Author Topic: How to change the Microcontroller in a Aivia Osmium!  (Read 15314 times)
Offline cl0rm
Re: How to change the Microcontroller in a Aivia Osmium!
« Reply #50 on: Fri, 03 April 2020, 08:40:50 »
I do not have the schematics, but I think most things should be in the easyAVR config files, there you can read about the pinout (And the Matrix):
Offline codezero
« Reply #51 on: Fri, 03 April 2020, 08:51:27 »
 Thanks a lot! I just ordered a teensy, so I'll let you know how it goes once I lay my hands on it
