Author Topic: Information about Ajazz AK 33  (Read 3231 times)
Offline demas
« on: Thu, 01 March 2018, 05:48:26 »
I have a single light version (https://ru.aliexpress.com/item/Ajazz-AK33-82-keys-Wired-Keyboard-Black-White-RGB-Backlight-Blue-LED-USB-Multimedia-Ergonomic-illuminated/32831903816.html), blue switch.
I have other keyboards with blue switches, but switches in this keyboard have a little bit different sound, than others.  May be you know which type of blue switches are used in this keyboard ? Because I really like this sound.
And second question about keycap profile.  It looks like OEM, but I am not sure and just want to check.
Thanks in advance.
p.s In the specification for RGB version I have found information about ZT Blue Switch, but I am not sure are there the same switches on single light version, and I can not find any information about this type of switches.
Offline demas
Re: Information about Ajazz AK 33
« Reply #1 on: Fri, 02 March 2018, 02:12:35 »
I have found answer for my first question" it is Zorro Blue switches: https://deskthority.net/wiki/Zorro_Blue
