this is a go. Can I swap my ALU for this?
Offline nu_types
  • Formerly Iredeus
« Reply #12 on: Mon, 05 March 2018, 21:03:55 »
Very interested
