Author Topic: [IC] HOLO Custom TKL Keyboard (GB has been launched)  (Read 44987 times)
Offline icyskyz
Re: HOLO Custom Keyboard
« Reply #50 on: Sat, 18 August 2018, 07:50:17 »
This...sounds like a recipe for disaster. Particularly with an unprotected PCB. Messy eaters beware!
Looks very good!
Thank you guys for the input!  :)
I will upload some clips of how the keyboard would sound like when I get the custom PCB and get everything together.
I have also decided not to add any bottom piece or else it might defeat the purpose of the board.  ^-^
And I'm still trying to figure out a solution to protect the PCB.
« Last Edit: Sat, 18 August 2018, 07:54:00 by icyskyz »
My collections - flickr | HWS Keyng Collector |
Offline Sshimosawa
HOLO Custom Keyboard (New prototype arrived)
« Reply #51 on: Sat, 18 August 2018, 10:40:08 »
Go with your original design. Not really sure how the pcb will get damaged in real world use unless youre constantly transporting it. Of course any exposed electronics will be at risk but if the guy wants to make a bottomless board then he should....
« Last Edit: Sat, 18 August 2018, 16:32:35 by Sshimosawa »
Offline Jkush463
Re: HOLO Custom Keyboard (New prototype arrived)
« Reply #52 on: Sat, 18 August 2018, 10:44:12 »
interesting for sure, what was the inspiration for this? just wanted something lighter or different? just curious dont think i have seen another case take this approach. sure looks good.
Offline icyskyz
« Reply #53 on: Sun, 19 August 2018, 02:06:29 »
Thanks man! That's the way I will be doing the board  :thumb:
Offline icyskyz
« Reply #54 on: Sun, 19 August 2018, 02:07:44 »
I appreciate the kind words man!  :D
I wanted to take difference approach on the design and yet still trying to keep it simple for the look.
I don't know how the sound of the hollow might actually turn out but I will have update on that soon!
Offline ppg77889
« Reply #55 on: Sun, 19 August 2018, 02:20:49 »
Offline Darknight00z
« Reply #56 on: Mon, 20 August 2018, 11:53:05 »
How heavy is the unbuilt proto right now?
Any considerations for a full brass one? I like a heavy board.
Offline icyskyz
« Reply #57 on: Tue, 21 August 2018, 12:19:27 »
I will weigh the board soon as I don't have scale with me.
And yes, I was planning to make couple of full brass board if anyone would be interested when the group buy starts but the cost is going to be much higher than the regular aluminum boards though.
Offline mkarlsson
« Reply #58 on: Tue, 21 August 2018, 13:08:25 »
Any estimated price after this prototype?
Also, will ISO be supported?
Offline ender
« Reply #59 on: Tue, 21 August 2018, 19:31:17 »
Will it be WKL only?
also, PLEASE get rid of the north facing LEDs.
Offline icyskyz
« Reply #60 on: Wed, 22 August 2018, 12:42:26 »
I will have the estimated price soon. I need just some more time to get all the packaging and PCB prices altogether.
Unfortunately, ISO will not be supported. Sorry :(
Offline icyskyz
« Reply #61 on: Wed, 22 August 2018, 12:43:25 »
Yes, it will be WKL only.
What do you mean by the north facing LEDs? I didn't really get that part.
Offline icyskyz
« Reply #62 on: Wed, 22 August 2018, 12:43:53 »
Just give me your money!  :p
Offline ender
« Reply #63 on: Wed, 22 August 2018, 19:43:06 »
On the renders, the switches are facing with the LEDs up, not down. This can cause interference with cherry profile caps. If you're not including a PCB you can disregard all of this.
Offline ender
« Reply #64 on: Wed, 22 August 2018, 20:51:37 »
Also, as long as the PCB is completely standard, it might be better to not include a PCB and suggest people buy the h87a instead, as it's part of a larger GB and will be cheaper.
Offline rymnd6c28
« Reply #65 on: Wed, 22 August 2018, 21:20:59 »
might as well go with all uni body, including the plate, a thick one  ;D ;D
Offline icyskyz
« Reply #66 on: Wed, 22 August 2018, 21:51:07 »
Oh I will definitely keep that in mind. Thanks!
I understand where you are coming from but it is just more convenient to include the PCB in the kit so people don't have to go through troubles buying the PCBs.
Offline icyskyz
« Reply #67 on: Wed, 22 August 2018, 21:53:03 »
I have thought about that but I need that additional weight that brass plate provides. ;D
Offline rymnd6c28
« Reply #68 on: Wed, 22 August 2018, 22:28:54 »
I see, me personally doesnt really drawn in by brass. But a thicker brass would be nice too!
Also I like the HOLO logo, but the spacing could be a little more between the logo and the edge of the backside.
Offline icyskyz
« Reply #69 on: Thu, 23 August 2018, 03:58:14 »
Yup, it will be a thick brass plate that's for sure! Thanks! :thumb:
The design is pretty much finalized though. :-X
Offline rymnd6c28
« Reply #70 on: Thu, 23 August 2018, 12:25:43 »
Ah well, its a minor thing tho, don't mind it. But still would be nice if the logo is just slightly smaller so it doesnt sit so much on the edge.
Are there any estimated price? and have you decided the exact thickness for the plate?
Offline catamscott
Re: HOLO Custom Keyboard TKL
« Reply #71 on: Thu, 23 August 2018, 18:03:23 »
very interesting idea, really like the design and am very curious as to how it might sound. looking forward to hearing what the final price estimate is!
Offline icyskyz
« Reply #72 on: Fri, 24 August 2018, 14:37:35 »
I will have the estimated price when I get the next prototype.  :)
Plate thickness is 1.5mm.
Offline icyskyz
« Reply #73 on: Fri, 24 August 2018, 14:38:54 »
I'm glad you like the board, thanks! :D
I will update here as soon as I have the estimated price.
Offline GeneriksGiraffe
  • Living the Rubber Life
« Reply #74 on: Sat, 25 August 2018, 23:24:16 »
I don't even have anything to say. This is just super clean. Beautiful.
SOMEONE PLEASE SELL/TRADE ME AN HHKB PRO 1
Offline icyskyz
« Reply #75 on: Sun, 26 August 2018, 05:23:58 »
Thank you and I'm really glad you like it!  :thumb:
Offline icyskyz
« Reply #76 on: Fri, 14 September 2018, 13:38:28 »
Just got the custom carrying case sample for the HOLO keyboard, the case still needs some tweaks though.
The case will come with the HOLO keyboards when the groupbuy starts.
« Last Edit: Fri, 14 September 2018, 13:45:57 by icyskyz »
« Reply #77 on: Fri, 14 September 2018, 14:05:30 »
OOF that looks fantastic!
Offline Delirious
« Reply #78 on: Fri, 14 September 2018, 14:15:37 »
for pcb protection, just add an acrylic to the bottom of the pcb like all the bent steel case. Look up bent steel case if you want to see an example.
Basically use the same mounting holes for the plate and just add spacers in between.
« Last Edit: Fri, 14 September 2018, 14:18:25 by Delirious »
Offline icyskyz
« Reply #79 on: Fri, 14 September 2018, 21:59:47 »
Offline icyskyz
« Reply #80 on: Fri, 14 September 2018, 22:01:29 »
Alright, I appreciate the suggestion! I will see what I can do with that. Thanks!
Offline rymnd6c28
« Reply #81 on: Sat, 15 September 2018, 00:54:57 »
how soon is the GB? if it fits my budget and have a WK version, I am in
Offline icyskyz
« Reply #82 on: Sun, 16 September 2018, 12:08:26 »
GB should start soon after I get the second keyboard sample in.
Unfortunately, it only comes with the WKL version, I'm sorry. :(
Offline lundmore
« Reply #83 on: Sun, 16 September 2018, 19:26:20 »
Have you considered having no logo on the back and moving it to a polycarb/acrylic plate underneath the PCB? The HOLO logo seems a bit showey for my liking... Maybe if it was just smaller, like half the size it is now, I dunno.
Offline icyskyz
« Reply #84 on: Mon, 17 September 2018, 00:02:12 »
The large logo on the back was one of the initial ideas in making the HOLO so I will not be changing it most likely. Sorry about that.
Offline SteffeMK
« Reply #85 on: Sat, 22 September 2018, 10:10:11 »
Any updates on this?
Offline icyskyz
« Reply #86 on: Sat, 22 September 2018, 16:02:19 »
New sample is still on the way. I will post updates here as soon as I get it!
Offline NINJER
« Reply #87 on: Wed, 17 October 2018, 07:40:38 »
This site is bad for everyone's health... Too many things that we must buy....
Sent from my SM-N960F using Tapatalk
Offline icyskyz
« Reply #88 on: Thu, 18 October 2018, 14:53:04 »
I have got the final CNC sample in dark grey earlier today and every little thing has been fixed up. :)
The final color options are: Dark Grey, Light Grey and Blue Grey. I will have the estimated price for the board soon.
Here is a photo comparison between dark grey and light grey:
Some photos of new sample:
« Reply #89 on: Thu, 18 October 2018, 15:42:08 »
A typing test would be crucial I think.
Offline SteffeMK
« Reply #90 on: Thu, 18 October 2018, 15:48:40 »
+1, I'm really interested how it sounds
Skickat från min SM-N950F via Tapatalk
Offline mkarlsson
« Reply #91 on: Thu, 18 October 2018, 19:50:47 »
Any idea about the price?
Offline icyskyz
« Reply #92 on: Sun, 21 October 2018, 15:26:21 »
Here is a short clip of how it might sound: https://www.youtube.com/watch?v=mpwqXRa15sM
Quick Setup:
- 2010 Vintage Cherry Blue Switch
- OG Cherry Dyesub PBT
- Brass Plate
But of course it might sound different depending on the type of surface the board is sitting on or using a different type of switch.
Offline icyskyz
« Reply #93 on: Sun, 21 October 2018, 15:28:55 »
Sorry I have been busy for the past few days. I will have that up ASAP.
Offline icyskyz
« Reply #94 on: Thu, 25 October 2018, 16:42:36 »
I have added the price for the keyboard kit.
Special treatment is applied to each brass plate so it will not turn black or oxidize after being touched by hands.
Price:
  • Keyboard, brass plate, PCB, case - $360
  • Extra PCB - $28
  • Extra brass plate - $55
  • Shipping & PayPal fees are additional
Re: HOLO Custom TKL Keyboard
« Reply #95 on: Sat, 27 October 2018, 02:41:33 »
How heavy is the board?
Offline icyskyz
« Reply #96 on: Sat, 27 October 2018, 03:23:48 »
The board itself is around 2.65 pounds (1.2 kg) and with carrying case is around 6.06 pounds (2.75 kg).
« Reply #97 on: Sat, 27 October 2018, 08:40:41 »
lol rip shipping fees
Offline iliketimex
« Reply #98 on: Sat, 27 October 2018, 12:30:36 »
Really like the bevels. I am hoping this will be a normal GB and not a raffle.
Offline icyskyz
« Reply #99 on: Mon, 29 October 2018, 11:54:07 »
I'm glad you like the design, and yes this will run as a normal GB not a raffle. :)
