Author Topic: Wtb colored or transparent switch tops, single colored clackerinos  (Read 2832 times)
Offline Signature
  • master of puppers
  • * Moderator
  • Trade Count: (2)
  • snoozing
Doesnt techkeys have clear switch tops?
for 0.5 dollar per piece... Worst case scenario I'll order some from there, ty anyway!
If you are using normal plate cut outs I had some issues with the techkeys clear switch tops. Some of them prevented me from properly installing them, had to shave down the sides with a knife just to get them to fit.
Good to know! Thanks :)
Offline Ruskie
  • Trade Count: (0)
Re: Wtb colored or transparent switch tops, single colored clackerinos
« Reply #1 on: Sun, 13 January 2019, 14:51:31 »
I have some blue dyed colored switch tops if you would like them!
Ive got myself a beefy boi
-Alf F62PE
-PCB Mount ZealV2 67g
-GMK KA1953 "OG Classic Retro"
8 pounds of clack
Offline Signature
  • master of puppers
  • * Moderator
  • Trade Count: (2)
  • snoozing
« Reply #2 on: Sun, 13 January 2019, 15:35:43 »
Ah I've already got them now hehe
