Author Topic: [IC] GMK Phantom - GB May 1st 2018  (Read 103070 times)
Offline KaosJ
Re: [IC] GMK Phantom *update 3/25/2018 - euro and colevrak kits
« Reply #100 on: Sat, 31 March 2018, 05:53:21 »
I think the set lack contrast making it too dark as a whole.
The purple is a novel idea,
I would recommend testing yellow alpha with purple font or at least adding in a yellow space bar or more yellow mods be it in the F row or something like that
To me, the main attraction of this set lies with its monotone keycaps, with the exception of the Enter, Esc, and Arrow keys. Changing it to have a colored mods or fn rows will just make this set like any other sets out there with different colors.
As for the colored spacebar, I think it was mentioned before that adding it will increase costs, with the unspoken agreement that colored spacebars will be offered in a separate child kit instead.
Plus, I think the price for the base kit would not be cheap, seeing how huge the current base kit is. Creating a separate child kit to accomodate more colors will make more sense. Even so, there is always a challenge of meeting MOQ for each kit (100 for child kit iirc).
I do agree on everything.  The only change i would do is probably yellow spacebars instead of purple spacebars in base kits (to not increase price), but not sure if this will be ok for all the others. Both options are ok for me
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
« Reply #101 on: Sat, 31 March 2018, 14:56:33 »
Base kit needs to have alpha colored spacebars, not accent colored. The only exception being having both alpha and accent colored 6.25u and 7u spacebars in the base kit with alpha/accent 6u spacebars in the spacebars kit.
Additionally, the whole point of this set is the purple monotone, so reversing the alphas is not the way to go.
Offline KaosJ
« Reply #102 on: Sat, 31 March 2018, 15:24:27 »
ikr but every monotone also have a spacebar kit accented while this one doesn't, so the whole thing "base kit must have blabla" doesn't stand.  I proposed  yellow spacebars instead of adding them, which would increase the price too much (still i wouldn't mind, both are fine to me).
On monotone it doesn't look bad and the spacebar is still one of the keycaps that is usually accented (in other kits like spacebars-kit, which this set will not have) so the answer should be "yes i like"/"no i don't like", not "it can't be like that because others never did it", simply for the fact that this set is different.
« Last Edit: Sat, 31 March 2018, 15:40:07 by KaosJ »
Offline amnesia0287
  • Formerly Amnesia
« Reply #103 on: Sat, 31 March 2018, 16:38:40 »
ikr but every monotone also have a spacebar kit accented while this one doesn't...
This is not even a little bit true. GMK Terminal R1, no accent space bar in base. GMK Stormtrooper, no accent spacebar. GMK Pristine, no accent spacebar. GMK Demonic, No accent spacebar. GMK Blue on Black, no accent spacebar in base. GMK Monkey,  no accent spacebar. GMK Skidata+,  no accent spacebar in base.
What monotone set has the accent spacebars in the base? As far as I am aware no one has ever said no spacebar kit.
Offline briano1905
« Reply #104 on: Sat, 31 March 2018, 16:51:56 »
space news:
i have the space kits ready
the reason its not up on the thread yet is because gmk is still working on the quotes and i want to know if its actually worth it to split the kits.
about yellow space bar, how many are interested in them? tbh i dont think it will look that great but please let me know if you want to see yellow space
Sent from my SM-G950F using Tapatalk
Offline KaosJ
« Reply #105 on: Sat, 31 March 2018, 17:03:07 »
At least read please before making a list "ikr but every monotone also have a spacebar kit accented while this one doesn't...
I never said that the spacebar accented was in the base set lol.
And later you say:
GMK Terminal R1 (which has a spacebar kit accented as i wrote)
GMK Blue on Black  (which has a spacebar kit accented as i wrote)
GMK Pristine  (which doesn't even have accents)
GMK Stormtropper (which doesn't even have accents lol)
GMK Demonic (which is a small set, not even iso and many other caps, ofc doesn't have all the accents)
GMK Monkey (which is a really really small set with as far as i remember no accents offered in gb)
GMK Skidata+ (which has orange accents in spacebar kit as i wrote)
Now, if you wanted to prove that my "every" is wrong, it's just hilarious, and even tho your list is wrong.
If you didn't get it, my point is that most of the monotone that are big enough have usually  the spacebar kit which will have these accented spacebars.
Now, IF this will not have a spacebar kit with Phantom so no accented spacebars, my suggestion was to have directly the accented spacebars in the base kit instead of the base spacebars, which is not usual to do yeah, but it isn't either usual to not add a spacebar kit with accented spacebars in such big sets with many kits, so Phantom is kinda unique on his path, so why we can't do something different?
Hope this cleared things up, didn't meant to be aggressive but the list was a bit unnecessary. Maybe i was unclear in the previous post or maybe you just fast-read it, peace
« Last Edit: Sat, 31 March 2018, 17:07:52 by KaosJ »
Offline donut_sauce
« Reply #106 on: Sat, 31 March 2018, 17:07:50 »
space news:
I’m personally not interested in a yellow spacebar but that’s just me.
Offline KaosJ
« Reply #107 on: Sat, 31 March 2018, 17:18:39 »
space news:
That should be an answer to a suggestion :D
I personally feel like you, i do prefer purple spacebar over yellow, but just SLIGHTLY so whatever will be i don't care. I added this suggestion mostly because that guy i was answering before it wasn't the only one wanting yellow/beige spacebars so that was the only solution that came in mind to avoid adding more keys in base and without adding a new kit which i'm not sure OP wants.
Since it will be hard to agree on what color on the spacebars and since usually spacebar kits happens, the only question at this point is:
HOW MANY WOULD ENTER FOR A SPACEBAR KIT WITH YELLOW SPACEBARS AND EXTRA SPACEBARS? (e.g. split too?)
Offline amnesia0287
  • Formerly Amnesia
« Reply #108 on: Sat, 31 March 2018, 17:19:25 »
And later you say:
Have you been following the thread though? Space kit was already discussed and mentioned as planned a month ago... so my assumption is you are complaining about the base because what you are asking for is already being added. Also, there is nothing in my list that is wrong, I simply didn't ALSO mention space bar kits as to me saying "no accent in base" is clearly indicating there was a spacebar kit and "no accent" indicates more obviously there is no option for an accent at all.
Let's not forget the next part of your quote that i left off:
Wonder why I thought you were talking about base kits...
Plus when you add CONTEXT:
Sorry I'm not psychic... To me reading everything you wrote, I get the impression you want yellow spacebars in the base and are complaining that they are not there. Where exactly am I misunderstanding you?
Offline KaosJ
« Reply #109 on: Sat, 31 March 2018, 18:02:37 »
EDIT: nvm just stahp both of us, keep the IC clean, i'm on discord if you want
don't click that stupid button below, that was my answer that will generate other useless answers for this IC
Have you been following the thread though? eSpace kit was already discussed and mentioned as plannd a month ago...
Yes since MD contest.  I guess you are still not reading.
The point is that OP for a while didn't really wanted to add the spacebar kit (which is totally understandable).
I don't think we need to discuss this anymore since the spacebar kit accented will probably be added as a extra kit (which i also suggested to op privately), and if it happens ok, otherwise who cares.
To make it clear, i don't care a single **** about yellow spacebars and have multiple screenshots confirming it (i also do like a lot purple in case you don't know me, just like you do).
I suggested it because multiple people asked and not only here, my point is to make them happy since 250 MOQ nowdays with another purple is not that easy, so people must be in fact happy at the end.
Your list in a tldr:
- Monotones with accented spacebars in "spacebar kit"
when i said: "ikr but every monotone also have a spacebar kit accented while this one doesn't..."
Which basically means that monotones doesn't have accented spacebars in base but they have the accented spacebars in the spacebar kit while this didn't had any planned spacebar kit really happening.
 E.g sets like Terminal and BoB shouldn't be in your list.
- Monotones without accents :thinking:
- Monotones with not even 120 keycaps :thinking:x2
...so the whole thing "base kit must have blabla" doesn't stand. I proposed yellow spacebars instead of adding them, which would increase the price too much (still i wouldn't mind, both are fine to me).
Which is my answer to donut when he basically said "base kit can't have accented spacebar".. umh?
I'll try to explain again since this is the only thing of your whole quoting where you might be right and i was unclear on this:
1 - I like purple over everything else.
2 - I prefer in fact purple spacebars SLIGHTLY over the yellow spacebars, whatever of them happens, i'm ok.
3 - I suggested yellow/beige spacebar instead of purple because i saw multiple people asking.
and
4 - OP will probably run that spacebar kit and if it happens ok, otherwise still ok. MOQ should be 100 so it might happen and no one will complain.
5 - Can we please stop this useless "quote-fight" already?
« Last Edit: Sat, 31 March 2018, 18:41:53 by KaosJ »
Offline jimirolln
« Reply #110 on: Sat, 31 March 2018, 18:46:03 »
can you do a render with the yellow bar on the monotone set?
i don't have a horse in this race as i have burnt my keeb budget for the next couple...but it would make for a good segway into a productive convo
whether it is well received or not
Offline Atredl
« Reply #111 on: Sat, 31 March 2018, 19:26:45 »
Just putting in my 2¢ but I’m not interested in the beige spacebars. I don’t mind if they’re in a spacebar kit but please don’t take the purple ones out of the base kit.
Offline Solotov
« Reply #112 on: Sat, 31 March 2018, 19:33:47 »
space news:
For this set, I will only go for purple spacebar as the yellow would ruin the monotone of this set, imo.
Flex is love, flex is life.
Offline KaosJ
« Reply #113 on: Sat, 31 March 2018, 19:37:51 »
Pretty sure OP will run the base kit like it is and put the accented spacebars where it should be, in the spacebar kit.
Purple spacebar seems secured boys, that change won't happen  ;D
The real question now is how many would join the spacebar kit (which should contain split spacebars and yellow spacebars) ?
Offline Al41
« Reply #114 on: Sat, 31 March 2018, 19:48:03 »
I plan on using a custom spacebar but i do like the purple more. That being said i think i would still be in for a yellow/beige spacebar kit. I'm new and just starting my collection so i don't mind having extra color options, just in case i want mix with future sets.
Offline cldskt
  • Wallet and hobby aren't friends
« Reply #115 on: Sun, 01 April 2018, 07:46:50 »
space news:
I personally wouldn't mind having a beige spacebar, provided that the price of the base kit does not increase.
If putting the beige spacebar increases the price of the base kit, I'm all for bundling the accent spacebars together in the spacebar child kit instead.
"Addiction is buying the things that I don't need with the money I don't have." - me
"Spending $500 on your first custom is justified." - also me
Offline x86ect
« Reply #116 on: Mon, 02 April 2018, 02:28:32 »
You don't get to be Kings and Queens without the gold [space] bars to back it up.
Offline cldskt
« Reply #117 on: Tue, 03 April 2018, 20:44:59 »
AFAIK there are these GMK runs currently running:
GMK Happy Life: until 15/4
GMK Doom: until 20/4
GMK Necro: until 27/4
GMK Olivia: until 28/4
So is it to safe to say that this will run after Olivia ends?
Offline wowremy
« Reply #118 on: Fri, 06 April 2018, 01:38:51 »
I really hope this set happens... In like a month or so.
Offline Marutks
« Reply #119 on: Wed, 11 April 2018, 14:56:39 »
Where is 1.5u "Meta" or "Code" keycap?  Many boards support only 1.5u key for Cmd/Win.  (Zephyr, M60)
Offline wowremy
« Reply #120 on: Thu, 12 April 2018, 00:40:58 »
I agree, this set needs a Gold spacebar, and even Golder legends.
Offline tanvir175
Re: [IC] GMK Phantom *update 4/13/2018 - spacebar kit
« Reply #121 on: Sat, 14 April 2018, 12:22:06 »
Gonna need to find a keyboard to put this on
Offline dead_pixel_design
  • IIIV is not a Roman Numeral. Positive Vibes.
« Reply #122 on: Sat, 14 April 2018, 14:01:40 »
I bet this would look good on the MoM0110
Offline tanvir175
« Reply #123 on: Sat, 14 April 2018, 14:39:10 »
Oohhh, definitely. I was planning on using Alps DSA Lightcycle or Japanese AEK for that, though. With either Blue or Brown alps. Not sure.
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #124 on: Sat, 14 April 2018, 16:04:15 »
If only we could have a Rolls Royce novelty.
"Phantom" has been the name of a many Rolls Royce models in the past.
Offline briano1905
« Reply #125 on: Sat, 21 April 2018, 07:04:02 »
:cool: :cool: :cool: :cool:
Offline Solotov
Re: [IC] GMK Phantom - GB May 1st 2018
« Reply #126 on: Sat, 21 April 2018, 07:58:58 »
Omg, finally it's happening!  :thumb:
Offline ewwgin
« Reply #127 on: Sat, 21 April 2018, 08:01:32 »
Sweet! I need to get a board for this then. What board is everyone putting this gorgeous set on?
Offline Solotov
« Reply #128 on: Sat, 21 April 2018, 08:39:45 »
I think it will look good on any dark color boards  :))
Offline briano1905
« Reply #129 on: Sat, 21 April 2018, 08:53:06 »
hhkb or rama m60-a or both :p :p
Offline mudcakehoney
« Reply #130 on: Sat, 21 April 2018, 10:00:59 »
Silver Kira EXS with purple insert
Offline RSC
« Reply #131 on: Sat, 21 April 2018, 10:04:09 »
When I see this, I think this is one of those sets that should also offer an optional blank modifiers kit. Damn, it looks amazing like this.
Offline cldskt
« Reply #132 on: Sat, 21 April 2018, 10:21:10 »
H Y P E
Offline Hutch
« Reply #133 on: Sat, 21 April 2018, 11:22:35 »
What cases are in the render images #3, #4, #5, and #6?
Offline KaosJ
« Reply #134 on: Sat, 21 April 2018, 11:31:45 »
The first one should be a prototype render of a keeb by Janglad, a keyboard that never happened.
The second seems to not be a specific case, but you can find multiple keebs with that layout/case style.
Offline BlackInk
  • "Manners maketh man"
    • TeamGSB
« Reply #135 on: Sat, 21 April 2018, 14:49:31 »
everyone get on the HYPE train
Offline ye_cole
« Reply #136 on: Sat, 21 April 2018, 15:26:16 »
is it too late to request weeb legends?
Offline Remsky
  • Lubed switch count > Puddsy post count
« Reply #137 on: Sat, 21 April 2018, 15:33:15 »
I mean it is entering GB phase like really soon....
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline Atredl
« Reply #138 on: Sat, 21 April 2018, 16:10:13 »
Offline KaosJ
« Reply #139 on: Sat, 21 April 2018, 16:14:15 »
: H A N G E R Y F A C E :
Offline Atredl
« Reply #140 on: Sat, 21 April 2018, 16:36:33 »
How about we keep weeb legends in sets where it fits the theme.
Offline cldskt
« Reply #141 on: Sat, 21 April 2018, 20:44:55 »
inb4 the hype train I hope we can see some smexy color samples from GMK ;)
Offline Rogue_Jellybean
« Reply #142 on: Sat, 21 April 2018, 20:48:06 »
Looking forward to this, should be my first GMK set! I love how not over-the-top the novelties are.  :eek:
Offline briano1905
« Reply #143 on: Sun, 22 April 2018, 15:15:23 »
original post updated with pricing!  ;D ;D
Offline bball2
« Reply #144 on: Sun, 22 April 2018, 15:35:02 »
Nice! $145 @ 250 MOQ is legit especially with those novelties in the base kit.
Hoping the Canadian pricing is just the exchange rate conversion.
Offline KaosJ
« Reply #145 on: Sun, 22 April 2018, 15:40:31 »
Don't forget that dope 135 euro in EU with Mykeyboard.  Usually with VAT we ends up to pay a lot more, but this time is really reasonable :)
Offline cldskt
« Reply #146 on: Mon, 23 April 2018, 07:27:06 »
Screamed internally knowing that this is shipping in November. But if November shipping is what it takes to get proper QC, I'll be willing to sit tight.
One question though: the "$-" pricing for Asia/AU/NZ, does it mean that they will have different pricing than US ones?
Offline xondat
  • i'm not a star
« Reply #147 on: Mon, 23 April 2018, 07:30:06 »
Most likely different prices since it'll be a different vendor and they have additional fees to cover etc.
Offline cldskt
« Reply #148 on: Mon, 23 April 2018, 07:31:36 »
Ah gotcha. Hope that the difference won’t be exorbitant cause the US price looks pretty neat.
Offline yap68
« Reply #149 on: Mon, 23 April 2018, 07:59:37 »
Pretty good pricing. Hope we can meet the moq.
